Scared of mid-airs
Old May 11th 06, 03:05 PM posted to rec.aviation.piloting,rec.aviation.student
Default Scared of mid-airs
Double bass is the same as string bass.
I do a lot of travelling, and use the airlines a lot.
However it's a pain to travel with the instrument, and ground crew are not
always nice to my bass.
I've just assumed the bass would not fit in my Arrow until yesterday.
I took it to the hangar, and found out that it fits perfectly though the
door, but I need to be able to fold the back seat to avoid it obstructing
the flap and trim.
Also, by laying it over the back seat, the bass is not resting in a good
position. It's got too much weight on the headstock, but if I can figure out
an easy way to fold down the seatback, like an estate car for example, the
Cherokee will be a perfect cargo hauler for me! :-)
At least on VFR days......
Frode
"Ol Shy & Bashful" skrev i melding
Frode
What is a double bass player? Interesting in that I played cello and
string bass professionally for years. I was with a symphony many years
ago (50's) playing cello and was doing jazz licks when the conductor
told me that was not professional. So, I began playing string bass and
had a lot of fun while making money. Amazing how many pilots are also
musicians and that is something I've commented on many times over the
years.
Did you ever have a near miss with a drummer? ggg
BTW....early last year I hit a pine tree while crop spraying in Oregon.
It damaged the boom and one rotor blade. I didn't know about the blade
until I shut down and we saw the damage. Unfortunately that grounded
the helicopter until new blades were put on. One of those deals where
you had to have been there? Like I said, close to you, may be two miles
to me. Again, experience and exposure.
Cheers
Rocky
Old May 11th 06, 06:52 PM posted to rec.aviation.piloting,rec.aviation.student
Default Removing the rear seats (was Scared of mid-airs
the flap and trim.
Frode,
Turns out, it's fairly easy to remove the rear seats from an Arrow. There
are 4 attach points. The rear 2 are spring-loaded and you just pull
forward/up. The front 2 are on a slide and come out easily when the rear
mounts are up. No tools required.
HTH,
Morris
(BTW, welcome back. I remember you used to post a lot around here)
Old May 11th 06, 07:58 PM posted to rec.aviation.piloting
On Thu, 11 May 2006 12:52:22 -0500, Journeyman
wrote in
What does the Arrow POH say about operating with the rear seats
removed? Is it approved? Does removing the rear seats require the
use of a different weight and balance chart for calculations? Does it
change the category from/to utility/normal? How is performance
affected?
Old May 11th 06, 09:37 PM posted to rec.aviation.piloting
It doesn't say anything in my POH, so I guess it wasn't considered...
Does this mean I need an STC for it?
Frode
"Larry Dighera" skrev i melding
wrote in
affected?
Old May 11th 06, 09:50 PM posted to rec.aviation.piloting
wrote in
affected?
On Thu, 11 May 2006 22:37:30 +0200, "Frode Berg"
wrote in ::
Frode
I'm guessing, but if operation with the rear seats removed isn't
mentioned in the POH, it's not approved.
Old May 11th 06, 10:47 PM posted to rec.aviation.piloting
The POH isn't necessarily relavant. My 182 didn't mention a word about
it. The more important document is the equipment list.
Old May 11th 06, 11:48 PM posted to rec.aviation.piloting
On Thu, 11 May 2006 15:47:58 -0600, Newps wrote
in ::
Was the revised W&B located in the equipment list also?
Old May 11th 06, 11:14 PM posted to rec.aviation.piloting
affected?
Honestly, I don't know. I've never actually flown with the rear seats
removed. I've removed them for access during maintenance, but always
put them back. Given how easy they are to remove, I assumed it should
not be a problem flying without them, modulo the weight/balance change.
I've heard of people flying with the rear seats removed, but never
specifically in the Arrow.
Morris
Old May 11th 06, 09:58 PM posted to rec.aviation.piloting,rec.aviation.student
You need to make a logbook entry for the preventative
maintenance of removing and re-installing the seats. The
weight and balance data needs to be there, if not you need
an A&P the first time to make the entry.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Journeyman" wrote in message
| In article , Frode
until yesterday.
| the flap and trim.
| Frode,
an Arrow. There
just pull
| HTH,
| Morris
around here)
Old May 11th 06, 11:01 PM posted to rec.aviation.piloting,rec.aviation.student
Good point. It hadn't occurred to me because the only time
I've removed the seats was for inspection.
Of course, European rules are likely to be different.
Morris
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
