Here is a common occurance at TPL, Temple, TX which I use
as a way of teaching students how to stay ahead of ATC: We are VFR doing practice approaches and being vectored for an ILS to RWY 15. Usually this results in being vectored to the west side of the airport and told to maintain 3000'. At about 8 miles out, the final clearance goes something like this: "Cessna xyxxz, you are 5 miles from the outer marker, turn right heading 120 to intercept the localizer, maintin 3000 until established, cleared for the ILS approach to runway 15 Temple." Normally, by the time the localizer needle comes off the peg, we have already flown trhough the glideslope and are well above the glide slope at this point. The MVA in that area (according to one controller) is 2600', but they routinely keep you at 3000' usless you ask for lower. The glide slope intercept altitude is 1700'. I tell my students to expect this, but the first couple of times it happens to them they always seem to get behind, don't ask for lower and/or end up failing to decend soon enough to recover. Makes for a nice game of catch-up as they try to get back on the glide slope. After a couple of times, they wise up and either ask for lower before being given the approach clearance, or they are spring loaded and ready to descend once the localizer needle gets within 3/4 scale deflection. Ronnie "KP" nospam@please wrote in message ... "M" wrote in message oups.com... Is it common for the approach controller to vector for an ILS at an altitude below the GS intercept altitude on the IAP? Today is the third time in the last year or so that Victoria terminal vectored me for the ILS into BLI at 2000 feet, instead of 2100. I'm very familiar with the area and I did not bother to question them. The Canadian controllers provide approach service for Bellingham probably from an agreement between FAA and NavCanada. Maybe the rules are somewhat different in Canada, or they just don't have the right information on this approach? See http://204.108.4.16/d-tpp/0604/00045I16.PDF As has already been pointed out, FAAO 7110.65 5-9-1b requires US controllers to vector "For a precision approach, at an altitude not above the glideslope/glidepath or below the minimum glideslope intercept altitude specified on the approach procedure chart." So... What was your assigned altitude prior to receiving the approach clearance? Above 2100 or level at 2000? If above 2100, what was the wording of the actual approach clearance? Any "at or above" or other wording that would allow you to adjust your descent to intercept the GS at the "altitude specified on the approach chart" rather than level at 2000? It could also be as simple as the MVA in that area is 2000 and the controllers simply assign the round thousands MVA as a routine. They either don't know or don't care (given the allowable error in altimeters and Mode C) that they are supposed to add that extra 100ft for ILS approaches. |
![]() "Ronnie" wrote in message . com... Here is a common occurance at TPL, Temple, TX which I use as a way of teaching students how to stay ahead of ATC: We are VFR doing practice approaches and being vectored for an ILS to RWY 15. Usually this results in being vectored to the west side of the airport and told to maintain 3000'. At about 8 miles out, the final clearance goes something like this: "Cessna xyxxz, you are 5 miles from the outer marker, turn right heading 120 to intercept the localizer, maintin 3000 until established, cleared for the ILS approach to runway 15 Temple." Normally, by the time the localizer needle comes off the peg, we have already flown trhough the glideslope and are well above the glide slope at this point. The MVA in that area (according to one controller) is 2600', but they routinely keep you at 3000' usless you ask for lower. The glide slope intercept altitude is 1700'. I tell my students to expect this, but the first couple of times it happens to them they always seem to get behind, don't ask for lower and/or end up failing to decend soon enough to recover. Makes for a nice game of catch-up as they try to get back on the glide slope. After a couple of times, they wise up and either ask for lower before being given the approach clearance, or they are spring loaded and ready to descend once the localizer needle gets within 3/4 scale deflection. Have you ever asked them why they assign altitudes to VFR aircraft? |
On 5/19/06 8:00 PM, in article
t, "Steven P. McNicoll" wrote: "Ronnie" wrote in message . com... Here is a common occurance at TPL, Temple, TX which I use as a way of teaching students how to stay ahead of ATC: We are VFR doing practice approaches and being vectored for an ILS to RWY 15. Usually this results in being vectored to the west side of the airport and told to maintain 3000'. At about 8 miles out, the final clearance goes something like this: "Cessna xyxxz, you are 5 miles from the outer marker, turn right heading 120 to intercept the localizer, maintin 3000 until established, cleared for the ILS approach to runway 15 Temple." Normally, by the time the localizer needle comes off the peg, we have already flown trhough the glideslope and are well above the glide slope at this point. The MVA in that area (according to one controller) is 2600', but they routinely keep you at 3000' usless you ask for lower. The glide slope intercept altitude is 1700'. I tell my students to expect this, but the first couple of times it happens to them they always seem to get behind, don't ask for lower and/or end up failing to decend soon enough to recover. Makes for a nice game of catch-up as they try to get back on the glide slope. After a couple of times, they wise up and either ask for lower before being given the approach clearance, or they are spring loaded and ready to descend once the localizer needle gets within 3/4 scale deflection. Have you ever asked them why they assign altitudes to VFR aircraft? I assumed that they are in VFR conditions but on an IFR plan. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
No, I have not asked, but I think it is because of tihs.
