Marine antenna
Old May 20th 06, 12:55 AM posted to rec.aviation.owning
Default Marine antenna
Newps wrote:
Doug wrote:
Well, that was what I was told at Oshkosh where EVERYONE was asking for
it. But it's really just a rumor. However, you don't see any of them.
Of course the FCC could change their mind.
The FCC doesn't have anything to say about it.
Other than to mandate the radio meet stringent technical standards and
that the manufacturer spend a bundle formally proving compliance before
the radio can be legally sold and that's not going to change...
Jim Pennino
Remove .spam.sux to reply.
Old May 21st 06, 01:15 AM posted to rec.aviation.owning
My impression was that the Japanese designed as few universal
platforms as possible, each with a multitude of features, qual'd the
platforms with the various PTTs, of which the FCC is just one, and
then disabled features in order to create application/country-specific
models. Hence the dozens of Web pages of simple
cut-the-jumper-and-tweak the-capacitor hacks.
Don
When done, it is usually to meet country specific nits.
For example, the Amateur frequency allocations are not 100% the same
throughout the world (close, but not 100%), so such things are common
there.
The FCC is getting anal about designs that allow jumper changes for
operation outside the original certification for non-Amateur equipment.
Besides, if a company went through all the hoops, why wouldn't it just
sell the equipment with the certified capability enabled?
Jim Pennino
Old May 21st 06, 02:08 PM posted to rec.aviation.owning
Michael Ware wrote:
"Doug" wrote in message
Just look at the specs for marine antennaes and use those, or go to a
marine store and measure one. No need to reinvent the wheel....
Well, that's true, but the VSWR should be checked, with a meter while
airborne. Failure to do this could result in a damaged radio.
Doubtful. No 12V (or 28V) transistor radio is going to burn up
it's finals driven into a mismatch. It won't produce much
power.
Marine antenna Don Tuite Owning 1 May 15th 06 12:20 PM
Marine antenna mikem Owning 3 May 15th 06 12:19 PM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Swift Boat Veterans For Truth: Are They Going To Sink John Kerry? BUFDRVR Military Aviation 151 September 12th 04 09:59 PM
Lot of noise being made about Purple Hearts Jack Military Aviation 154 September 8th 04 07:24 PM
