MoGas Tips, Tricks, Concerns, How To
Old May 12th 06, 02:42 PM posted to rec.aviation.owning
Default MoGas Tips, Tricks, Concerns, How To
"Matt Barrow" wrote in message
"soxinbox" wrote in message
If you run your car engine on 80 octane mogas, it will usually run fine.
If your car overheats, it will start to knock. If you have 100 octane gas
it will start to knock at a higher CHT than if you ran at 80 octane. This
is not usually a problem in a car that has a radiator and thermostat to
regulate the temperature.
I can't remember seeing anything less than 85 octane car gas since, oh,
maybe the 60's?
Around here the grades on the pump are 83,89 and 93. Here=South & Central
Arkansas.
Old May 12th 06, 03:31 PM posted to rec.aviation.owning
On Fri, 12 May 2006 08:42:59 -0500, "Gig 601XL Builder"
maybe the 60's?
Arkansas.
I've always wondered why the mogas octane levels are different around
various areas of the US. Where I live (northwest), our mogas is
87, 89 and 92.
Bela P. Havasreti
Old May 12th 06, 04:31 PM posted to rec.aviation.owning
"Bela P. Havasreti" wrote in message
fine.
gas
This
maybe the 60's?
Arkansas.
87, 89 and 92.
Altitude - higher needs more octane.
Old May 12th 06, 04:40 PM posted to rec.aviation.owning
Altitude-higher needs less octane
Karl
ATP CFI ETC
"Curator" N185KG
Old May 12th 06, 04:51 PM posted to rec.aviation.owning
"karl gruber" wrote in message
Correct -- that's what I get for rewording it three times.
Old May 12th 06, 06:43 PM posted to rec.aviation.owning
Arkansas.
I think he's mistaken on the 83.
87, 89 and 92.
The lowest octane that you find in a given area has to do with altitude.
The higher you are the less octane you need. Around here regular is 85.5
Old May 12th 06, 08:00 PM posted to rec.aviation.owning
Lower octane autogas is quite common in mountain states where the
elevation is high. Non turbo-charged car engines have a bigger
denotation margin at higher elevation and require less octane.
Old May 12th 06, 09:03 PM posted to rec.aviation.owning
So that's why "super" mogas in Florida is 93 octane but only
92 octane in the Seattle area. Thanks everyone for the replies
(usenet is good for something besides arguing about politics
afterall!).
Bela P. Havasreti
Old May 13th 06, 01:49 PM posted to rec.aviation.owning
"Bela P. Havasreti" wrote in message ...
afterall!).
Bela P. Havasreti
Both Seattle and Florida are basically at sea level. The lower octane is not explained by altitude difference in this
case....
Old May 13th 06, 05:15 PM posted to rec.aviation.owning
afterall!).
Bela P. Havasreti
case....
Most of Florida is close to sea level.
You don't have to go far from downtown Seattle to be at 6000 feet.
Jim Pennino
Remove .spam.sux to reply.
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
