MoGas Tips, Tricks, Concerns, How To
Old May 12th 06, 03:12 AM posted to rec.aviation.owning
Default MoGas Tips, Tricks, Concerns, How To
"Jay Honeck" wrote in message
I wonder about the effect of LOP on muffler life. I used just the
low-power-operate-at-peak philosophy and my 172 went thru the muffler
internal flame tubes every 450 hrs, like it could read the hour meter.
As posted before, the head honcho at Dawley Aviation (the exhaust
system folks in Burlington, WI) told me personally that running lean of
peak has been the best thing that EVER happened to their business.
And has been pointed out in this group previously, he's full of ****.
Old May 12th 06, 02:29 PM posted to rec.aviation.owning
Hmmm. Let's see. Shall I believe the guy who runs a multi-million
dollar aircraft exhaust system business (and has no incentive to lie to
me), or shall I believe Usenet?
Golly, what a conundrum...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 12th 06, 03:14 PM posted to rec.aviation.owning
me),
Who said he was lying?
Indeed, when you don't know the difference between "falsehood" and
"mistaken".
English major, huh?
Maybe you can have him explain how he's doing such a great business in when
maybe 5% of the aircraft are being run LOP?
Maybe you can have him explain how that happens when the EGT is symetrical
on either side of peak EGT, and the CHT is actually cooler...much cooler?
Did he give you as data-intensive an answer as you got on UseNet (complete
with charts and graphs?
Or maybe you can go back and bury your head in the sand.
Old May 12th 06, 04:36 PM posted to rec.aviation.owning
("Matt Barrow" wrote)
"Or maybe you can go back and bury your head in the [corn]."
Montblack
Old May 12th 06, 04:51 PM posted to rec.aviation.owning
"Montblack" wrote in message
Oh, now that's low (this time of year).
Old May 12th 06, 05:30 PM posted to rec.aviation.owning
Get it right:
"Or maybe you can go back and bury your head in the [ethanol]."
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 12th 06, 05:37 PM posted to rec.aviation.owning
Get it right:
Dammit! Use a STRAW!!
Old May 12th 06, 08:32 PM posted to rec.aviation.owning
I believe Dawley's exhaust business is benefiting from people running
INCORRECTLY lean of peak. The problem isn't necessarily running lean
of peak, which most people know should produce cooler (not hotter) EGTs
and CHTs.
The trouble comes with everyone TRYING to run LOP (or, just plain
leanER) to save gas, without the proper instrumentation, technique, or
knowledge.
Heat kills exhaust systems. Dawley has noticed a spike in their sales
since gas prices went through the roof, and they believe it is due to
everyone trying to run LOP. I have no reason to doubt them.
People are saving a few bucks on gas, but are spending a few hundred on
more frequent exhaust system replacement costs. I would imagine this
may translate into other repair costs as well. It's the nature of the
beast.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 13th 06, 12:26 AM posted to rec.aviation.owning
when
symetrical
Considering that most engines will shake themselves to death before they're
much leaner than peak, that's a bit of a stretch.
If someone is leaning incorrectly, attemping LOP will give warnings before
they get there. Blaming it BLINDLY on LOP is stupid. If he wants to say
"Incorrect leaning procedures", that's what he should say. Again, for YEARS
the standard procedure was right at peak EGT, as in the standard dogma, "I
lean to peak then enrich a bit". Well, that kept the engine shops busy doing
jugs and heads. It kept the maintenance people busy doing fouled plugs and
valves.
Think of someone you drove with who was driving a stick shift, but who
didn't give it enough gas before engaging the clutch, or who rode the
clutch; does that mean stick shifts are bad because they'd wear out the
clutch really soon?
and CHTs.
Most people DON'T know that LOP is cooler. AAMOF, on the A&P tests, the
correct answer to "What will too lean a mixture produce" define the problem
just the opposite (ie, higher CHT temps).
knowledge.
SInce most people are flying rentals/club aircraft which are rented WET, I
really wonder how many are trying ot overlean without the proper equipment
and instrumentation. Even so, having the right "stuff", LOP procedures is
different (ie, going from full rich to LOP in 2-3 seconds, not the several
seconds up to a minute that some people use in adjusting the mixture.
Well, when people were running in the "Red Zone", that would have been a
boon to his business since ROP is hotter. Much hotter.
beast.
As above...but no doubt, many have changed from 200ROP over to peak to
20LOP, still in the "Red Zone". But again, if he doesn't know the difference
between LOP and merely bad leaning technique, he should qualify his
statement or else he comes off a fool.
Just to show how stupid the FAA exams are and the naiveté of many of they
people they "spawned", see what Mike Busch has to say:
http://www.avweb.com/news/columns/182135-1.html
Now, you can take that stuff as an "Internet Legend" because we all know
that what comes out of the engine manufacturers Legal or Sales & Marketing
departments is GOSPEL (everybody say "Amen"!!).
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old May 13th 06, 01:57 PM posted to rec.aviation.owning
when
symetrical
They're probably wrong on BOTH sides of peak. Pilots have been chewing up
engines long before GAMI reinstituted the "LOP craze".
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
