Aluminum Paint & Inerior antenna?
Old May 4th 06, 04:32 AM posted to rec.aviation.homebuilt
Default Aluminum Paint & Inerior antenna?
On Wed, 03 May 2006 22:56:14 GMT, "JOHN L. WOLFE"
Will the aluminum paint applied of a fabric plane preclude use of an
interior VHF antenna? Just a simple yes or no would be appreciated. JLW
My Fly Baby is covered with the Stits process and has the antenna inside. Seems
to work fine. But then, it has a wood structure...won't work as well, inside a
steel tube fuselage.
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 07:01 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
