On Sun, 21 May 2006 03:18:35 GMT, "soxinbox" wrote:
In my Arrow IV, I have taken off with the door open more than once. I followed the procedures, vents closed, window open, 80 kts??, and slip. While solo, I was able to close the bottom latch, but not the top. No big Just remember that door is a structural member in the Arrow, unlike the Cessna. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com deal, I think the manual even says you can fly like this with no adverse effects. The other day I had a CFII with me, and same deal, only he could not close the top or bottom from the passenger seat. I guess the passenger has less leverage. We just landed and closed the door. "gatt" wrote in message news ![]() "bob" wrote in message . .. I've only flow small single engines and had NO IDEA how serious this could be. They don't teach you that in flight school. Or is it because single engines with only one door do not react the same as the twins. Tell me the straight skinny so I know next time I go flying. I posted about this a couple of weeks ago when the door on the Arrow II I was flying unlatched. A high-wing door -should- close itself enough that it won't disrupt airflow. A low-wing door, which is what I was flying, is a little trickier, I THINK because the low pressure over the wing draws the door out slightly, but the airflow keeps it closed enough that I determined that trying to close it in solo flight was more of a distraction that landing the airplane at a nearby strip and resecuring the door. My windbreaker and sectional vanished, though. -c |
Roger wrote:
Just remember that door is a structural member in the Arrow, unlike the Cessna. The door opening *frame* may be a structural member, but not the door itself. I doubt there's any significant cockpit strength difference when the door is latched vs. unlatched. --- Jay -- Jay Masino "Home is where the critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Roger,
If you look, the door shape no longer matches that of the opening. Please, look again. -- Thomas Borchert (EDDH) |
Roger wrote:
Open the door in level flight. Now close the door in level flight. It won't close. Why? If you look, the door shape no longer matches that of the opening. As I recall on the Cherokee 180 the mismatch was on the order of half an inch. The (4) PA-28 airframes I've flown (mostly 160HP Warriors) will close quite easily if you follow the POH in-flight door closing procedure. With the storm window open, cabin vents closed, and the right airspeed, the door is almost sucked closed. Was there something wrong with the Cherokee you were flying? G |
Roger wrote:
Consider this. Open the door in level flight. Now close the door in level flight. It won't close. Why? If you look, the door shape no longer matches that of the opening. As I recall on the Cherokee 180 the mismatch was on the order of half an inch. That means the fuselage flexed about a half an inch. The door was providing additional, structural strength albeit it's not critical. I think you're making a wrong assumption. Look at the door, the hinges, and the latches. There's nothing strong enough to be considered "structural". The door frame flexes a bit. When you have the door latched securely, first, the gap remains small. If the door frame flexes a bit, while the door is open, there's little hope of getting the door to shut as securely. --- Jay -- Jay Masino "Home is where the critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
