o and io engines
Old May 6th 06, 07:35 PM posted to rec.aviation.owning
Default o and io engines
It appears the 200 HP injected engines all have tuned induction systems
for a little more power, too. And isn't here some point where they use
the angle valve cylinders to get a better combustion chamber shape? I
couldn't spot it though.
An interesting list. Think of the documentation there must be at
Lycoming to support this many certified engines!
Old May 6th 06, 09:32 PM posted to rec.aviation.owning
A 180 hp O-360 Lycoming has parallel valves, the 200 hp IO-360 has
angle valves. With the 540's the typical cut-off for parallel valve
heads is 250 hp.
Indeed.
TC
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
