![]() "Jay Honeck" wrote in message oups.com... As posted before, the head honcho at Dawley Aviation (the exhaust system folks in Burlington, WI) told me personally that running lean of peak has been the best thing that EVER happened to their business. And has been pointed out in this group previously, he's full of ****. Hmmm. Let's see. Shall I believe the guy who runs a multi-million dollar aircraft exhaust system business (and has no incentive to lie to me), Who said he was lying? Golly, what a conundrum... Indeed, when you don't know the difference between "falsehood" and "mistaken". English major, huh? Maybe you can have him explain how he's doing such a great business in when maybe 5% of the aircraft are being run LOP? Maybe you can have him explain how that happens when the EGT is symetrical on either side of peak EGT, and the CHT is actually cooler...much cooler? or shall I believe Usenet? Did he give you as data-intensive an answer as you got on UseNet (complete with charts and graphs? Or maybe you can go back and bury your head in the sand. |
("Matt Barrow" wrote)
"Or maybe you can go back and bury your head in the [corn]." Montblack |
![]() "Montblack" wrote in message ... ("Matt Barrow" wrote) "Or maybe you can go back and bury your head in the [corn]." Oh, now that's low (this time of year). |
Get it right: "Or maybe you can go back and bury your head in the [ethanol]." :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message oups.com... "Or maybe you can go back and bury your head in the [corn]." Get it right: "Or maybe you can go back and bury your head in the [ethanol]." :-) Dammit! Use a STRAW!! |
maybe 5% of the aircraft are being run LOP? Maybe you can have him explain how that happens when the EGT is symetrical on either side of peak EGT, and the CHT is actually cooler...much cooler? I believe Dawley's exhaust business is benefiting from people running INCORRECTLY lean of peak. The problem isn't necessarily running lean of peak, which most people know should produce cooler (not hotter) EGTs and CHTs. The trouble comes with everyone TRYING to run LOP (or, just plain leanER) to save gas, without the proper instrumentation, technique, or knowledge. Heat kills exhaust systems. Dawley has noticed a spike in their sales since gas prices went through the roof, and they believe it is due to everyone trying to run LOP. I have no reason to doubt them. People are saving a few bucks on gas, but are spending a few hundred on more frequent exhaust system replacement costs. I would imagine this may translate into other repair costs as well. It's the nature of the beast. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message oups.com... Maybe you can have him explain how he's doing such a great business in when maybe 5% of the aircraft are being run LOP? Maybe you can have him explain how that happens when the EGT is symetrical on either side of peak EGT, and the CHT is actually cooler...much cooler? I believe Dawley's exhaust business is benefiting from people running INCORRECTLY lean of peak. Considering that most engines will shake themselves to death before they're much leaner than peak, that's a bit of a stretch. If someone is leaning incorrectly, attemping LOP will give warnings before they get there. Blaming it BLINDLY on LOP is stupid. If he wants to say "Incorrect leaning procedures", that's what he should say. Again, for YEARS the standard procedure was right at peak EGT, as in the standard dogma, "I lean to peak then enrich a bit". Well, that kept the engine shops busy doing jugs and heads. It kept the maintenance people busy doing fouled plugs and valves. Think of someone you drove with who was driving a stick shift, but who didn't give it enough gas before engaging the clutch, or who rode the clutch; does that mean stick shifts are bad because they'd wear out the clutch really soon? The problem isn't necessarily running lean of peak, which most people know should produce cooler (not hotter) EGTs and CHTs. Most people DON'T know that LOP is cooler. AAMOF, on the A&P tests, the correct answer to "What will too lean a mixture produce" define the problem just the opposite (ie, higher CHT temps). The trouble comes with everyone TRYING to run LOP (or, just plain leanER) to save gas, without the proper instrumentation, technique, or knowledge. SInce most people are flying rentals/club aircraft which are rented WET, I really wonder how many are trying ot overlean without the proper equipment and instrumentation. Even so, having the right "stuff", LOP procedures is different (ie, going from full rich to LOP in 2-3 seconds, not the several seconds up to a minute that some people use in adjusting the mixture. Heat kills exhaust systems. Dawley has noticed a spike in their sales since gas prices went through the roof, and they believe it is due to everyone trying to run LOP. I have no reason to doubt them. Well, when people were running in the "Red Zone", that would have been a boon to his business since ROP is hotter. Much hotter. People are saving a few bucks on gas, but are spending a few hundred on more frequent exhaust system replacement costs. I would imagine this may translate into other repair costs as well. It's the nature of the beast. As above...but no doubt, many have changed from 200ROP over to peak to 20LOP, still in the "Red Zone". But again, if he doesn't know the difference between LOP and merely bad leaning technique, he should qualify his statement or else he comes off a fool. Just to show how stupid the FAA exams are and the naiveté of many of they people they "spawned", see what Mike Busch has to say: http://www.avweb.com/news/columns/182135-1.html Now, you can take that stuff as an "Internet Legend" because we all know that what comes out of the engine manufacturers Legal or Sales & Marketing departments is GOSPEL (everybody say "Amen"!!). -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
![]() "Jay Honeck" wrote in message oups.com... Maybe you can have him explain how he's doing such a great business in when maybe 5% of the aircraft are being run LOP? Maybe you can have him explain how that happens when the EGT is symetrical on either side of peak EGT, and the CHT is actually cooler...much cooler? I believe Dawley's exhaust business is benefiting from people running INCORRECTLY lean of peak. They're probably wrong on BOTH sides of peak. Pilots have been chewing up engines long before GAMI reinstituted the "LOP craze". |
MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Home Built | 82 | May 19th 05 02:49 PM |
MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Owning | 87 | May 19th 05 02:49 PM |
Pocket PC Tips & Glide Navigator II Tips | Paul Remde | Soaring | 0 | December 14th 04 08:21 PM |
Mogas and microbial growth | Economic Girly Man | Owning | 6 | November 13th 04 09:14 AM |
"Dirty Tricks" and "Both Sides Do It" | Leslie Swartz | Military Aviation | 19 | March 29th 04 06:11 PM |
