IFR retest (Long)
Old August 9th 04, 11:21 AM
Cecil Chapman
Default IFR retest (Long)
Great to hear Jeff!!!! Big congratulations! Be sure to celebrate!!!!!
Good Flights!
Cecil
PP-ASEL
Student-IASEL
Check out my personal flying adventures from my first flight to the
checkride AND the continuing adventures beyond!
Complete with pictures and text at: www.bayareapilot.com
"I fly because it releases my mind from the tyranny of petty things."
- Antoine de Saint-Exupery -
"We who fly, do so for the love of flying. We are alive in the air with
this miracle that lies in our hands and beneath our feet"
- Cecil Day Lewis -
Old August 9th 04, 01:40 PM
Steven Barnes
[snip]
After the VOR was behind us, he played ATC again and vectored us back to
RHP. Once he got me back in the pattern, I 'broke out' and I was able to
do
a fairly smooth landing on 26. When I taxiied off and shutdown, he held
out
his hand and said, "Well done, congratulations".
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
www.wizardofdraws.com
www.cartoonclipart.com
Cool. I've got my checkride scheduled for the 23rd. GULP! Hoping to have
only *one* post here after the ride.... ;-) We'll see.
Old August 9th 04, 01:57 PM
Dave Butler
Wizard of Draws wrote:
I jumped in and took off from runway 4, flipped up the gear handle and...
nothing. No transit light, just three greens still glowing brightly. Toggle
the handle, nothing. So I call crosswind and then downwind while I toggle a
few more times. Since Andrews-Murphy (KRHP) is in nearly the opposite
direction, Randall came on the radio and asked if I was coming back in. Just
then the gear came up. I quickly explained and peeled off from midfield back
to the north.
Congratulations on your new priveleges! Use them wisely. What was wrong with the
gear?
Dave
Old August 9th 04, 09:24 PM
David Brooks
"Wizard of Draws" wrote in message
news:BD3C4654.1B2E1%jeffbREMOVE@REMOVEwizardofdraw s.com...
Toggle
a
Just
back
to the north.
Congratulations, Jeff! Now go fly into some clouds.
But I was wondering: what was your state of mind as you hit the switch to
put the gear down at KRHP? We now know it worked...but you knew something
was wrong...
-- David Brooks
Old August 11th 04, 04:17 PM
Rod Tomlinson
Good going Jeff! Time to put some actual instrument time in that logbook!
Rod
Old August 12th 04, 12:37 AM
Wizard of Draws
On 8/11/04 11:17 AM, in article ,
Rod
Thanks Rod. After a little over 250 hours total, I've only got 1.8 of
actual.
Old August 13th 04, 08:03 PM
Andrew Gideon
We're not quite sure what the problem was with the gear. With all the
glitches just getting airborne, I was a bit apprehensive as I descended
into the pattern at RHP. But there wasn't any problem after that first
takeoff. It did feel a bit odd each time they came down, with the airplane
wanting to yaw right a tad. Perhaps they were coming down asymetrically? I
let the owner know when I got back and he's checking it out.
Hmm. I've only just recently started to fly a retract. But if I failed to
get the gear up as normal, I'm pretty sure I'd just land again and cancel
the flight. The 182RG POH has an emergency retract procedure, but if the
gear is already down and there's a nice runway right there...
Of course, one variable in my equation is that the 182RG has no backup in
case of a complete hydraulic loss. Lose all fluid, and you're going to
scratch the belly.
From what I understand, this lack is somewhat unusual.
- Andrew
Old August 13th 04, 09:29 PM
gatt
Thanks for the report! Getting ready to do my checkride at the end of the
month and getting nervous. What's more frustrating is when you ask five
pilots who the best DE is, and one guy recommends one and another says to,
by all means, avoid that guy. Congrats!
Background: July 11 was my first attempt at the IFR checkride. I failed
partial panel VOR with a full deflection, in part due to inattention and a
heavy left foot. The examiner, Mr. Jones was leaving on vacation the next
day, so a quick retest wasn't going to happen. Today I took the retest and
tried to keep my feet off the rudder pedals.
August 8, 2004 9:30 1.2 hrs.
Mr. Jones is back. The weekend was forecast for beautiful fall-like temps
and turned out to be just that. Saturday was a southeast wind out of
mostly
blue skies and Don had said that we would do the VOR partial panel retest
at
Toccoa (KTOC) instead of Knoxville if it stayed that way. The forecast was
pretty firm for that so I flew the heck out of the Toccoa VOR/DME 2
approach, thinking that was the one that he wanted to do since I thought
it
would be faster. Doh! As it turned out the VOR or GPS 20 was today's draw.
Not a disaster, but I had only studied it for a little bit and didn't fly
it
at all on the simulator. Hell, that made me even more nervous than I
already
was.
I arrived at the airport early and preflighted the plane. It needed
topping
off, but when Randall and I pulled it down to the pumps, they weren't
working. So we went looking for the gas truck driver and found him in the
main FBO. We asked for and got, a priority on our plane. Well, it almost
seemed that 'someone' didn't want me to take the test today, because now
with the truck nozzles in the wings, the truck wouldn't pump either. The
driver fiddled around a bit in the cab, then came out and realized he hadn
't
flipped a crucial switch. Voila, 18 gallons of avgas.
Toggle
a
Just
back
to the north.
At Andrews-Murphy, Mr. Jones and I really had nothing to do before taking
off for the test except brief the approach and give the plane an
abbreviated
preflight. So we climbed in and did an intersection departure. Down with
hood and he gave me mock ATC vectors to intercept the Blairsville VOR 118
radial to Foothills VOR at Toccoa. At about 9 miles from Foothills VOR he
failed my attitude and DG instruments and the test began in earnest. Deep
breaths and try to remember to relax. Surprisingly, the wind was pretty
strong at that altitude and I was having to hold a big correction to
maintain the needle, so I was making mental notes about the correction I'd
have to hold once I was established on the approach. We arrived over the
Foothills VOR, turned outbound and it took a bit longer than I'd like for
the needle to come back in (I saw him glance at his watch), but it did and
I
captured it to about a dot off center. A procedure turn that went very
well
with the wind pushing me back in and on course right quick. But it took
nearly a 30 degree crab to hold the needle, and I was sweating bullets by
now even though I was able to keep the needle within 1 and 2 dots of
center.
A quick 8 second left dogleg over the VOR, turn, time, twist, throttle,
talk, gas, undercarriage, mixture, prop, and I was on the home stretch. I
leveled off at 1900' right where he wanted it to terminate, and then he
had
me lift the hood. There was the airport and (I assumed at this point) my
ticket. Down came the hood, off came the stickies and he told me to
execute
the missed, a climbing left turn to 5000' and back to the VOR.
do
out
Old August 13th 04, 09:33 PM
Dave Butler
the flight.
That was my thinking, too.
Old August 13th 04, 10:02 PM
Matt Whiting
Well, if you are at all well prepared, it shouldn't make a lot of
difference which DE you get. Sure some will be more fun than others,
but I've yet to met one who took pleasure in issuing a pink slip.
Matt
Checkride bust (long) Wizard of Draws Instrument Flight Rules 9 July 14th 04 12:53 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