This facility is Gray Approach, an army ATC facility that handles Gray Army Airfield and other military airfiields associated with Forth Hood. In general, the controlers treat all traffic, inlcuding VFR trafic, like IFR traffic unless you continue to remind them that you are VFR. I usually don't bother because I'm interested in letting my instrument students experience the IFR handling, even if we are VFR. Ronnie "Steven P. McNicoll" wrote in message nk.net... "Ronnie" wrote in message . com... Here is a common occurance at TPL, Temple, TX which I use as a way of teaching students how to stay ahead of ATC: We are VFR doing practice approaches and being vectored for an ILS to RWY 15. Usually this results in being vectored to the west side of the airport and told to maintain 3000'. At about 8 miles out, the final clearance goes something like this: "Cessna xyxxz, you are 5 miles from the outer marker, turn right heading 120 to intercept the localizer, maintin 3000 until established, cleared for the ILS approach to runway 15 Temple." Normally, by the time the localizer needle comes off the peg, we have already flown trhough the glideslope and are well above the glide slope at this point. The MVA in that area (according to one controller) is 2600', but they routinely keep you at 3000' usless you ask for lower. The glide slope intercept altitude is 1700'. I tell my students to expect this, but the first couple of times it happens to them they always seem to get behind, don't ask for lower and/or end up failing to decend soon enough to recover. Makes for a nice game of catch-up as they try to get back on the glide slope. After a couple of times, they wise up and either ask for lower before being given the approach clearance, or they are spring loaded and ready to descend once the localizer needle gets within 3/4 scale deflection. Have you ever asked them why they assign altitudes to VFR aircraft? |
Probably not relevant at TPL, but are controllers allowed (or
required?) to assign altitiudes to VFR aircraft in Class B? (I'd always assumed "yes" without giving it much thought.) I often get vectors for practice BJC ILS29R approaches while VFR. The vectors take me into DEN Class B. I'm invariably given altitudes as well as headings, which I appreciate as I'm trying to practice IFR proceures. Tim. On Sat, 20 May 2006 00:00:23 GMT, "Steven P. McNicoll" wrote: Have you ever asked them why they assign altitudes to VFR aircraft? |
If you're in the Bravo airspace they WILL assign you an altitude or
expect that you keep the one you are on. I've been assigned "wrong way" VFR altitudes while in the Bravo airspace to fit in with their plans. Once you exit the Bravo you are expected to fly proper VFR altitudes for your direction. Tim Auckland wrote: Probably not relevant at TPL, but are controllers allowed (or required?) to assign altitiudes to VFR aircraft in Class B? (I'd always assumed "yes" without giving it much thought.) I often get vectors for practice BJC ILS29R approaches while VFR. The vectors take me into DEN Class B. I'm invariably given altitudes as well as headings, which I appreciate as I'm trying to practice IFR proceures. Tim. On Sat, 20 May 2006 00:00:23 GMT, "Steven P. McNicoll" wrote: Have you ever asked them why they assign altitudes to VFR aircraft? |
![]() "Robert Chambers" wrote in message . com... If you're in the Bravo airspace they WILL assign you an altitude or expect that you keep the one you are on. I've been assigned "wrong way" VFR altitudes while in the Bravo airspace to fit in with their plans. Once you exit the Bravo you are expected to fly proper VFR altitudes for your direction. Once you exit Class B airspace ATC is supposed to tell you to resume altitudes appropriate for the direction of flight. |
![]() "Tim Auckland" wrote in message ... Probably not relevant at TPL, but are controllers allowed (or required?) to assign altitiudes to VFR aircraft in Class B? (I'd always assumed "yes" without giving it much thought.) I often get vectors for practice BJC ILS29R approaches while VFR. The vectors take me into DEN Class B. I'm invariably given altitudes as well as headings, which I appreciate as I'm trying to practice IFR proceures. ATC can assign altitudes to VFR aircraft wherever separation is provided to VFR aircraft; Class B airspace, Class C airspace and the associated outer area, and TRSAs. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 12:39 AM |
