![]() wrote Yes, however:- Hydrostatic drives shuch as this are fairly common in heavy construction equipment and the like however there is a problem. There is too much loss even for ordinary car use and the fuel consumption is unacceptably poor. I would guess that this would be an even more serious issue in aircraft. Indeed, there would be, and one large problem is called weight. It wo8uld be extremely heavy. Also, those loss issues bring up another problem. When you have loss, what happens to that energy? Energy can not be created or destroyed, and that energy put into loss shows up as heat. Boatloads of heat that must be dissipated, and that will take a lot of radiator, and air to go through it. That will cause wind resistance, which will slow the plane, so much as to make a biplane seem speedy. -- Jim in NC |
Why does a prop ice up so apparently readily? | Mike Rapoport | General Aviation | 3 | November 8th 05 02:52 PM |
Engine driven fuel pump necessary with gravity feed tank?? Lycoming | RonLee | Home Built | 2 | May 8th 05 06:10 PM |
Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 08:08 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
