On Fri, 19 May 2006 09:04:51 -0400, "bob" wrote:
How serious is it on small twin engines with only one door? Or with 2 doors, for that matter? Unless they've changed when it comes to Bonanzas and Barons the official word from the Air Safety Foundation and American Bonanza Society is either land and close it, or leave it alone until you get to your destination otherwise they consider it *should* be a non-issue. They had lost enough pilots and passengers due to pilot distraction trying to close a door that they have one sentence that covers it. "Don't try to close the door in flight!" and they devoted a section of in the Bo/Baron specific training to that so every one had a door pop open at take off or on climb out. In the Deb it sounds like a shotgun from close range. OTOH that is the cleanest the floor has ever been in there, but it was briefly IMC in the cockpit. Each plane is different. Adhere to what ever the manufacture, or pilots group says. A friend of mine tells me that he once had a twin engine Piper crash to investigate due to ditching. It was later learned upon the conclusion of the investigation that a passenger in the back seat was trying to switch places with someone in the front and the door inadvertently popped open. At that point the investigator determined, from his own similar experience, that the plane sunk like a rock due to critical disruption of the airflow to that could not be corrected in flight. --The door could not be closed again!--- In many planes this is normal. In a Bonanza and Baron the door is part of the structure and when it pops open there is over an inch of mismatch. As for my friend with his similar experience, his friend's hand was all bloody from trying to hold it closed as much as he could. Fortunately, they This is a prime example of not knowing what should be done along with wasted time and pain. Unless they are gull type doors they are going no where with no need to try to hold it closed. made a safe emergency landing at an island the just happened to be nearby. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single It's normally a non issue with trainers, but I can't speak for all trainers. engines with only one door do not react the same as the twins. Some do and some don't. Tell me the straight skinny so I know next time I go flying. The only way to know for sure is to read the POH and consult the manufacturer, (and/or) pilot/owner groups. The number one problem with doors popping open in flight is pilot distraction. Just ask the Air Safety Foundation. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Thanks |
Beech Bonanza and Baron cabin doors are a very minor
problem. On the Baron the nose baggage door is another matter. A service bulletin (and recent production airplanes have a third safety catch which prevent the nose door from opening more than about 1-2 inches, there is also a net to secure baggage. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Roger" wrote in message ... | On Fri, 19 May 2006 09:04:51 -0400, "bob" wrote: | | How serious is it on small twin engines with only one door? Or with 2 | doors, for that matter? | | Unless they've changed when it comes to Bonanzas and Barons the | official word from the Air Safety Foundation and American Bonanza | Society is either land and close it, or leave it alone until you get | to your destination otherwise they consider it *should* be a | non-issue. | | They had lost enough pilots and passengers due to pilot distraction | trying to close a door that they have one sentence that covers it. | "Don't try to close the door in flight!" and they devoted a section of | in the Bo/Baron specific training to that so every one had a door pop | open at take off or on climb out. In the Deb it sounds like a shotgun | from close range. OTOH that is the cleanest the floor has ever been | in there, but it was briefly IMC in the cockpit. | | Each plane is different. Adhere to what ever the manufacture, or | pilots group says. | | | A friend of mine tells me that he once had a twin engine Piper crash to | investigate due to ditching. It was later learned upon the conclusion of | the investigation that a passenger in the back seat was trying to switch | places with someone in the front and the door inadvertently popped open. At | that point the investigator determined, from his own similar experience, | that the plane sunk like a rock due to critical disruption of the airflow | to that could not be corrected in flight. | --The door could not be closed again!--- | | In many planes this is normal. In a Bonanza and Baron the door is | part of the structure and when it pops open there is over an inch of | mismatch. | | | As for my friend with his similar experience, his friend's hand was all | bloody from trying to hold it closed as much as he could. Fortunately, they | | This is a prime example of not knowing what should be done along with | wasted time and pain. Unless they are gull type doors they are going | no where with no need to try to hold it closed. | | made a safe emergency landing at an island the just happened to be nearby. | | I've only flow small single engines and had NO IDEA how serious this could | be. They don't teach you that in flight school. Or is it because single | | It's normally a non issue with trainers, but I can't speak for all | trainers. | | engines with only one door do not react the same as the twins. | | Some do and some don't. | | | Tell me the straight skinny so I know next time I go flying. | | The only way to know for sure is to read the POH and consult the | manufacturer, (and/or) pilot/owner groups. | | The number one problem with doors popping open in flight is pilot | distraction. Just ask the Air Safety Foundation. | | Roger Halstead (K8RI & ARRL life member) | (N833R, S# CD-2 Worlds oldest Debonair) | www.rogerhalstead.com | Thanks | |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
