Busted TFR, what to expect?
Old May 27th 06, 05:42 PM posted to rec.aviation.piloting,rec.aviation.misc
Default Busted TFR, what to expect?
"Jay Honeck" wrote in message
news:QLXdg.5074$1i1.1849@attbi_s72...
That's possible, I suppose. Time spent flying (and preflighting) is NOT
deducted from your lifespan, so it pays to take your time... ;-)
Preflighting *is* part of flying, as you say. I know for a fact it takes me
15 minutes, but I also know for a fact that it doesn't feel like 15 minutes
because time flies when you're having fun. I enjoy the inspection, and the
minutes just pass by like water.
I still say you're suffering from time elongation during preflight.
I suffer from the same time distortion you do. It doesn't seem like 15
minutes. But I've checked the clock on several occasions. I know how long
it actually takes.
How long does your pre-takeoff checklist take you? Perhaps we're
commingling different parts of the lists, and counting them differently as
a result?
I do a normal run-up. Electric fuel pump is my primer, and so operation is
checked during engine start, like for your airplane. In any case, even on a
172, with much simpler systems than on my own airplane, my preflight is
generally over 10 minutes, and that's an airplane I can't even get into the
engine compartment with.
I don't know what else you might be considering...my pre-takeoff checks are
pretty typical as far as I know, except for the flight control check (only
the ailerons are visible from the cockpit, so I do check the flight controls
during the walkaround). If anything, I would guess my pre-takeoff checks
are fewer than others' for that reason.
Pete
Busted TFR, what to expect? bob General Aviation 98 July 9th 06 04:00 PM
CAP SAREX what to expect? Robert M. Gary Piloting 8 August 22nd 05 02:16 PM
Class B busted...My problem or the controller's ? Antoņio Piloting 130 June 4th 05 02:59 PM
IFR to & from CLT - Delays and Fees to Expect David Instrument Flight Rules 6 August 21st 04 04:57 AM
Busted IFR Checkride Jon Kraus Instrument Flight Rules 77 May 4th 04 02:31 PM
Copyright Š2004-2025 AviationBanter.
