IFR use of handheld GPS
Old May 9th 06, 03:48 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS
"Steven P. McNicoll" wrote:
"Ron Lee" wrote in message
You have neither answered my questions nor done what I suggested. Why
not?
Your "questions" were actually one question. I answered them when I said
anything can malfunction. I'll do what you suggested after you send me
money to pay for the flight.
I'm left to conclude you cannot answer my question.
I'm left to conclude that you are not a pilot to entrust with anyone's
life. Do you need a reg to tell you not to fly into thunderstorms?
Do you need a reg to tell you not to fly into known icing conditions
with an aircraft not approved for it?
Do as you wish. Just don't take anyone with you should you fall prey
to Darwinism.
Ron Lee
Old May 9th 06, 04:09 PM posted to rec.aviation.ifr
life.
Upon what do you base that conclusion?
Nope. Do you?
Nope do you?
to Darwinism.
Do you see any similarity at all between flying into thunderstorms or flying
into known icing conditions with an aircraft not approved for it and
enroute IFR navigation by handheld GPS in US controlled airspace?
Old May 9th 06, 09:01 PM posted to rec.aviation.ifr
to Darwinism.
Ron Lee
So you now assume that navigating direct with a handheld GPS is
dangerous? Why is that? I can understand why people disagree whether
its "legal" or not, but safety? And pushing RAIM won't convince me.
I've seen almost as many IFR panel mount units give unreliable data or
drop out unexpectedly as I have seen that happen in handhelds. And
just a couple of days ago someone related the story in another thread
regarding his glideslope instrumentation going bad and causing the
autopilot, on a coupled ILS, to reach DH some two miles early. I'd
call that a safety issue.
Old May 10th 06, 12:13 AM posted to rec.aviation.ifr
Bob Noel wrote:
If you don't understand RAIM, then why bother asking about safety?
I didn't say I didn't understand RAIM. I just don't care. I am not
convinced that it is necessary for enroute navigation that can be
"safely" accomplished with 30-year old VOR receivers.
My question is how is using a handheld GPS while in radar contact
unsafe? Or more to the point, how is it less safe than using a
combination of radar vectors and VORs? Is "fly heading 320, direct XYZ
VOR when able" any safer?
Sure a panel-mount TSOed IFR approved GPS is supposed to tell you when
its got an inconsistent solution of your position, and therefore it is
more reliable than a handheld, but we're not comparing panel mounts
with handhelds. We're comparing ADF/VOR navigation with handheld GPS.
Peter
Old May 10th 06, 01:08 AM posted to rec.aviation.ifr
Bob Noel wrote:
It seems to me that you've already made up your mind wrt safety.
I have an opinion. That's not the same as being closed-minded. I'm
happy to hear the other side of the argument if you'd care to write it
down instead of just snapping back at me with one-liners.
Old May 10th 06, 03:45 AM posted to rec.aviation.ifr
"Bob Noel" wrote in message
Nothing in his message suggested he doesn't understand RAIM.
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
