Matt Whiting wrote: So if the AIM says that handhelds are not authorized for IFR navigation, there must be a rule somewhere, right? Not necessarily. The AIM is meant to contain information that is "good practice", not just regulatory information. The FARs are for regulation. If the AIM was also regulatory and only contained information already in the FARs, what would be the point of it? Yes, it's true that the AIM is "not regulatory". We all learned that and regurgitated it back on some private pilot knowledge test long ago. But, just because it doesn't cite chapter and verse from 14 CFR is no reason to completely ignore what it says. The paragraph in question is 1-1-19-d-1-(a): 1. Authorization to conduct any GPS operation under IFR requires that: (a) GPS navigation equipment used must be approved in accordance with the requirements specified in Technical Standard Order (TSO) TSO-C129, or equivalent, and the installation must be done in accordance with Advisory Circular AC 20-138, Airworthiness Approval of Global Positioning System (GPS) Navigation Equipment for Use as a VFR and IFR Supplemental Navigation System, or Advisory Circular AC 20-130A, Airworthiness Approval of Navigation or Flight Management Systems Integrating Multiple Navigation Sensors, or equivalent. Equipment approved in accordance with TSO-C115a does not meet the requirements of TSO-C129. Visual flight rules (VFR) and hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference. During IFR operations they may be considered only an aid to situational awareness. While the AIM may not be regulatory, it also doesn't lie. When a simple declaratory statement is made such as, "hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference", it's a pretty good guess that there is some regulation, somewhere that backs that up. Anybody who feels confident enough that handheld GPS is good enough for IFR is welcome to invite an FSDO guy to ride along with you for an inspection with a handheld as your sole means of IFR navigation outside of DR, vectors, celestial, and a ham sandwich. See how far you get. Then please post about it so we can all share in your experience. Until that time, all this talk about how the AIM is not regulatory and how it's OK to fly IFR with a handheld is just a lot of masturbation. |
![]() "Roy Smith" wrote in message ... Yes, it's true that the AIM is "not regulatory". We all learned that and regurgitated it back on some private pilot knowledge test long ago. But, just because it doesn't cite chapter and verse from 14 CFR is no reason to completely ignore what it says. The paragraph in question is 1-1-19-d-1-(a): 1. Authorization to conduct any GPS operation under IFR requires that: (a) GPS navigation equipment used must be approved in accordance with the requirements specified in Technical Standard Order (TSO) TSO-C129, or equivalent, and the installation must be done in accordance with Advisory Circular AC 20-138, Airworthiness Approval of Global Positioning System (GPS) Navigation Equipment for Use as a VFR and IFR Supplemental Navigation System, or Advisory Circular AC 20-130A, Airworthiness Approval of Navigation or Flight Management Systems Integrating Multiple Navigation Sensors, or equivalent. Equipment approved in accordance with TSO-C115a does not meet the requirements of TSO-C129. Visual flight rules (VFR) and hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference. During IFR operations they may be considered only an aid to situational awareness. While the AIM may not be regulatory, it also doesn't lie. When a simple declaratory statement is made such as, "hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference", it's a pretty good guess that there is some regulation, somewhere that backs that up. Anybody who feels confident enough that handheld GPS is good enough for IFR is welcome to invite an FSDO guy to ride along with you for an inspection with a handheld as your sole means of IFR navigation outside of DR, vectors, celestial, and a ham sandwich. See how far you get. Then please post about it so we can all share in your experience. Until that time, all this talk about how the AIM is not regulatory and how it's OK to fly IFR with a handheld is just a lot of masturbation. You don't have to make an actual flight, a hypothetical will work just as well for this purpose. I did just that some 6 1/2 years ago. The message below was originally posted on December 4th, 1999, in this forum in the thread "Going direct to an intersection": I sent the following message to eleven of the fourteen FSDOs in the Great Lakes Region: "I have a question regarding the use of a handheld GPS receiver during IFR enroute flight. Let's say I file from MBS direct to SEA in my BE36/A. My Bonanza has two nav/coms, ADF, GS receiver, DME, marker beacon receiver, transponder, encoder, and an autopilot. But