MoGas Tips, Tricks, Concerns, How To
Old May 11th 06, 05:34 PM posted to rec.aviation.owning
Default MoGas Tips, Tricks, Concerns, How To
Jay Honeck wrote:
: Now, in a fuel-injected engine (especially with GAMI), that's a whole
: different world. But in the low compression carbureted world, you run
: rich of peak, or you risk destroying your engine.
Sorry Jay, but it's not necessarily so cut-n-dried. Yes, fuel distribution is
rather poor in your flat six. Not quite as bad in my flat four, but I still have
uneven fuel distribution. The real issue is knowing *FOR SURE* what power setting
you are at and never exceeding the POH amount. Lycoming says essentially *ANY*
mixture setting is fine if you stay below 75% and 450 degrees CHT. I personally don't
like to run it that close and use the more conservative 65% and 375 degrees CHT. At
those power settings and temperatures, you cannot damage your engine with the red
knob. You can lean it until it wheezes if the CHT stays cool enough.
Now, whether or not it runs smoothly there is an entirely different matter....
one of vibration acceptability. Having some above peak and some below peak EGT is
fine if you keep the power and temps low enough.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
