Flying IFR with Garmins
Old June 21st 04, 05:51 AM
Robert M. Gary
How do you do that with the 296? How do you program in a radial to fly
to? I don't even see radials on the VORs when I look at it. I haven't
been able to find anything on this in the manual.
There's nothing to stop you using the VOR for course guidance but using the
GPS track readout to ensure that your track matches the VOR radial. Forgive
me if that's very obvious, but I'm always surprised at how many pilots don't
use that aspect of the GPS to take the hard work out of tracking
conventional navaids (particularly on the ILS).
Julian Scarfe
Old June 21st 04, 06:05 AM
Michael 182
I don't know if the 296 has the same capability as the 430, but on the 430
you can define user waypoints as radials and distance from a VOR.
Michael
om...
Forgive
don't
Julian Scarfe
Old June 21st 04, 07:59 AM
Julian Scarfe
Forgive
don't
om...
That's not what I mean. I'm talking about something much more trivial. The
only number on the GPS you need is the TRK readout. Use the NAV's CDI for
course guidance. Best illustrated with an example.
You're on the 250 radial and want to track a 070 course to the ABC VOR. Set
the CDI to 070 and turn the aircraft until the track readout shows 070. The
aircraft will (barring VOR errors) stay on the radial. If it does move,
turn the aircraft to adjust the track.
The GPS doesn't need to know about the existence of VORs or LOCs.
It doesn't help you with programming the GPS for course guidance along a
winding airway, but it's an aspect of GPS utility that many pilots seem to
ignore.
Julian Scarfe
Old June 21st 04, 09:30 PM
Robert M. Gary
Sounds more like the old days of trying to fly an NDB intercept.
Correcting cross winds in your example sounds harder than actually
usnig a VOR. The reason I like airways on the GPS is because while the
clouds are wacking the crap out of you and you're jumping through busy
airspace, you can quickly turn the plane to maintain the center of the
airway. You also don't need to figure out what intersection the airway
turns at next. It sounds like Garmin IFR pilots keep an enroute very
close at hand so they can figure out where all the turns are in the
airway.
-Robert
"Julian Scarfe" wrote in message news:vzwBc.5$AX2.0@newsfe6-win...
ignore.
Julian Scarfe
Old June 22nd 04, 08:04 AM
Julian Scarfe
om...
usnig a VOR.
I think that's only because I laid it out so painfully. How about this
method?
1) At VOR, turn aircraft to track towards next VOR
2) Goto 1.
airway.
Some of the differing perspective in this thread are due to flying in
environments with different demands. I fly in an environment in which the
requirement is almost always to fly direct towards a waypoint rather than
track a centerline, and which is sufficiently busy that making significant
turns to make aggressive radial intercepts is going to raise some eyebrows
at ATC. You fly in an environment in which the choice is to follow the
airway centerlines or hit rock.
All that said, airways on Garmins would be a nice feature.
Julian Scarfe
Old June 22nd 04, 05:37 PM
Robert M. Gary
"Julian Scarfe" wrote in message news:nKRBc.1345$I43.1315@newsfe6-win...
om...
Well, I ordered the unit and am pretty excited about getting it.
Sportys said they should have some in this week to ship. I'm really
excited about putting on the hood and seeing if I can maintain the
blue side up using their turn-coordinator display. I think that could
be a HUGE IFR backup. It will also be cool to take the unit out when
you get to your destination and use it to find your hotel.
-Robert
Old June 27th 04, 05:07 PM
Wyatt Emmerich
I tried to fly under the hood relying on just the Garmin 196 artificial
panel. It's doable, but there were pretty big deviations and I had to
struggle. In real IFR in an emergency. . .I wouldn't want to be in that
situation. However, it is a nice reinforcer that helps me feel more
confident about my instruments in IMC.
om...
om...
than
significant
eyebrows
-Robert
Old June 27th 04, 06:34 PM
Roy Smith
I've tried that experiment once (actually, my student was flying; I was
just looking out the window and kibbitzing). I put us into some unusual
attitudes, and he did the recoveries. He did best if he completely
ignored the GPS pitch information and just used rudder inputs to achieve
zero rate of turn, relying on the elevator trim to take care of pitch.
The result was pretty ugly, but survivable. When he was trying to
control attitude with the synthetic AI and ASI, we just got into larger
and larger pitch oscillations and eventually I had to take control.
Old June 21st 04, 01:09 PM
Dave Butler
If it's like the 196, go to the page displaying the pseudo-HSI and press Menu,
one of the options is "OBS".
Julian Scarfe
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 01:58 PM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 01:53 PM
restarting instrument flying Matthew S. Whiting Instrument Flight Rules 13 November 21st 03 01:04 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 03:04 PM