I intend to use my handheld GPS receiver for enroute navigation, which I have previously determined will not cause interference with the navigation or communication system on my airplane. ATC clears me as filed and I proceed on my merry way direct to Seattle. Does this operation violate any FAR?" I received E-mail responses from four FSDOs, I have changed only identification of offices and individuals. From FSDO "A": Dear Steven, Thank you for your question concerning GPS Navigation. You must comply with the limitations of your GPS. There isn't a handheld alive that is approved for IFR enroute or terminal navigation, so to answer your question, no, you cannot use the GPS for anything during your IFR Flight. I recommend that you review your GPS Manual provided by the factory. I hope this answers your question, Steven. Sincerely, John Doe FSDO "A" Dear Mr. Doe, Thank you for your prompt response. My question and scenario are completely hypothetical, I don't own a GPS (or a Bonanza, unfortunately), so I have no GPS manual to review. But I'm afraid you didn't answer my question; I wanted to know what regulation, if any, was being violated in the scenario. What FAR prohibits the use of a handheld GPS during enroute IFR flight? What regulation requires me to comply with the limitations of my GPS? What regulation requires the GPS, or any other nav system for that matter, to be approved for IFR enroute flight? Sincerely, Steven P. McNicoll No further messages were received from FSDO "A". From FSDO "B": Dear Steven, Does this operation violate any FAR? FAR - "singular" NO, "pural" YES or only if the FAA accident investigation team has to pry it out of your cold hands at the site of the crash, otherwise no one will know. Sorry, but I just can't pass up to opportunity to put a little humor into my work. Seriously here is the"spin" that most FAA types put on the answer to this question. Hand held GPS units are not approved for flight into IFR conditions. Panel mount GPS units may be certified for enroute portions only, or the high dollar units that meet all the FAA's certification requirements can be used for enroute and approaches, these units are also panel mounted units. Further, the panel mounted units are to be installed by properly certificated technicians and the equipment list, weight and balance of the aircraft should reflect the additional equipment. (No the FAA doesn't make it easy.) So in the case of a handheld GPS for IFR flight, the unit is not certified for that use and is not authorized by FARs. Richard Roe FSDO "B" Dear Mr. Roe, Thank you for your response. I appreciate humor as much as anyone, but I don't see how we arrived "at the site of the crash". This operation presents no undue hazard. I'm aware that hand held GPS units are not approved for flight into IFR conditions, and that GPS installations CAN be approved for IFR flight. But after an extensive search, I cannot find any regulation REQUIRING that GPS have that approval in order to be used during IFR enroute flight. You say that this operation would violate several FARs, could you cite them please? Sincerely, Steven P. McNicoll No further messages were received from FSDO "B". From FSDO "C": Dear Steve, I am forwarding your question to our Avionics Inspector; Apollo Garmin. This is in his area of expertise. Thank you for using our website. Guy Fawkes FSDO "C" Steve, I got together with our Avionics Inspector and have an answer for you. "A PORTABLE GPS CANNOT BE APPROVED IN THE AIRCRAFT FOR INSTRUMENT FLIGHT RULES (IFR) OR VISUAL FLIGHT RULES UNLESS THE COMPLETE SYSTEM IS INSTALLED AND EVALUATED IN ACCORDANCE WITH THE INTERIM POLICY GUIDANCE DATED MARCH 20, 1992, AS AMENDED, PERTAINING TO THE APPROVAL OF GPS EQUIPMENT." VFR only not IFR. Let me know if we can be of any further assistance. Guy Fawkes FSDO "C" Dear Mr. Fawkes, Thank you for your response. I understand that a portable GPS receiver cannot be approved for IFR flight, but what regulation prohibits a non-approved GPS receiver from being used during IFR flight? Steven P. McNicoll Steven, Per my Avionics Inspector the following 14CFR Paragraph answers your question (specifically para (b)(5): ---------------------------------- 91.21 _ Portable Electronic Devices. (a) Except as provided in paragraph (b) of this section, no person may operate, nor may any operator or pilot in command of an aircraft allow the operation of, any portable electronic device on any of the following U.S.