Flying through Canadian airspace
Old May 27th 06, 11:16 PM posted to rec.aviation.ifr,rec.aviation.piloting
Default Flying through Canadian airspace
"Jay Honeck" wrote in message
One semi-interesting observation: This isn't true in the Washington
ADIZ. There, a VFR ADIZ flight plan IS opened by ATC, after first
filing with flight service.
That's because the ADIZ flight plan isn't a VFR flight plan.
Funny that some things actually work better under the ADIZ.
Not really. The most you can say is that things aren't as bad under the
ADIZ as they could be.
Pete
Old May 31st 06, 08:10 PM posted to rec.aviation.ifr,rec.aviation.piloting
Paul Tomblin wrote:
Post 9/11, you still have to be on a flight plan of some sort to cross the
border, and now you have to be talking to ATC as well.
Where does that latter requirement come from? It's news to me, and
Toronto Terminal isn't usually interested in talking to VFR arrivals.
Old May 31st 06, 08:19 PM posted to rec.aviation.ifr,rec.aviation.piloting
FDC NOTAM 2/5319
"PART 2 OF 8 .. SPECIAL NOTICE .. OPERATIONS TO/FROM LOCATIONS OUTSIDE THE
U.S. PART II. U.S., MEXICAN OR CANADIAN REGISTERED AIRCRAFT CONDUCTING
IFR/VFR OPERATIONS TO/FROM LOCATIONS OUTSIDE THE TERRITORIAL AIRSPACE OF
THE U.S. NO PERSON MAY OPERATE AN AIRCRAFT UNDER VFR OR IFR TO OR FROM THE
TERRITORIAL AIRSPACE OF THE U.S. EXCEPT AS PROVIDED BELOW: A. PART 91 VFR
OPERATIONS ARE AUTHORIZED FOR AIRCRAFT WITH A MAXIMUM CERTIFICATED TAKEOFF
GROSS WEIGHT OF 95,000 POUNDS OR LESS, BETWEEN THE COUNTRIES OF THE U.S.,
CANADA, AND MEXICO, PROVIDED ALL THE FOLLOWING CONDITIONS ARE MET: 1. THE
AIRCRAFT IS REGISTERED IN THE U.S., CANADA OR MEXICO. 2. THE FLIGHT CREW
AND ONLY KNOWN PASSENGERS ARE ON BOARD. 3. THE PILOT FILES AND ACTIVATES A
FLIGHT PLAN. 4. THE PILOT IS IN COMMUNICATION WITH THE GOVERNING ATC
FACILITY AT THE TIME OF THE BOUNDARY CROSSING. 5. THE AIRCRAFT IS
SQUAWKING AN AIR TRAFFIC CONTROL ASSIGNED DISCRETE BEACON CODE. 6. THE
PILOT COMPLIES WITH ALL U.S. CUSTOMS NOTIFICATIONS AND COMPLIES WITH
REQUIREMENTS TO LAND AT AIRPORTS IN THE U.S., CANADA OR MEXICO DESIGNATED
AS PORTS OF ENTRY. END PART 2 OF 8"
I draw your attention to part 4 and 5.
Paul Tomblin
http://xcski.com/blogs/pt/
The thing I've noticed, particularly about Usenet, that while as a
welcome break from work it is refreshing and interesting, when you've
got bugger all else to do it kinda loses its appeal. -- C Speed
Old June 5th 06, 04:01 AM posted to rec.aviation.ifr,rec.aviation.piloting
On Wed, 31 May 2006 19:19:32 +0000 (UTC), (Paul
FDC NOTAM 2/5319
But you seem to forget that the whole section refers to flights TO/FROM
foreign LOCATIONS. Passing through Canadian airspace when both origin and
destination are in the US is not covered by this whole section.
Old May 25th 06, 06:59 PM posted to rec.aviation.ifr,rec.aviation.piloting
Boy, Denny, you really need to brush up on what a VFR Flight Plan is, and
isn't. There is NO CONNECTION between a VFR Plan and Flight Following.
Perhaps it's also time for you to do a BFR -- if your grasp on procedures is
that shaky, your flying skills are also probably not up to scratch.
On 25 May 2006 05:20:30 -0700, "Denny" wrote:
Well, we did the flight from Saginaw to Cleveland and back... As
promised I did file VFR and I will never, never, never, pinch me, n e
v e r, do that again... What a ghastly experience... And this is
from a fella who has been flying the ATC system for over 40 years - but
hasn't filed a VFR flight plan within that time frame (that I can
remember)..
Anyway, Out on the ramp I phoned and got the Lansing FSS... Rattled off
the usual flight plan info... Waited for the usual CRAFT response and
then gotcha #1 rose up... (I should have known right then!) She didn't
read back the plan!!!
"OK, it's filed... Hayuv a nice day.", she chirped...
Slight pause on my part (the deer in the headlights look, my son, DL,
later dryly mentioned) as I was well into the role of mentor and
smoothly showing my son how it is done by a pro I thought ....
"Uhhh, I didn't get a squawk."
"Oh, I can't give you a squawk, ATC will assign that when you open your
flight plan."
Well, OK I can live with that, and I know where I'm going, I hope she
remembered... So we saddled up and turned lose those thumpin 150 HP
engines on Fat Albert... Airborne I coach DL through the mechanics of
contacting the nearest ATC and asking for the flight plan to be
opened... Gotcha #2 grins at us... Saginaw approach says they "don't"
open VFR flight plans... (Note, they didn't say can't, just don't - can
you spell 'controllers union versus the privatized FSS'?)
