Upgrading from C172SP to 182S
Old May 25th 06, 06:29 PM posted to rec.aviation.piloting
Default Upgrading from C172SP to 182S
On Thu, 25 May 2006 11:42:18 +0200, Greg Farris wrote:
I made exactly the same transition some years ago - from a 172S to a 182S,
and my impression is in some ways opposite to the others listed here. The
182S was the first constant-speed prop I had flown, and I found the plane
took off like a rocket!
That's true. At a climb out speed of 70 knots, it feels like it's almost
on its tail. I love that feeling, but the visibility is lousy. Vy is 78
(at least in the older 182s I fly), so that's better anyway (why the POH
has the 70-80 range I don't know).
I knew the plane was heavier, so I was ready for that. You know it, and
you're ready for it. I knew about the CS prop, and had studied that too.
I think I've also found that the 182 will sink faster in the flare. That
calls for a slightly quicker flair. Some people use a little power in the
flare to slow the sink, and that works. But I prefer to avoid that
because I assume it'll cost me runway length.
- Andrew
Old May 25th 06, 07:35 PM posted to rec.aviation.piloting
Use 55 mph IAS, full flaps and a little power. This results in a slight
nose up attitude. Fly it right into the ground, no flare necessary. On
non paved strips you can lock the brakes. Total runway used is 450 feet.
Old May 25th 06, 08:15 PM posted to rec.aviation.piloting
This sounds like a glassy water landing. I've never have expected it to
yield a shorter landing distance than an unpowered landing using the same
short-field speed (65 kts in my POH, I believe). Interesting.
[Obviously, I need to go try this. Ah, another excuse to play grin.]
- Andrew
Old May 25th 06, 11:10 PM posted to rec.aviation.piloting
I had VG's on my 182 so that helped a little. I could fly final at 50
mph IAS when I was alone and about 40 gallons. 65 kts on final is too
fast for a 182 unless you're heavy. I fly at about 70 mph IAS in my Bo
and that weighs about 250 pounds more than my 182 did and the wing isn't
as good.
- Andrew
Old May 26th 06, 02:22 AM posted to rec.aviation.piloting
And to think I get ****ed when I pick up a stone chip in my prop cuz of my
cruddy taxiway...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 26th 06, 03:32 AM posted to rec.aviation.piloting
In article RLsdg.3179$No1.2442@attbi_s71,
cruddy taxiway...
That's just because you fly a nose heavy Piper. :-))
Old May 26th 06, 04:31 AM posted to rec.aviation.piloting
Atlas IS nose-heavy, compared to our old Warrior. No different than
comparing a 172 and a 182, really...and the performance difference is about
the same, too. It's just got that wing thingy on the proper side of the
fuselage!
I sure wouldn't dream of coming in behind the power curve, hitting an
unpaved strip and locking up the brakes, though. I've just got too much
money tied up in our plane to treat it like that...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 26th 06, 05:12 AM posted to rec.aviation.piloting
fuselage!
You are missing his point. At 55 kts he is still at minimum 10 kts above
aft cg gross weight stall. He is not behind the power curve. It only
takes 100-200 rpm above idle to cushion the contact.
It is easy to land the 182 in a short distance without damaging the
aircraft or with undue wear on the brakes.
Another factor is the Cessna spring steel/tubular main landing gear. A
high sink rate with your Piper may punch the main gear up through the
top of the wing. On the Cessna it will splay outward and propel the
aircraft back into the air. Additionally, the ground clearance with the
Cessna gear is greater than the Piper.
Old May 26th 06, 05:21 PM posted to rec.aviation.piloting
fuselage!
Kts? Kts is for airline pilots. That's 55 mph IAS.
Stall is around mid 40's mph.
It's a 182, we're nowhere near aft cg.
A
If you do it right it doesn't bounce at all. If you bounce you're
airspeed was too high. The lower you're airspeed the higher the sink
rate can be.
Old May 26th 06, 05:17 PM posted to rec.aviation.piloting
Treat it like what? Nothing happens to the plane.
GAO: Option of Upgrading Additional EA-6Bs Could Reduce Risk in Development of EA-18G. Mike Naval Aviation 0 April 28th 06 02:32 PM
C172SP engine start with battery switch only? Robert Winn Piloting 8 April 13th 04 12:31 AM
Cessna 182S flaps EDR Piloting 7 January 16th 04 02:37 AM
1997 Cessna 182S EDR Piloting 2 December 28th 03 03:21 AM
Upgrading System Anthony Acri Simulators 1 July 17th 03 03:18 AM