-registered civil aircraft: (1) Aircraft operated by a holder of an air carrier operating certificate or an operating certificate; or (2) Any other aircraft while it is operated under IFR. (b) Paragraph (a) of this section does not apply to- (1) Portable voice recorders; (2) Hearing aids; (3) Heart pacemakers; (4) Electric shavers; or (5) Any other portable electronic device that the operator of the aircraft has determined will not cause interference with the navigation or communication system of the aircraft on which it is to be used. (c) In the case of an aircraft operated by a holder of an air carrier operating certificate or an operating certificate, the determination required by paragraph (b)(5) of this section shall be made by that operator of the aircraft on which the particular device is to be used. In the case of other aircraft, the determination may be made by the pilot in command or other operator of the aircraft. ------------------------ Guy Fawkes FSDO "C" Dear Mr. Fawkes, FAR 91.21(b)(5) permits the operation of any portable electronic device, other than a portable voice recorder, hearing aid, heart pacemaker, or electric shaver, that the operator of the aircraft has determined will not cause interference with the navigation or communication system of the aircraft on which it is to be used. Recall that in my scenario I stated that I had previously determined that my handheld GPS receiver does not cause interference with the navigation or communication system on my airplane. It seems to me that I have complied with FAR 91.21 to the letter. Steven P. McNicoll No further messages were received from FSDO "C" From FSDO "D": Dear Mr. Steven P. McNicoll In response to your question, does this operation violate any FAR? Yes, it does. You may file IFR as a (slant) /A. The handheld GPS is not acceptable as RNAV and is contrary to: 14 Code of Federal Regulations(CFR), Part 21 sub part K and O. 14 CFR 23.1307 14 CFR 23.1309(b) 14 CFR 91.21 14 CFR 91.205 These are referenced in FAA pamphlet FAA-P-8000-3. Thank you for your interest in aviation safety. Please call if you have any questions, (987) 654-3210. Inspector John Smith FSDO "D" Dear Mr. Smith, Thank you for your response. Please see below for additional questions and comments. Steven P. McNicoll Dear Mr. Steven P. McNicoll In response to your question, does this operation violate any FAR? Yes, it does. You may file IFR as a (slant) /A. The handheld GPS is not acceptable as RNAV What regulation specifies what is acceptable and what is not acceptable as RNAV? and is contrary to: 14 Code of Federal Regulations(CFR), Part 21 sub part K and O. How can that be? A handheld GPS is not a part or an appliance, it is not installed in or attached to the aircraft. To my knowledge there is no regulation that requires a GPS receiver to comply with a TSO. 14 CFR 23.1307 I don't see how Part 23 is applicable at all, this does not involve any change to a type certificate. A handheld GPS receiver is not equipment necessary for the airplane to operate at the maximum operating altitude or in the kinds of operations and meteorological conditions for which it is certified. Why would it need to be included in the type design? Given that it is a portable device, how could it be included in the type design? 14 CFR 23.1309(b) 14 CFR 23.1309(b) refers to installed equipment, but a handheld GPS is not installed equipment. 14 CFR 91.21 Recall that I had previously determined my handheld GPS does not cause interference with the navigation or communication system on my airplane. 14 CFR 91.205 How is this regulation being violated? My aircraft contains all of the instruments and equipment specified 14 CFR 91.205 for IFR operations, and those instruments and items of equipment are in operable condition. These are referenced in FAA pamphlet FAA-P-8000-3. How may I obtain this pamphlet? Thank you for your interest in aviation safety. Please call if you have any questions, (987) 654-3210. Inspector John Smith FSDO "D" Dear Mr. Steven P. McNicoll, Your Bonanza was probably built in accordance with 14 CFR 23 (FAR 23), and if you intend to use the aircraft for IFR flight, it should have the equipment specified in 14 CFR 91.205. The hand-held GPS is not included in 91.205 because it is not approved for IFR flight. In fact no GPS systems are mentioned in 91.205, any GPS system that is approved for IFR use and is going to be permanently installed in an aircraft needs to be approved for that specific make and model of aircraft. The FAA will not approve a GPS installation for IFR use if the GPS unit wasn't manufactured to the minimum specifications of Technical Standard Order-129A (TSO-C129A). At this point in time, no hand-held GPS unit meets the minimum specifications spelled out in TSO-C129A. TSO-C129A specifies the criteria by which an installed GPS system, intended for certification in IFR operations, will be built. A hand-held, portable GPS is not built to these specifications. The pamphlet(FAA-P-8000-3) we previously mentioned is available at "http://gps.faa.gov/Library/gps1.pdf" on the Internet. In FAA-P-8000-3, chapter 1, page 1-7, the first paragraph under section 1.3. Hand-held or portable GPS receivers may be used as a supplement