#11
All true, but there is no specific "Angel Flight" exemption.
Sorry, didn't mean to imply that there was a special exemption. Angel Flight is specially recognized by the FAA. If you tried to start the same organization today the FAA would require a 135 certificate since it fails the "common cause" test for 135 operation. The FAA has threatened to shut down Angel Flight in the past but they do a good job of showing successful missions on "Good Morning America" and the like. The FAA chooses to ignore Angel Flight. Our flights are purely part91 flights with no "compensation" going to either the pilot or the organization in return for the flight (neither the patient nor the hospital is ever billed a dime). True, it passes the compensation test but if failes the "common cause" test. Anytime you publicly offer to transport someone from one place to another that you would not have otherwise gone it, its generally considered part 135. AOPA has a good publication on the several tests the FAA uses to determine part 135. -Robert |
"Robert M. Gary" wrote in
ups.com: All true, but there is no specific "Angel Flight" exemption. Sorry, didn't mean to imply that there was a special exemption. Angel Flight is specially recognized by the FAA. If you tried to start the same organization today the FAA would require a 135 certificate since it fails the "common cause" test for 135 operation. The FAA has threatened to shut down Angel Flight in the past but they do a good job of showing successful missions on "Good Morning America" and the like. The FAA chooses to ignore Angel Flight. Our flights are purely part91 flights with no "compensation" going to either the pilot or the organization in return for the flight (neither the patient nor the hospital is ever billed a dime). True, it passes the compensation test but if failes the "common cause" test. Anytime you publicly offer to transport someone from one place to another that you would not have otherwise gone it, its generally considered part 135. AOPA has a good publication on the several tests the FAA uses to determine part 135. -Robert The FAA does not "ignore" Angel Flight. There is a specific order in the Air Transportation Inspector's handbook (FAA Order 8400.10) addressing the status of Angel Flight and similar organizations regarding this issue. The Air Care Alliance web site has a copy of FAA Order 8400.10, Vol. 4, Chap. 5, Section 1, Para 1345 (http://www.aircarall.org/tax.htm) which specifically tells inspectors that they should NOT treat the tax decuctiblity of Angel Flight or similar groups (referred to as "life flights") as "compensation for hire" for the purposes of enforcement of FAR 61.118 or FAR part 135. The following have been copied from the above referenced web site. The April 23, 1993 letter from the FAA Acting Chief COunsel to the Air Care Alliance and Angel Flight of Texas: Apr 23, 1993 "As a matter of policy, taking into consideration the fact that Congress has specifically provided for the tax deductibility of some costs of charitable acts, we will not treat charitable deduction of such costs, standing alone, as constituting "compensation or hire" for the purpose of enforcing [Paragraph] 61.118 or Part 135. If taking a charitable tax deduction for transporting persons or property is coupled with any reimbursement of expenses, or other compensation of any kind, then this policy does not apply." [Signed] John H. Cassady FAA Acting Chief Counsel FAA Order 8400.10, Vol. 4, Chap. 5, Sect. 1, Para 1345 12/20/94 1345. FAA POLICY REGARDING "COMPENSATION OR HIRE" CONSIDERATIONS FOR CHARITABLE FLIGHTS OR LIFE FLIGHTS. Various organizations and pilots are conducting flights that are characterized as "volunteer," "charity," or "humanitarian." These flights are referred to by numerous generic names, including "lifeline flights," "life flights," "mercy flights," and "angel flights." These types of flights will be referred to as "life flights" in this section. A. Purposes for Life Flights. The types of organizations and pilots involved with or conducting life flights vary greatly. The most common purpose of life flights is to transport ill or injured persons who cannot financially afford commercial transport to appropriate medical treatment facilities, or to transport blood or human organs. Other "compassionate flights" include transporting a child to visit with a dying relative, or transporting a dying patient to return to the city of the patient's birth. B. FAA Policy. The FAA's policy supports "truly humanitarian efforts" to provide life flights to needy persons (including "compassionate flights"). This also includes flights involving the transfer of blood and human organs. Since Congress has specifically provided for the tax deductibility of some costs of charitable acts, the FAA will not treat charitable deductions of such costs, standing alone, as constituting "compensation or hire" for the purpose of enforcement of FAR 61.118 or FAR Part 135. Inspectors should not treat the tax deductibility of costs as constituting "compensation or hire" when the flights are conducted for humanitarian purposes. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
![]() "Mike Schumann" wrote in message news:9jPeg.9452 The way I read the FARs, the private pilot needs to have 200 hours unless he has a commercial rating. In addition, you need to go thru the AOPA waver to avoid having to take the drug test. Can somebody elaborate on this? I'm looking at the form right now, and it says: "Under FAA Exemption No. 7112D, the event sponsor must provide the AOPA member-pilot with a statement indicating that neither the event sponsor nor any participating pilot operating under this exemption has operated more than four similar events during the calendar year." So, if I read this correctly, IF YOU'RE AN AOPA member, you can fill out the form and be exempted so long as the charity organization doesn't conduct these sorts of flights more than four times a year. I presume that the AOPA has some arrangement with the FAA that it extends to its members, and that the four-event maximum is to prevent bogus "charity" airlines. Am I correct and, if so, WTH does drug testing have to do with any of it? -c |
You posted some stuff regarding tax deduction and the FAAs decision that that is not "compensation". However, the FAA chooses to ignore the fact that Angel Flight would normally be considered part 135 because there is no common purpose of flight. When I was serving as the area Angel Flight check pilot instructor it was made clear to us that we were on non-solid ground and unsafe flight could easily get the entire organization shut down. -Robert |
ups.com: The FAA does not "ignore" Angel Flight. You posted some stuff regarding tax deduction and the FAAs decision that that is not "compensation". However, the FAA chooses to ignore the fact that Angel Flight would normally be considered part 135 because there is no common purpose of flight. When I was serving as the area Angel Flight check pilot instructor it was made clear to us that we were on non-solid ground and unsafe flight could easily get the entire organization shut down. -Robert The FAA Order not only exempted Angel Flight pilots from FAR 61.118 (now 61.113), but also from FAR 135. This was not an issue when I received my Angel Flight checkout and orientation. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
