In your controller training, are situations
addressed concerning aircraft which request priority but do not declare an emergency? Is there any guidance in the Controllers' Handbook? The document says (very roughly) if in doubt handle as emergnecy even if not declared by aircrew. This reminds me of a time when I was a dual Pilot Under Instruction. I was flying the aeroplane (almost ready for solo) when (as we later found out) a drive gear to one of the magnetos lost some teeth. We were 500' AGL climbing out from takeoff. The engine immediately lost a lot of power and sounded very bad. The instructor took over control and turned 180 degrees and made a downwind landing. The engine did not get worse. IIRC we were able to maintain altitude more or less. I was surprised that he did not declare an emergency and only requested clearance to land on the reciprocal runway. The tower said nothing either but as we approached I could see that the fire crews were out. I did not pursue my flying and so have not really much more experience that I had then but I still feel that not declaring an emergency was not the right thing to do. He was however a military instructor which I assume indicates quite a bit of flying experience. He did, of course, take the opportunity to demonstrate and talk through the issues and techniques of downwind landing which I had not yet covered! The engine lost power since the faulty mag was still firing quite a lot but not at the right time. Given more altitude various mag switch fiddling would have presumably restored power. Anyway, the point is that the UK controllers behaved as described in the document referred to in the previous post and called out the crash crew even though no emergency had been declared. |
So who files out the paper work later?
I ask because I once arrived at a major U.S. West Coast airport, and upon extending the landing gear, had no light. I was left base at the time, so I asked for a "right 270" to do a quick troubleshoot. Sure enough, the bulb was bad. After landing I was followed by the equipment, and when I stopped, the crash rescue guys wanted to know the "nature of my emergency". I told them I had no emergency, and they left. It took two months of talking to FAA folks to convince them there was no emergency in the first place. Al wrote in message oups.com... In your controller training, are situations addressed concerning aircraft which request priority but do not declare an emergency? Is there any guidance in the Controllers' Handbook? The document says (very roughly) if in doubt handle as emergnecy even if not declared by aircrew. This reminds me of a time when I was a dual Pilot Under Instruction. I was flying the aeroplane (almost ready for solo) when (as we later found out) a drive gear to one of the magnetos lost some teeth. We were 500' AGL climbing out from takeoff. The engine immediately lost a lot of power and sounded very bad. The instructor took over control and turned 180 degrees and made a downwind landing. The engine did not get worse. IIRC we were able to maintain altitude more or less. I was surprised that he did not declare an emergency and only requested clearance to land on the reciprocal runway. The tower said nothing either but as we approached I could see that the fire crews were out. I did not pursue my flying and so have not really much more experience that I had then but I still feel that not declaring an emergency was not the right thing to do. He was however a military instructor which I assume indicates quite a bit of flying experience. He did, of course, take the opportunity to demonstrate and talk through the issues and techniques of downwind landing which I had not yet covered! The engine lost power since the faulty mag was still firing quite a lot but not at the right time. Given more altitude various mag switch fiddling would have presumably restored power. Anyway, the point is that the UK controllers behaved as described in the document referred to in the previous post and called out the crash crew even though no emergency had been declared. |
The rule does not require the pilot to say the "magic words"
to have an emergency, nor does it mean that if the words are not spoken an emergency does not exist. The rules also require a report IF traffic priority is given. The tower saw that you were doing something out of the ordinary. They may have extended another airplane [perhaps an airliner] and if the airline asked why their fuel bill was $1,000 higher and 10 minutes late, the tower needs your statement, really just a N-number, name to CYA. If you mentally declare an emergency to yourself, you can do what ever is needed to solve the problem, including violations of airspace, minimums or clearance. For instance, you're solid IFR/IMC and have a total electrical failure which is not covered by any regulation except pilot's emergency authority. You can shout at your dead radio, until you get on the ground somewhere nobody will know the nature of your emergency. Your navigation becomes dead reckoning to the nearest area of known VMC. Controllers are there to help, but unless you say emergency they're not obligated to give you priority handling. There is no investigation, no third degree or rubber hose, declare the emergency, get on the ground safely, tell them your name and thanks. