Neat experience today.
Old May 29th 06, 11:11 PM posted to rec.aviation.piloting
Default Neat experience today.
Matt Whiting wrote:
snip
Often when flying Pipers I know slowly "pump" the controls during the
flare. One of the aviation columnists recently wrote about using this
technique and the advantages of it. I never needed it much in my 182 as I
could gradually pull back the wheel in it. The Arrow isn't nearly as
smooth and a low amplitude, high frequency "pumping" of the wheel tends to
allow smoother arrivals at closer to stall speed.
Matt
Okay, survey time. We have a lot of Piper pilots on the newsgroups. How
many of you find it necessary to "pump the yoke"to get a smooth low speed
landing? I'll go first... not me. Is something wrong with my airplane or
just every other Piper in the world?
Joe Schneider
N8437R
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old May 29th 06, 11:59 PM posted to rec.aviation.piloting
JJS wrote:
Matt Whiting wrote:
snip
Matt
I've flown four different Pipers, a Tomahawk, where I didn't notice
excessive stiction. It was very light on the controls, much like the
C150s I learned in.
I've flown two different Cherokee 180s. Both had substantial stiction,
but both were hard used FBO aircraft. My instructor sprayed some
silicon on it one time as it was so bad. This helped for a few hours,
but was short-lived.
I currently fly a Piper Arrow. It has excessive stiction. I don't know
how often the column gets lubed. I'll ask our maintenance officer at
our next club meeting.
Matt
Old May 30th 06, 12:09 AM posted to rec.aviation.piloting
Not me (cherokee 140).
Bob Noel
Looking for a sig the
lawyers will hate
Old May 30th 06, 12:17 AM posted to rec.aviation.piloting
If properly maintained and lubricated, the shaft should move freely,
without binding.
Old May 30th 06, 12:36 AM posted to rec.aviation.piloting
"john smith" wrote in message
or
without binding.
Bingo. On my old Tomahawk, I had to dip the tip of my index finger into
engine oil and spread it on both yoke shafts about once every six months to
keep everything moving easily. The difference between pre and post-lube
stiction was noticable.
KB
Old May 30th 06, 04:41 AM posted to rec.aviation.piloting
to keep everything moving easily. The difference between pre and
post-lube stiction was noticable.
I'll bet a little lithium grease would work better, longer, and be less
mess.
Of course, you seldom will have a bit of lithium grease on your dipstick,
when you need it! g
Jim in NC
Old May 30th 06, 03:52 AM posted to rec.aviation.piloting
Nope, not me either...
'79 Warrior..... no "stiction"...flare is a two finger exercise.
If my yoke is back, a slight push, it will "coast" all the way to the
panel with the engine stopped..
I would check the lubricant situation on the yoke tube...or something
ia REALLY out of whack....
Dave
On Mon, 29 May 2006 17:11:30 -0500, "JJS" jschneider@re
Matt Whiting wrote:
snip
Matt
Joe Schneider
N8437R
Old May 30th 06, 09:59 AM posted to rec.aviation.piloting
Jjs,
Me neither.
Thomas Borchert (EDDH)
Old June 1st 06, 04:10 AM posted to rec.aviation.piloting
79 P28RT201T. count me in the positive stiction category. I brought the
topic up in rec.aviation.owners before and many people replied that they had
similar problems and similar remedies to what is seen here.
"JJS" jschneider@re movecebridge.net wrote in message
Matt Whiting wrote:
snip
I could gradually pull back the wheel in it. The Arrow isn't nearly as
to allow smoother arrivals at closer to stall speed.
Matt
Joe Schneider
N8437R
News==----
Newsgroups
Old June 1st 06, 09:05 PM posted to rec.aviation.piloting
"soxinbox" wrote in message ...
79 P28RT201T. count me in the positive stiction category. I brought the topic up in rec.aviation.owners before and
many people replied that they had similar problems and similar remedies to what is seen here.
So you pump the yoke on every landing?
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 02:19 AM
First Soaring Experience BTIZ Soaring 0 September 1st 05 01:02 AM
Today, I became a pilot... Jase Vanover Piloting 8 August 8th 05 03:14 PM
Long flight today... Steve R. Rotorcraft 1 October 21st 04 11:16 PM
NASA Research looking for pilots with WSI in-flight weather experience Peter R. Piloting 3 October 20th 04 02:23 AM