to Visual Flight Rules only. If you have any further questions you should contact your local F. A. A. FSDO for more information. We are an Air Carrier Office and deal with the airlines. Your local FSDO will have Inspectors who deal with Part 91 operators. From the address on your e-mail it appears that you are in the Milwaukee FSDO area. There phone number is (414) 486-2920. They also have an Internet web-site. The address is: "http://www.faa.gov/fsdo/mke". Thank You, Inspector John Smith FSDO "D" Dear Mr. Smith, Thank you for your response. Please see additional comments and questions below. Sincerely, Steven P. McNicoll Dear Mr. Steven P. McNicoll, Your Bonanza was probably built in accordance with 14 CFR 23 (FAR 23), and if you intend to use the aircraft for IFR flight, it should have the equipment specified in 14 CFR 91.205. Please understand that this is a completely hypothetical scenario, I do not own a Bonanza. My hypothetical Bonanza contains all of the instruments and equipment specified in 14 CFR 91.205. The hand-held GPS is not included in 91.205 because it is not approved for IFR flight. If my aircraft contains all of the instruments and equipment specified in 14 CFR 91.205, then I am in compliance with that regulation. What regulation prevents me from using a device that is not mentioned in 91.205? In fact no GPS systems are mentioned in 91.205, any GPS system that is approved for IFR use and is going to be permanently installed in an aircraft needs to be approved for that specific make and model of aircraft. The FAA will not approve a GPS installation for IFR use if the GPS unit wasn't manufactured to the minimum specifications of Technical Standard Order-129A (TSO-C129A). At this point in time, no hand-held GPS unit meets the minimum specifications spelled out in TSO-C129A. TSO-C129A specifies the criteria by which an installed GPS system, intended for certification in IFR operations, will be built. A hand-held, portable GPS is not built to these specifications. I understand that, but I can find no regulation that requires a GPS receiver that is used for IFR enroute flight to be permanently installed in the aircraft or to meet the specifications of TSO C-129a. The pamphlet(FAA-P-8000-3) we previously mentioned is available at "http://gps.faa.gov/Library/gps1.pdf" on the Internet. In FAA-P-8000-3, chapter 1, page 1-7, the first paragraph under section 1.3. Hand-held or portable GPS receivers may be used as a supplement to Visual Flight Rules only. I don't believe that pamphlet has the force of law. The FAA publishes the Federal Aviation Regulations (FARs) to make readily available to the aviation community the regulatory requirements placed upon them. If a GPS receiver that did not meet the standards of TSO C-129a was not to be used during IFR flight, then there would be an FAR that required any GPS receiver used during IFR flight to meet that standard. If you have any further questions you should contact your local F. A. A. FSDO for more information. We are an Air Carrier Office and deal with the airlines. Your local FSDO will have Inspectors who deal with Part 91 operators. From the address on your e-mail it appears that you are in the Milwaukee FSDO area. There phone number is (414) 486-2920. They also have an Internet web-site. The address is: "http://www.faa.gov/fsdo/mke". Thank You, Inspector John Smith FSDO "D" I have contacted eleven of the fourteen FSDOs in the Great Lakes Region. I gave them all this same scenario and asked them all the same question. Seven of them responded, all stating that navigation by handheld GPS receiver during enroute flight under IFR is illegal, but none of them could cite any law that would be violated by such use! It seems to me that if it is illegal, then there must be a regulation that is being violated; if there is no regulation being violated, then it is not illegal. Sincerely, Steven P. McNicoll No further messages were received from FSDO "D". |
![]() "Steven P. McNicoll" writes: The hand-held GPS is not included in 91.205 because it is not approved for IFR flight. If my aircraft contains all of the instruments and equipment specified in 14 CFR 91.205, then I am in compliance with that regulation. [...] Perhaps your scenario is self-contradictory. 91.205.d.2 appears to require "... navigational equipment appropriate to the ground facilities to be used ...". If you're filing to a far-away ground facility (far away airport or navaid) that you don't have appropriate nagivational equipment (super-duper VOR receiver or substitutable GPS) to guide yourself to, you may be in violation right there. It may be interesting to other readers that in other parts of the world, it is sometimes required to carry sufficient *extra* navigational equipment that would enable an instrument letdown to an alternate in the case of a failure of any one. - FChE |