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Al" wrote in message ... | So who files out the paper work later? | | I ask because I once arrived at a major U.S. West Coast airport, and | upon extending the landing gear, had no light. I was left base at the time, | so I asked for a "right 270" to do a quick troubleshoot. Sure enough, the | bulb was bad. After landing I was followed by the equipment, and when I | stopped, the crash rescue guys wanted to know the "nature of my emergency". | I told them I had no emergency, and they left. It took two months of talking | to FAA folks to convince them there was no emergency in the first place. | | Al | | | wrote in message | oups.com... | In your controller training, are situations | addressed concerning aircraft | which request priority but do not declare an | emergency? Is there any | guidance in the Controllers' Handbook? | | The document says (very roughly) if in | doubt handle as emergnecy even if not | declared by aircrew. | | This reminds me of a time when I was | a dual Pilot Under Instruction. | | I was flying the aeroplane (almost | ready for solo) when (as we later | found out) a drive gear to one of the | magnetos lost some teeth. | | We were 500' AGL climbing out from takeoff. | | The engine immediately lost a lot of power | and sounded very bad. The instructor took over | control and turned 180 degrees and made | a downwind landing. The engine did not get worse. | IIRC we were able to maintain altitude more or less. | | I was surprised that he did not declare an emergency | and only requested clearance to land on the reciprocal | runway. The tower said nothing either but as we approached | I could see that the fire crews were out. | | I did not pursue my flying and so have not really | much more experience that I had then but | I still feel that not declaring an emergency was | not the right thing to do. | | He was however a military instructor which I | assume indicates quite a bit of flying experience. | | He did, of course, take the opportunity to | demonstrate and talk through the issues | and techniques of downwind landing which | I had not yet covered! | | The engine lost power since the faulty | mag was still firing quite a lot but not at | the right time. Given more altitude various | mag switch fiddling would have presumably | restored power. | | Anyway, the point is that the UK controllers | behaved as described in the document | referred to in the previous post and | called out the crash crew even though no | emergency had been declared. | | | |
![]() Jim Macklin wrote: The rule does not require the pilot to say the "magic words" to have an emergency, nor does it mean that if the words are not spoken an emergency does not exist. The rules also require a report IF traffic priority is given. The tower saw that you were doing something out of the ordinary. They may have extended another airplane [perhaps an airliner] and if the airline asked why their fuel bill was $1,000 higher and 10 minutes late, the tower needs your statement, really just a N-number, name to CYA. You're just makin' this **** up. Nowhere does it spell out that if you do something "unusual" does that then require a report. In the situation where the gear light failed you ask to have a little manuvering space to check it out. We give you that and you tell us it was the bulb. You get the equipment as a matter of course. Whether you think it is an emergency or not is irrelavant, we do so therefore it is an emergency. You land safely and there are two lines on the daily log. Fiorst line states that N12345 has gear difficulty and that the trucks were rolled. Second line states you landed safely. That's it and the end of it. That log, like all daily logs, gets kept for a year. They are not forwarded on to anybody. You will not be asked for a report. If there is an incident or accident you may be called by the tower for some information. We had one of the local C310's that is used by a 135 air taxi outfit to deliver bank checks everyday fold up its right main three weeks ago on landing. Gear ups are by definition an incident and not an accident. Normally the airport and FBO can get a gear up off the runway pretty quickly however this time the owner of the plane demanded that they lift up the plane using two cranes, like you're supposed to to prevent further damage. It took an extra half hour to locate so the plane tied up our main runway for over an hour. Many airliners, air taxi's and biz jets in holding while all of this going on. We never talked to the pilot of the 310 after the gear up, no need to. The fire truck guys have their own paperwork but that has nothing to do with the FAA. |
