Cabin Class?
Old May 7th 06, 04:40 AM posted to rec.aviation.piloting
Default Cabin Class?
"Frank Ch. Eigler" wrote
Perhaps the main operational difference is whether or not the cabin is
pressurized.
The one that makes the most sense to me, is the one about everyone entering
though the same door, and going forward between the seats, to get to the
pilot's seats.
Jim in NC
Old May 7th 06, 04:51 AM posted to rec.aviation.piloting
pilot's seats.
So a 747 is not cabin class?
-Robert
Old May 7th 06, 05:16 AM posted to rec.aviation.piloting
OK, I'll bite. How does one get to the pilot seats in a 747?
Jim in NC
Old May 7th 06, 06:00 AM posted to rec.aviation.piloting
Years and years of training and experience.
"Morgans" wrote in message
747?
| Jim in NC
Old May 7th 06, 06:09 AM posted to rec.aviation.piloting
Starting from the ground, you climb two flights of access steps to reach the
main deck door. Once inside the craft, you climb a third flight to reach
the upper deck, turn right (usually), pass the galley, heads, emergency
egress door, and enter the flight deck. Variations on the theme if you're
flying the freighter version, but the structure's about the same. I think
it probably qualifies as cabin-class.
Old May 7th 06, 06:50 AM posted to rec.aviation.piloting
the main deck door. Once inside the craft, you climb a third flight to
reach the upper deck, turn right (usually), pass the galley, heads,
emergency egress door, and enter the flight deck. Variations on the theme
if you're flying the freighter version, but the structure's about the
same. I think it probably qualifies as cabin-class.
If you enter like the passengers, from the jetway, how do you get there?
Even this aside, a little common sense says that a 747 is cabin class,
without having to look at other definitions? g
Jim in NC
Old May 7th 06, 05:09 PM posted to rec.aviation.piloting
Up one flight. The cockpit is accessed only from the upper deck.
Old May 7th 06, 06:42 PM posted to rec.aviation.piloting
Just like the upper deck passengers, huh?
Yep, the 747 IS a cabin class, then! g
Jim in NC
Old May 7th 06, 06:16 AM posted to rec.aviation.piloting
Through a choice of several doors. Everyone does not enter the same
door unless the airport is very, very old and unable to handle multiple
doors.
Old May 7th 06, 06:57 AM posted to rec.aviation.piloting
doors.
The pilot does not have a door that goes directly to the cockpit, does it?
I'm starting to think that everyone here has lost every semblance of common
sense! g
Perhaps the "able to walk around " definition may work better.
Anyone got an exception to that one? ;-o)
Jim in NC
Class E or Class G - another one of those that makes you go 'hmmmmm' JT Piloting 10 February 27th 06 06:41 PM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
