![]() "Robert M. Gary" wrote in message ups.com... OK, I'll bite. How does one get to the pilot seats in a 747? Through a choice of several doors. Everyone does not enter the same door unless the airport is very, very old and unable to handle multiple doors. The pilot does not have a door that goes directly to the cockpit, does it? I'm starting to think that everyone here has lost every semblance of common sense! g Perhaps the "able to walk around " definition may work better. Anyone got an exception to that one? ;-o) -- Jim in NC |
![]() "Morgans" wrote in message The pilot does not have a door that goes directly to the cockpit, does it? No, not for access. There are, however, two specific emergency egress points directly from the cockpit. |
![]() "John Gaquin" wrote No, not for access. There are, however, two specific emergency egress points directly from the cockpit. That is interesting. Where are they, and how do they work? -- Jim in NC |
![]() "Morgans" wrote in message news:jlq7g.84 That is interesting. Where are they, and how do they work? One is a small door on the right side equipped with a slide. When deployed, the slide is very long and narrow, and often, I'm told, gets blown askew, rendering it unusable. Even when used as designed, I'm told, it is a very long run, resulting in a fairly high speed descent and a strong probability of skin burns and other injuries. The other is a roof hatch, slightly left of centerline and directly behind the FE, used in conjunction with a body harness and inertia reel. Climb out and just slide on down the side, trusting that the inertia reel will slow your descent at the bottom as designed. If the aircraft is sitting on its belly, sans gear, its about a 35 foot drop from the roof to the ground. My guess is that the real trick would be to avoid all the probes, sensors, and other pieces of metal projecting from the side of the craft on the way down. Ouch! |
Class E or Class G - another one of those that makes you go 'hmmmmm' | JT | Piloting | 10 | February 27th 06 06:41 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
