I assume you mean the red LED Overvoltage light on the passenger side.
In my 172M, when it came on, it would latch on until the master was turned off and back on again. Is that what you are doing in flight? Or maybe you have an intermittent in the indicator too? FWIW, for a while though we messed with grounds at and around the voltage regulator with some success. In our case the Overvoltage sensor was detecting at too low voltage and was finally replaced. Problem solved. |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
Mooney Low Voltage | [email protected] | Owning | 22 | August 1st 05 01:01 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 03:31 AM |
