#21
Heavy use of the autopilot is not a problem. Reliance on the autopilot
is absolutely deadly unless you have multiply redundant autopilots with redundant power sources. There's no problem in using the autopilot as long as you're also getting plenty of time in the equivalent flight conditions and are very comfortable in them. Basically, it's OK to use the autopilot any time you would allow a child with emotional problems who is good at playing flight simulator to fly the plane while you watch. The degree of monitoring you should exercise should also be the same. Most pilots already get plenty of experience flying day-VMC in cruise, so using the autopilot in those conditions is no big deal, just as it would be no big deal to let any passenger fly under those conditions. If you're one of those rare people who gets plenty of actual all the time and feel very comfortable in the soup, there's no issue with using it in the soup either. If you shoot so many approaches to minimums in actual that you find the process boring, it's fine to let the autopilot shoot the approach. If you are struggling to get enough actual to stay proficient, and even going under the hood, then why would you give any of that valuable IMC time away to the autopilot? You need that time to keep your skills sharp and hopefully develop them. You're paying for that time. Realize that no GA autopilot on the market has the capability to crosscheck gyros. Any of them can cause the ailerons to go to full deflection smoothly but quickly. As long as you're always in a position where you are confident you can recover from that safely, there's no problem with using the autopilot. If you're in a position where that's not true, why are you there? If the reason is because you can't handle the workload (or are not confident you can handle the workload), fine, turn on the autopilot. Then make it a point to get more training/practice prior to your next IMC flight. Otherwise, all you're doing is increasing the risk. Personally, other than in training, I use the autopilot only in level crusie in VMC, generally on long trips so I can rest. I never use it in IMC because I don't feel like I get enough of it to stay sharp (I go under the hood at least once a year for recurrent) so I'm not going to give any away to the autopilot. If I ever feel like I'm losing it, I'll turn it on. If I had to fly several hours of solid IMC in one day single pilot, I would use it in level cruise, to reduce fatigue and keep myself shart for the higher workload terminal and approach operations. Of course everything I said above is based on the idea of the proficient pilot - someone who could easily pass his instrument checkride in whatever plane he normally flies IFR without needing to prepare for it. This does not describe most instrument rated private pilots I've met. I suspect that has a lot to do with the abysmal safety record of private IMC flight. I've only ever met a few who fit this description, and most of them, even if they don't fly professionally, hold professional ratings. The average instrument rated private pilot I've met was probably at his best as an instrument pilot the day he took his IFR checkride, and would need to practice quite a bit to pass it again. For someone like that, I recommend buying the best, most modern autopilot he can afford and using the it as much as possible throughout the flight, since the autopilot is less likely to screw up than he is - that is assuming he is not willing to practice enough to bring his skills up to par and is unwilling to give up flying IFR, both of which I consider better options. Michael |
Degrading hand-flying skills while using the AP? I've got the solution to
that one! My AP ain't so good. Only roll control and my plane takes rudder action to make anything happen. Flying with the AP takes about as much hand-flying skills than without. However, at least it won't let the roll get away from me, if I were to get distracted for a few seconds. But, if I'm not paying attention, it will be in a skid in no time as it tries to turn but can't without a little rudder help. With the AP on, I can spend more time watching outside or looking at charts and glance at the turn coordinator and altimeter until I resume my normal, full scan. My AP is best when it's calm. Of course, in that situation, the plane flies about the same no hands and no AP. When it's turbulent, I can hand fly better than my AP. But it does lighten the workload until I start feeling seasick with the wandering back and forth. -- ------------------------------- Travis Lake N3094P KPWK "Roy Smith" wrote in message ... In article , "STICKMONKE" wrote: I got my IFR rating 7 months ago. I use the KAP140 autopilot a lot. From climb-out to MDA/DA. I find it really helps in my management of the plane and the IFR flight. I am interested in comments regarding the pros and cons of a heavy use/reliance on the autopilot. The only real con of the autopilot is that it's too easy to become dependent on it and let your hand-flying skills degrade to the point there you're in trouble if George quits. Turn it off every once in a while and hand-fly to stay in shape. Don't just click on the A/P and zone out. Take advantage of the workload reduction it gives you to stay further ahead of the airplane. Pull out those approach charts earlier and brief the approaches you might end up doing. Get on the radio and talk to Flight Watch to find out what the weather is up ahead. Update your flight planning to make sure that re-route ATC gave you didn't eat into your fuel budget too much. And, above all, keep up your instrument scan! If George wigs out and puts you into an unusual attitude, you've still got to recognize it and recover. |
Matt Barrow wrote:
"Sam Spade" wrote in message news:_oM6g.175224$bm6.117405@fed1read04... Matt Barrow wrote: Sam, you're one of the most knowledgable people in here, but your communications (writing) leaves much to be desired by those of us that don't read minds (intentions, contexts). How have I failed to communicate? Notice how many people are completely confounded by what you write. You have to write to _the audience_, not to yourself. It is tough to know the audience in a forum like this. I work in an environment where a lot of this stuff is a given. I guess here it could end up being article writing. That is not what these Usenet forums are about. Also, I have been accused by some here of being an "AH jail house lawyer" so it is a no-win situation in some ways. |
"STICKMONKE" wrote in
