MoGas Tips, Tricks, Concerns, How To
Old May 15th 06, 08:56 PM posted to rec.aviation.owning
Default MoGas Tips, Tricks, Concerns, How To
A couple of points:
1) My copy of ASTM spec D910 page 0539 states that the allowable TEL
content of 100LL avgas is 2 milliliters per gallon NOT 2 grams per
gallon. This means there will be over 1/3rd pound of lead in an 80
gallon tank of 100LL, plus about 1/5th pound of ethlylene dibromide
scavenging agent.
2) My muffler "failures" were from the internal flame tubes, which
must be present and in reasonable condition if they were originally
present when new, but are not required on later mufflers that did not
have the internal flame tubes. We did a proctoscope exam with a small
flashlight at annual to verify their condition. Our engine was run
about 50 deg rich of peak, or so we thought as we had only a single EGT
probe. There was little engine roughness though if the mixture was
leaned further. Manifold pressure was set to 21 inches for cruise,
less at higher altitudes.
I suspect many 172s were just run until the flame tubes were all gone
out the tailpipe.
Old May 15th 06, 10:49 PM posted to rec.aviation.owning
"nrp" wrote in message
A couple of points:
scavenging agent.
Aside from the curiousity of mixing gallons and metric measurments, 2
gr/gallon is 160 grams in an 80 gallon tank. 160/454=0.3524 lbs, so it's
virtually the same thing. SAW, 160 gr in a tank that holds 36,320 grams, 1/3
lb in a tank holding 480 lbs.
Old May 16th 06, 02:54 AM posted to rec.aviation.owning
It is close, as TEL is only about 2/3 lead by weight. The molecular
weight of TEL is 323 according to my chemistry book, and the tetraethyl
part is about 116. The net numbers work out as you indicated. The
spcific density of TEL is 1.659 gm/ml.
Old May 16th 06, 11:57 PM posted to rec.aviation.owning
That's indeed quite a bit, huh? If I take a 1/3lb lead ball to a C-206
flyer and tell him that's how much lead there is in his full tanks, I
bet he'll be surprised.
nrp wrote:
A couple of points:
scavenging agent.
Old May 17th 06, 12:16 AM posted to rec.aviation.owning
"M" wrote in message
How big do you think that ball would be?
Old May 17th 06, 01:05 AM posted to rec.aviation.owning
Roughly somewhere between the size of a candy jaw breaker and a big
marble (I know there is a name for the big ones, but since I lost
all my marbles, I can't remember what it is).
Jim Pennino
Remove .spam.sux to reply.
Old May 17th 06, 02:11 AM posted to rec.aviation.owning
("Matt Barrow" wrote)
flyer and tell him that's how much lead there is in his full tanks, I bet
he'll be surprised.
"I know, I know. Me. Me. Call on Me!"
http://www.tesarta.com/www/resources...y/weights.html
Lead:
[Cubic foot = 1,728 cubic inches]
710 lbs / cubic foot
1 lb. = 2.43 cubic inchs of lead
x 0.33 lbs. = 0.8 c.i. (cubic inches of lead)
http://www.1728.com/diam.htm
Volume of a sphere ..."I knew where to look it up!"
1.15 inches [Diameter] seems to be close for 0.8 cubic inches.
A 25 cent [Quarter] measures 92% of an inch across. About 15/16 - not quite
an inch. (I squinted because I needed 0.92! g)
..92 [Diameter] into the sphere equation = 0.4 c.i. (x 2) = 0.8 c.i.
So, two spheres, each with a diameter of a 25 cent [Quarter] = 0.8 cubic
inches ...which = 1/3 lb of lead. One lead ball for each side!
Montblack
Time for Gym. Heading outside for my 3 mile walk....
Old May 17th 06, 01:46 PM posted to rec.aviation.owning
"Montblack" wrote in message
Lead:
quite an inch. (I squinted because I needed 0.92! g)
In the words of Don Rickles, "Very good; you win a cookie!" :~)
Old May 17th 06, 04:12 PM posted to rec.aviation.owning
How big's the cookie?
Montblack
Radius is all I need... g
Old May 17th 06, 04:47 PM posted to rec.aviation.owning
cubic inches ...which = 1/3 lb of lead. One lead ball for each side!
....and what's the lead content?
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
