"Now if someone could just figure out how to
do the same with hydraulics"... hydraulics is a whole diff ballgame, i take it?... |
Everything's ball bearings these days...
Chuck W Sharc, NAR Section 613 www.flysharc.org Sharc, the section where two out of three certification flights always work just fine! |
![]() "~^ beancounter ~^" wrote in message oups.com... "Now if someone could just figure out how to do the same with hydraulics"... Generally if the hydraulic actuator is bad (leaking, not working properly) you take it off and ship it off to be overhauled. Sometimes the problem is rigging which can be fixed on the airplane. In the case of electrical part of the actuator the servovalve (something I've actaully worked with) you have to ship the actuator it's attached to back to an overhaul shop where it is removed and then shipped on to either the manufacturer or a specialty shop. Very few stand alone specialty shops, some of the bigger airlines have servovalve shops but in general 80-90% of your servovalves are repaired by the manufacturer. I've been approached a couple of times about doing Boeing servo-valves and when I point out what is involved in doing a fresh setup the manager rapidly loses interest. There is a little "tribal knowledge" which isn't in the manual involved in tuning a servovalve. And if you don't get it right you will probably get the "mystery auto-pilot disconnect" problems that are damn near impossible to diagnose. I'll note all of my on-aircraft repair experience was electrical. My hydaulic work was limited to overhaul shops unless I was working an auto-pilot problem on an airplane. hydraulics is a whole diff ballgame, i take it?... |
"End of an era: USN's Tomcats make their final approach before decommissioning" | Mike | Naval Aviation | 15 | April 5th 06 03:45 AM |
Which Military Service is best? | ArtKramr | Military Aviation | 33 | September 19th 04 04:12 PM |
Air Force Chief Sounds Off as Service Birthday Approaches | Otis Willie | Military Aviation | 0 | September 18th 04 03:54 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 05:36 AM |
