Discus B speeds to fly
Old May 5th 06, 03:28 PM posted to rec.aviation.soaring
Default Discus B speeds to fly
A couple of years ago someone mentioned on this site a list of maximum
efficient speeds based on total weights for the Discus B. I believe
this info was from a club in the UK. I got a copy of that data, but
didn't back it up. A fried hard drive on a new computer toasted it.
Can anyone lead me to that info again?
Old May 6th 06, 02:18 PM posted to rec.aviation.soaring
I think this is the information you are searching.
I printed out this information some time back from
somewhere on the web.
'The Discus (B, CS) polar curve has an inflection,
a bending at a moderate high speed. If you exceed this
speed, you are in a good sense loosing performance.
The sink of the glider is increased more than usual.
To get the maximum of the plane, it is clever to fly
the glider in the speed range till the inflection point.'
Gross Wt(lbs) V Knots
661 82
717 86
772 89
827 92
882 95
937 98
992 101
1047 104
1102 106
1157 109
Regards, SAM
a list of maximum
B. I believe
of that data, but
toasted it.
Discus polar curve at high speeds [email protected] Soaring 12 December 20th 05 01:59 AM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
All Czech built Discus grounded Paul Soaring 0 September 14th 03 02:22 AM
18m Discus Burt Compton Soaring 2 September 8th 03 10:52 AM
