![]() Diesel actually has a substantial advande in fuel economy. The Tielert diesel claims to have a BSFC of 0.33lb/HP-hr, far better than the gasoline engines that're usually at 0.40-0.45 range. If you think this is not significant, consider that diesel weighs more per gallon than avgas, and we buy fuel in volume, not weight. So a 25% improvement of BSFC by going diesel will actually result in 28% of saving in the volume (gallon) of fuel burn. If the cost of diesel per gallons is 20% lower than avgas, the total fuel cost saving is going to be about 34% in dollar amount. That's very significant over the life time of an engine. wrote: What is going to happen to fuel costs? Right now Jet A is $.87/gal cheaper at my local FBO. Will this spread increase or decrease? Will a FADEC diesel further reduce the fuel costs by keeping everything optimal? |
I thought the fuel for these aviation diesel engine
was Jet A. Is the data below for Jet A or for diesel fuel? How does Jet A compare to gasoline? Ronnie "M" wrote in message ps.com... Diesel actually has a substantial advande in fuel economy. The Tielert diesel claims to have a BSFC of 0.33lb/HP-hr, far better than the gasoline engines that're usually at 0.40-0.45 range. If you think this is not significant, consider that diesel weighs more per gallon than avgas, and we buy fuel in volume, not weight. So a 25% improvement of BSFC by going diesel will actually result in 28% of saving in the volume (gallon) of fuel burn. If the cost of diesel per gallons is 20% lower than avgas, the total fuel cost saving is going to be about 34% in dollar amount. That's very significant over the life time of an engine. wrote: What is going to happen to fuel costs? Right now Jet A is $.87/gal cheaper at my local FBO. Will this spread increase or decrease? Will a FADEC diesel further reduce the fuel costs by keeping everything optimal? |
I was using the term diesel fuel in a generic sense. Yes the math is
based on Jet A because it's 6.84lb/gal compared with 6lb/gal of avgas. Ronnie wrote: I thought the fuel for these aviation diesel engine was Jet A. Is the data below for Jet A or for diesel fuel? How does Jet A compare to gasoline? |
"Ronnie" writes:
I thought the fuel for these aviation diesel engine was Jet A. Is the data below for Jet A or for diesel fuel? How does Jet A compare to gasoline? Jet A == kerosene. Gasoline is 6.25 lbs/gallon {at ~70F} Kero is 6.84 lbs/gallon... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Jet A is more expensive out our local pumps than 100LL but about 80cents.
BT "M" wrote in message ps.com... Diesel actually has a substantial advande in fuel economy. The Tielert diesel claims to have a BSFC of 0.33lb/HP-hr, far better than the gasoline engines that're usually at 0.40-0.45 range. If you think this is not significant, consider that diesel weighs more per gallon than avgas, and we buy fuel in volume, not weight. So a 25% improvement of BSFC by going diesel will actually result in 28% of saving in the volume (gallon) of fuel burn. If the cost of diesel per gallons is 20% lower than avgas, the total fuel cost saving is going to be about 34% in dollar amount. That's very significant over the life time of an engine. wrote: What is going to happen to fuel costs? Right now Jet A is $.87/gal cheaper at my local FBO. Will this spread increase or decrease? Will a FADEC diesel further reduce the fuel costs by keeping everything optimal? |
On Wed, 17 May 2006 17:42:17 -0700, "BTIZ"
wrote: Jet A is more expensive out our local pumps than 100LL but about 80cents. BT How much is home heating oil? Don |
![]() "BTIZ" wrote in message news:JpPag.1293$rS6.170@fed1read11... Jet A is more expensive out our local pumps than 100LL but about 80cents. BT Fairly common in areas where the "jet-setters" congregate, like Jackson Hole, Squaw Valley, Aspen... |
FlightAware web site -- finally free flight tracking | Chip Hermes | Instrument Flight Rules | 24 | September 15th 05 02:34 AM |
FlightAware web site -- finally free flight tracking | Chip Hermes | Piloting | 23 | September 15th 05 02:34 AM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Finally got my X-country in.. | PJ Hunt | Rotorcraft | 0 | December 18th 04 10:50 AM |
Finally flying new Skyhawks! | Scott Schluer | Piloting | 11 | February 24th 04 10:02 PM |
