Maule Driver wrote:
I'll second that regarding corrosion. Cost me a gear rebuild and later, after repositioning the exit to the bottom of the gear door, I believe that some was being drawn into the rudder hinge area (LS-6) but can't confirm that. Careful thought needs to be made in terms of positioning the exit - it needs to be in a low pressure area and positioned so that it doesn't then risk contaminating corrodible parts. Our Nimbus 2c has the exit in centre of the lower starboard quadrant of the cockpit 'bulge', just aft of the widest point (i.e. low pressure area). The only potential metal in that flow is the tail wheel assembly. Not only have we not had any problems there, there is no trace of dried urine on the skin of the aircraft. Whilst I have used bags in other aircraft when cross country instructing, having a plumbed in system makes for much more comfortable flying. As for catheters, I (and no pilot I know of here in Aus) uses the adhesive tape that comes with the external catheters (known locally and rather politically incorrectly as 'Irish condoms'). They seal perfectly when rolled far enough down the penis. The only problems I have experienced in removing them have revolved around rolling pubic hair into them during the removal. I have decided that a judicious shave is the answer to that problem! -- Robert Hart +61 (0)438 385 533 http://www.hart.wattle.id.au |
Regarding 'low pressure' area. My six had been rather crudely modified
by the previous owner with a waste tube that exited in front of the gear door area. Whether or not that particular spot was low pressure or not didn't seem to matter. My personal plumbing in those years had positive pressure at the source. The problem was that the gear well, despite sealing, was a low pressure area and was sucking corrosive urine up into the entire gear mechanism. Obviously an exit anywhere in front of the gear well would be ill advised on that ship. After a rebuild, we mounted the tube on the bottom of a gear door so I could open the gear when needed and extend the discharge point 5 inches or so away from the fuse. Did the aerodynamics work for that? Probably. That was about as much engineering as I was willing to do to facilitate a pee. If 'ol Foureyes cycled his gear while above you in the gaggle, you weren't one of his favorites. Robert Hart wrote: Maule Driver wrote: I'll second that regarding corrosion. Cost me a gear rebuild and later, after repositioning the exit to the bottom of the gear door, I believe that some was being drawn into the rudder hinge area (LS-6) but can't confirm that. Careful thought needs to be made in terms of positioning the exit - it needs to be in a low pressure area and positioned so that it doesn't then risk contaminating corrodible parts. Our Nimbus 2c has the exit in centre of the lower starboard quadrant of the cockpit 'bulge', just aft of the widest point (i.e. low pressure area). The only potential metal in that flow is the tail wheel assembly. Not only have we not had any problems there, there is no trace of dried urine on the skin of the aircraft. Whilst I have used bags in other aircraft when cross country instructing, having a plumbed in system makes for much more comfortable flying. As for catheters, I (and no pilot I know of here in Aus) uses the adhesive tape that comes with the external catheters (known locally and rather politically incorrectly as 'Irish condoms'). They seal perfectly when rolled far enough down the penis. The only problems I have experienced in removing them have revolved around rolling pubic hair into them during the removal. I have decided that a judicious shave is the answer to that problem! |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