: I got my IFR rating 7 months ago. I use the KAP140 autopilot a lot. From climb-out to MDA/DA. I find it really helps in my management of the plane and the IFR flight. I am interested in comments regarding the pros and cons of a heavy use/reliance on the autopilot. PRO: A good autopilot will typically fly an approach as well or better than a person. Also, it allows the pilot to have time to manage the other aspects of the flight. CON: Autopilots can fail. If you exclusively rely on the autopilot to fly the plane, you quickly become the passenger, not the pilot. You need to stay attentive and proficient enough that if the autopilot fails, you don't kill yourself. |
Brien K. Meehan wrote:
The biggest "con" I've observed is that it sometimes gives the passengers the impression that you're not working hard enough. I actually had a passenger say to me, "What am I paying you all this money for? This is easy, you're just pressing buttons! I could do that myself!" You say "come on up, and do it yourself". |
How true. My KFC225 has failed about a dozen times in 4 years, most of
them without any indication. Yuck. I knew they were unreliable. I didn't know they were THAT unreliable. On one occassion the red Disconnect button failed (this was after the AP drove the ailerons to full deflection) so the master disconnect had to be used. This is the sort of thing I worry about when it comes to autopilots. Ailerons go hard over at the wrong time, and that's all she wrote. All this makes a complete joke of TSO-129 certification, which obviously has no concept of software/hardware quality or reliability. Eventually, you will come to accept that FAA certification only adds cost, not value or safety. It's only obvious in those areas where you know what's going on. In areas where you are ignorant, FAA rules can seem like a good idea. They never are. I also hand fly a proportion of approaches, but not all because flying them (especially an ILS) with the AP is also something that needs to be done with the correct procedure and that needs practice too. You know, I've shot a lot of approaches in IMC, including more than one ILS to real mins (less than 300 ft and less than a mile vis) including one in a plane I only got into that morning, with an HSI that had failed and a compass that was unreadable due to a bad light. But the ILS approach that scared me most was in VMC - with a Century 2000 A/P flying it. It never seriously occurred to me that I would roll the plane over just because I was flying with a partial panel at night in low IMC in an unfamiliar airplane - I always had confidence that it might not be pretty, but I would either put it on the runway right side up or make a passable miss. But I knew for a fact that uncommanded hard rolls are part of life with an autopilot - and frankly my enthusiasm for low altitude aerobatics on instruments is very low, even in good VMC. I certainly did not have confidence that I would successfully recover from such an uncommanded roll - especially if the disconnect were to fail as well, necessitating fumbling for the rarely used master disconnect. At 300 AGL my fear got the best of me, I switched off the AP, and completed the approach by hand - and again, this was VMC. Risking an uncommanded hard roll at 300 AGL in IMC strikes me as a last-resort kind of option. I know the airlines do it - but they're doing it with substantially better equipment that is maintained far more meticulously. I have to ask - what was your altitude loss when the ailerons went hard over and the A/P disconnect failed? What is your logic behind having it engaged when you are lower than that (assuming you do have it engaged then)? Personally, you can't pay me enough to have the autopilot engaged on an actual IMC approach. I quite agree with you that the procedures involved require practice, and I do practice with it - under the hood with a safety pilot I can really trust, and never below 800 AGL. Michael |
#28
![]() "Peter" wrote: CON: Autopilots can fail. If you exclusively rely on the autopilot to fly the plane, you quickly become the passenger, not the pilot. You need to stay attentive and proficient enough that if the autopilot fails, you don't kill yourself. How true. My KFC225 has failed about a dozen times in 4 years, most of them without any indication. My buddy has a KFC225 with a similarly dismal history. The avionics shop tells him this is not unusual for that model. Not usual!!! My S-Tec 50, a 2-axis, rate-based unit, has operated with only one glitch-- a bad switch--in 700+ hours since installation. It's a much simpler piece of gear, not as precise or as smooth in turbulence as the KFC225, but I'll take reliability over capability every time. -- Dan C-172RG at BFM |
#29
bad switch--in 700+ hours since installation. A friend of mine has a 50 in his Bo, and it hasn't fared as well as yours. If went 'dead' - meaning no action on aileron control and no annunciation - multiple times before the problem was resolved. Usually by the time he got it to the A/P shop it was working again, and the shop could not figure out what was wrong. Eventually it died for good. It was a bad motor in the roll servo. On the flip side, I once instructed a student in an Ovation who told me his KFC-225 never hiccupped. Michael |
#30
![]() "Michael" wrote in message ups.com... My S-Tec 50, a 2-axis, rate-based unit, has operated with only one glitch-- a bad switch--in 700+ hours since installation. A friend of mine has a 50 in his Bo, and it hasn't fared as well as yours. If went 'dead' - meaning no action on aileron control and no annunciation - multiple times before the problem was resolved. Usually by the time he got it to the A/P shop it was working again, and the shop could not figure out what was wrong. Eventually it died for good. It was a bad motor in the roll servo. On the flip side, I once instructed a student in an Ovation who told me his KFC-225 never hiccupped. Michael Some autopilot failures are very subtle. I was shooting a coupled ILS to minimums with a King autopilot in a Mooney. After capturing the glideslope, I noticed the rate was about 75'/min more than I was used to. As we got closer to DH, the DME was still showing about 2 miles to the airport. I leveled at DH, and while motoring along 200' above the houses, I tapped the Vor/loc. The GS needle snapped to the top of the case. It was "stuck" centered, and the autopilot was literally flying the needle. Iron Mike, indeed. Al |
Experimental Catagory: Pros and Cons? | [email protected] | Soaring | 18 | April 16th 06 10:56 PM |
Long Tow Rope Pros & Cons | chris | Soaring | 7 | December 10th 03 02:30 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