![]() "Newps" wrote in message ... Jim Macklin wrote: The rule does not require the pilot to say the "magic words" to have an emergency, nor does it mean that if the words are not spoken an emergency does not exist. The rules also require a report IF traffic priority is given. The tower saw that you were doing something out of the ordinary. They may have extended another airplane [perhaps an airliner] and if the airline asked why their fuel bill was $1,000 higher and 10 minutes late, the tower needs your statement, really just a N-number, name to CYA. You're just makin' this **** up. Nowhere does it spell out that if you do something "unusual" does that then require a report. In the situation where the gear light failed you ask to have a little manuvering space to check it out. We give you that and you tell us it was the bulb. You get the equipment as a matter of course. Whether you think it is an emergency or not is irrelavant, we do so therefore it is an emergency. You land safely and there are two lines on the daily log. Let's see: He says virtually the same thing and he's "making **** up"? Read it again and, this time, don't just skim it. Fiorst line states that N12345 has gear difficulty and that the trucks were rolled. Second line states you landed safely. That's it and the end of it. That log, like all daily logs, gets kept for a year. They are not forwarded on to anybody. You will not be asked for a report. If there is an incident or accident you may be called by the tower for some information. We had one of the local C310's that is used by a 135 air taxi outfit to deliver bank checks everyday fold up its right main three weeks ago on landing. Gear ups are by definition an incident and not an accident. Normally the airport and FBO can get a gear up off the runway pretty quickly however this time the owner of the plane demanded that they lift up the plane using two cranes, like you're supposed to to prevent further damage. It took an extra half hour to locate so the plane tied up our main runway for over an hour. Many airliners, air taxi's and biz jets in holding while all of this going on. We never talked to the pilot of the 310 after the gear up, no need to. The fire truck guys have their own paperwork but that has nothing to do with the FAA. What is it about the controllers in here that they're ****house lawyers and have their egos shoved so far up their ass? |
![]() Matt Barrow wrote: "Newps" wrote in message ... The rules also require a report IF traffic priority is given. No such rule. The tower saw that you were doing something out of the ordinary. Every controller sees this everyday. If a report were required everytime somebody does something out of the ordinary there wouldn't be any trees left. They may have extended another airplane [perhaps an airliner] and if the airline asked why their fuel bill was $1,000 higher and 10 minutes late, They wouldn't and if they did we'd blow them off. the tower needs your statement, really just a N-number, name to CYA. We don't need to CYA. We're gonna get sued anyways. What is it about the controllers in here that they're ****house lawyers and have their egos shoved so far up their ass? Would you like some cheese with that whine? |
Why don't you read posts before clipping....or at least learn to clip
correctly. "Newps" wrote in message ... Matt Barrow wrote: "Newps" wrote in message ... The rules also require a report IF traffic priority is given. No such rule. The tower saw that you were doing something out of the ordinary. Every controller sees this everyday. If a report were required everytime somebody does something out of the ordinary there wouldn't be any trees left. They may have extended another airplane [perhaps an airliner] and if the airline asked why their fuel bill was $1,000 higher and 10 minutes late, They wouldn't and if they did we'd blow them off. the tower needs your statement, really just a N-number, name to CYA. We don't need to CYA. We're gonna get sued anyways. What is it about the controllers in here that they're ****house lawyers and have their egos shoved so far up their ass? Would you like some cheese with that whine? |
Would you like some cheese with that whine? I don't drink, thanks. My post wasn't meant for pilots to snipe at controllers. It was meant for enlightenment concerning an incident where the controller declined to provide priority when asked, and an accident followed. I'll ask again- In your controller training, are situations addressed concerning aircraft which request priority but do not declare an emergency? D. (Where's McNicholl?) |
"Newps" wrote in message The fire
truck guys have their own paperwork but that has nothing to do with the FAA. For those who haven't had the 'pleasure', I point out for educational purposes that giving a statement to the firefighters is strictly voluntary. If you do, it may come back to haunt you. For myself, "I respectfully decline to provide that information." D. |
![]() "Al" wrote in message ... So who files out the paper work later? What paperwork? I ask because I once arrived at a major U.S. West Coast airport, and upon extending the landing gear, had no light. I was left base at the time, so I asked for a "right 270" to do a quick troubleshoot. Sure enough, the bulb was bad. After landing I was followed by the equipment, and when I stopped, the crash rescue guys wanted to know the "nature of my emergency". I told them I had no emergency, and they left. It took two months of talking to FAA folks to convince them there was no emergency in the first place. Why bother? You feel there was no emergency, they believe there was. So what? |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