![]() "Frank Ch. Eigler" wrote in message ... Perhaps your scenario is self-contradictory. 91.205.d.2 appears to require "... navigational equipment appropriate to the ground facilities to be used ...". If you're filing to a far-away ground facility (far away airport or navaid) that you don't have appropriate nagivational equipment (super-duper VOR receiver or substitutable GPS) to guide yourself to, you may be in violation right there. I'm in full compliance with FAR 91.205 in that regard, I have two fully functional VOR receivers aboard. |
![]() "Steven P. McNicoll" writes: Perhaps your scenario is self-contradictory. 91.205.d.2 appears to require "... navigational equipment appropriate to the ground facilities to be used ...". [...] I'm in full compliance with FAR 91.205 in that regard, I have two fully functional VOR receivers aboard. But those ordinary VOR receivers will do approximately nothing for you, when flying direct to a faraway VOR they cannot pick up yet, thus they are not "appropriate to the ground facilities to be used". - FChE |
On 05/08/06 10:39, Frank Ch. Eigler wrote:
"Steven P. McNicoll" writes: Perhaps your scenario is self-contradictory. 91.205.d.2 appears to require "... navigational equipment appropriate to the ground facilities to be used ...". [...] I'm in full compliance with FAR 91.205 in that regard, I have two fully functional VOR receivers aboard. But those ordinary VOR receivers will do approximately nothing for you, when flying direct to a faraway VOR they cannot pick up yet, thus they are not "appropriate to the ground facilities to be used". - FChE I think the point is that no ground facilities are being used for the direct-to part of the flight. You're assuming that he is using the VOR receiver to go direct-to a VOR 1000 miles away, but he's already said that he was using the GPS. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Frank Ch. Eigler" wrote in message ... But those ordinary VOR receivers will do approximately nothing for you, when flying direct to a faraway VOR they cannot pick up yet, thus they are not "appropriate to the ground facilities to be used". They're fully appropriate when I'm actually using them. |
![]() "Steven P. McNicoll" wrote: But those ordinary VOR receivers will do approximately nothing for you, when flying direct to a faraway VOR they cannot pick up yet, thus they are not "appropriate to the ground facilities to be used". They're fully appropriate when I'm actually using them. This rather Clintonian argument ("to be used" vs "I wish to use") opens the door to kooky things like flying an ILS with a handheld GPS. ("Sure I have one on board, but the FARs don't say I have to USE it ...."), or ignoring monitoring instruments ("my engine oil temp may have been at redline, but I don't have to LOOK at it"). A 91.13 citation would fit perfectly, should something go wrong. - FChE |
On Mon, 08 May 2006 08:59:03 -0400, Roy Smith wrote:
While the AIM may not be regulatory, it also doesn't lie. When a simple declaratory statement is made such as, "hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference", it's a pretty good guess that there is some regulation, somewhere that backs that up. As Steven has so often pointed out, nobody has been able to cite that regulation. I applaud John Deakin and Steven for challenging commnonly held assumptions they believe to be wrong, even if they do it in their own particular style. It's one of the ways in which we learn. Anybody who feels confident enough that handheld GPS is good enough for IFR is welcome to invite an FSDO guy to ride along with you for an inspection with a handheld as your sole means of IFR navigation outside of DR, vectors, celestial, and a ham sandwich. See how far you get. Then please post about it so we can all share in your experience. Until that time, all this talk about how the AIM is not regulatory and how it's OK to fly IFR with a handheld is just a lot of masturbation. No it's not. Chances are that you'd get a FSDO guy who assumes that the AIM statement is based on a FAR. It's not worth the hassle or expense of an airplane flight to try to persuade this one guy otherwise. What you do in the real world is up to you. Personally, on reflection, I'd use the GPS to get the heading I want to fly, then ask ATC for that vector. I believe the Direct routing is legal, but I see no reason to stir up a possible hornet's nest in the air when the alternative is so simple. Tim. |
HANDHELD RADIO | [email protected] | Soaring | 22 | March 17th 16 03:16 PM |
Navcom - handheld VS panel ? | [email protected] | Home Built | 10 | October 31st 05 08:08 PM |
GPS Handheld | Kai Glaesner | Instrument Flight Rules | 2 | November 16th 04 04:01 PM |
Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 03:33 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
