Darrell S wrote:
Not quite. You can still move the throttle(s) but when you release them the autothrottle system (if still engaged) will return the throttle(s) to try to achieve what you're asking of the system. That could be to obtain and maintain a given speed or to set a power setting like T.O. Power, Climb Power, Cruise Power, etc. Some systems have a "clamp" operation where the throttle(s) can be moved and will stay there until an even occurs which brings the throttle(s) out of "clamp" and they again try to maintain a speed or a power setting. IIRC, trying to manually move the throttles on a Gulfstream will result in an autothrottle disconnect and associated amber CAS message. |
Bob Martin wrote:
IIRC, trying to manually move the throttles on a Gulfstream will result in an autothrottle disconnect. Makes sense too that way, isn't it? Cap'n Doug, if you're reading this... I recall clearly, on the one occasion I was in an A320 flight deck, that the AutoThrottle's variations weren't reflected in corresponding changes in position of the throttle. So when you guys want to manually override at some stage, does the throttle, upon first touch, automatically move itself to the position where the AutoThrottle has been up to that instant? It shouldn't happen that you get to move around a throttle that's in neutral, if you know what I mean ![]() Ramapriya |
Cap'n Doug, if you're reading this... I recall clearly, on the one occasion I was in an A320 flight deck, that the AutoThrottle's variations weren't reflected in corresponding changes in position of the throttle. So when you guys want to manually override at some stage, does the throttle, upon first touch, automatically move itself to the position where the AutoThrottle has been up to that instant? With the autothrust off, the FADEC measures the lever angle and sets the power accordingly. The autothrust function disconnects if the levers are moved aft of the climb detent. Power is set conventionally with the autothrust disconnected. Over-eager pilots new to the Bus occassionally manage to bump the thrust lever ever so slightly out the detent at inconvenient moments. For example, coming over the middle marker, the autothrust has N1 set at about 1.05 EPR (27% rpm) even though the levers are in the climb detent. Bumping one of the levers just aft of the detent will tell the autothrust to disconnect and the FADEC will measure the angle and assume you want climb power. When trying to land on a wet, short runway with limited visibility and a strong crosswind at max landing weight, having the engines go to climb power is terribly inconvenient. D. |