"You will have to talk to FSS.", click and silence...
Well, OK Martha Jane, I DO know how to talk to FSS... So we dial up FSS
and after a few calls get the nice lady... "Oh, your flight plan is
opened."...
So, back to Mr. Wonderful at Saginaw Approach...
highly condensed
"57 Pop is back with you and the VFR flight plan to Cleveland is
opened."
"OK, I can give you flight followingheh, heh, heh Squawk
'snookered', maintain 3500, blah, blah, blah...".... picture me with
sour expression
So, a few miles later we get told, "Leaving my airspace, radar services
terminated, squawk VFR.. You may be able to contact Flint." click...
silence...
Wearily I call Flint Approach... "Who are you, where are you, how high
are you (by now I wish)... And while he didn't say, why are you
bothering me, the attitude was there... The instant you say VFR flight
plan, the temperature in the voice drops 10 degrees...
The Coupe De Grass came on the return leg North lots of grubby details
condensed After Cleveland Approach pinged me to FSS and they ponged me
back, Cleveland finally, grudgingly, gave me a squawk,then waited until
I just touched Canadian Airspace and with a gloat in the voice says:
drum roll you all know what's coming
"Leaving my airspace, return to VFR, have a nice day.", click!
At that point I became annoyed and bluntly told ATC, "Wait a minute
Jack... I am in international airspace and you don't just dump me."
"Well, you can try contacting Detroit." Knowing full well that I am out
of range for Detroit
So, we spent the next 15+ miles calling Detroit... When I finally
reached them it was the three stooges who-what-why-go away routine all
over...
This morning I called the Great Lakes FSDO and spoke to an OPS
specialist... At first she gave me the party line... "tsk, tsk, I
don't know how that could happen, after all a VFR flight plan and
flight following are different programs."
After a bit she warmed up and finally told me, "Well Lockheed Martin
took over FSS and everything is changing and we don't know what ATC is
doing or why."
So, there you have it folks... File VFR and you become a scab walking
into the middle of a sit down strike... Beats me... I have been
banging around airports for over 60 years and flying the ATC system for
over 40 years, and I don't have a clue what to do...
denny
Old May 25th 06, 11:21 PM posted to rec.aviation.ifr,rec.aviation.piloting
is
Having a bad day, Jay?
That is quite a leap, accusing him of having poor flying skills, because he
was doing something (flying across the border) that he does not do
frequently. A giant leap.
Jim in NC
Old May 27th 06, 12:58 AM posted to rec.aviation.ifr,rec.aviation.piloting
On Thu, 25 May 2006 18:21:46 -0400, "Morgans"
is
Not much of a leap at all. If one is significanty deficient on one area,
the probablility of being similarily deficient in a closely related area is
quite high.
Old May 27th 06, 08:46 PM posted to rec.aviation.ifr,rec.aviation.piloting
On Fri, 26 May 2006 19:58:54 -0400, Jay Somerset
is
quite high.
The change was in the system,not in the pilot.
Over the years I had come to expect receive similar treatment from the
system whether VFR or IFR. Only on more recent flights have I seen a
major difference.
www.rogerhalstead.com
Old May 27th 06, 10:06 PM posted to rec.aviation.ifr,rec.aviation.piloting
"Roger" wrote in message
major difference.
From which system? Canada or US? And over how many years?
Granted, my first flight into Canada was "only" 15 years ago. But even
then, the US system did not generally involve ATC being willing to deal with
VFR flight plans. Doing so required them to negotiate with the FSS directly
(as opposed to dealing with an IFR flight plan that was already transmitted
to their computers), and was an additional work item they never wanted to
deal with.
The only time I was able to get ATC to close a VFR flight plan for me was
when the US Customs agent that was supposed to meet me had overslept and I
was left sitting in my airplane for 30 minutes until the guy finally showed
up and let me and my passengers out of the airplane. I was unable to reach
the FSS on their local RCO frequency while sitting on the ground (guess it
wasn't that local) and ATC thankfully was willing to talk to the FSS and
have them close my VFR flight plan, as well as phone Customs to try to
figure out why my scheduled Customs agent wasn't present.
Canada on the other hand has always been willing to deal with VFR and IFR
flight plans in the same way. As far as I know, they *are* handled the same
way for them, without the FSS-disconnect that exists in the US for VFR
flight plans. Canada ATC has always closed my inbound flight plan for me,
and opened my outbound flight plan for me. I have even filed a VFR flight
plan through the Canada ATC once when I had a mechanical issue and I was
stuck out on the airport ramp when the plane was finally ready to go. I
could've walked back into the terminal and phoned, but they let me file on
the ground control frequency through them.
As an aside (not related to your comment about "over the years", obviously),
I have not made an international flight since before 9/11/2001, so I don't
have first-hand information about how the new flight plan requirements work.
But I haven't read anything to suggest they are a LOT different from the way
they used to be, and haven't seen anything to suggest that US ATC is now
handling VFR flight plans in the same way that they handle IFR flight plans.
Someone flying internationally and expecting US ATC to open and close their
VFR flight plans just hasn't done their homework.
Pete
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 01:15 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
ADV: CPA Mountain Flying Course 2004 Dates [email protected] Piloting 0 February 13th 04 04:30 AM
