Hi,
I sell and support SeeYou Mobile. It also has what they call a "Thermal Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. The interesting feature of the SeeYou Mobile Thermal Assistant is that it can be used with any GPS. Of course, it will work best with a Cambridge 302, LX7007, LX1600, Borgelt B50 or B500 that is sending it vario data, but it seems to work quite well with my Cambridge 302A GPS flight recorder. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "bumper" wrote in message ... I have both the Themi and Winpilot Pro. When I'm not flying my glider into the ground, I find that both of these devices generally work as advertised. They most often agree with each other too - - though not always. Also, in a compound thermal with several lift cores adjacent to one another, they are of no help in suggesting that the glider move to a stronger area in the complex, as may be suggested by looking at the overhead cloud structure. The Themi has one advantage over WPP, it remembers where thermals are for the return trip. And if you arrive at a different altitude the second time around, it accounts for that too. That said, if I already had WinPilot Pro, I wouldn't spend the money on a Themi unless I needed that unit's logger function. bumper wrote in message oups.com... At a fellow pilot's suggestion, for over a year I've been using Glide Navigator II's "tracks" feature to help center difficult thermals. It doesn't tell me where the best lift is but it does help me visualize the thermal and see where I am compared with the previous circles. More sophisticated soaring navigation software actually marks areas of stronger lift and may even offer recommendations: e.g., WinPilot Pro, SeeYou Mobile, and possibly others. I've stuck with GNII not only because I like it but also because I'm still running it on the old gray-scale Compaq 1550 and don't have one of the newer varios/flight computers that add airspeed and variometer data to the GPS sentences going into the PDA. I'll ignore the very real concern about whether this feature tends to make pilots look outside the cockpit even less than they already do. In my experience, those who commit this sin are the same pilots who fly their flight computers right into the ground when they accidentally set the arrival height to minus 500 ft. My question is do these features work well in WinPilot, etc.? Is the relative rate-of-climb information accurate; i.e., is the best lift displayed in the right place? What about the suggestions to shift the circle in a certain direction (e.g., the Themi device)? Chip Bearden ASW 24 "JB" |
Paul Remde wrote:
Hi, I sell and support SeeYou Mobile. It also has what they call a "Thermal Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. I've used the Thermal Assistant for about 15 flights. I can do a better job when I'm paying attention, but it's an asset when I'm distracted with other matters. These include looking for other gliders (particularly if I've lost sight of them), retracting the propeller after a launch, taking pictures of the scenery, consulting a sectional chart, using the relief tube, talking on the radio, and so on. It's not necessary to stare at the PDA, as I find a glance is sufficient to see about where the maximum lift was in the circle. This gets me "synchronized" with the thermal again. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Eric Greenwell wrote:
Paul Remde wrote: Hi, I sell and support SeeYou Mobile. It also has what they call a "Thermal Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. I've used the Thermal Assistant for about 15 flights. I can do a better job when I'm paying attention, but it's an asset when I'm distracted with other matters. These include looking for other gliders (particularly if I've lost sight of them), retracting the propeller after a launch, taking pictures of the scenery, consulting a sectional chart, using the relief tube, talking on the radio, and so on. It's not necessary to stare at the PDA, as I find a glance is sufficient to see about where the maximum lift was in the circle. This gets me "synchronized" with the thermal again. Same experience here. However, I've disabled the visual indicator and rely merely on the audible tones it generates. That helps keep my head out of the cockpit even more. Jeremy |
Jeremy Zawodny wrote:
Eric Greenwell wrote: Paul Remde wrote: Hi, I sell and support SeeYou Mobile. It also has what they call a "Thermal Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. I've used the Thermal Assistant for about 15 flights. I can do a better job when I'm paying attention, but it's an asset when I'm distracted with other matters. These include looking for other gliders (particularly if I've lost sight of them), retracting the propeller after a launch, taking pictures of the scenery, consulting a sectional chart, using the relief tube, talking on the radio, and so on. It's not necessary to stare at the PDA, as I find a glance is sufficient to see about where the maximum lift was in the circle. This gets me "synchronized" with the thermal again. Same experience here. However, I've disabled the visual indicator and rely merely on the audible tones it generates. That helps keep my head out of the cockpit even more. I'll have to try that. I've reset the Thermal Assistant parameters to make it more sensitive, and to alert me when it's time to straighten out. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. The interesting feature of the SeeYou Mobile Thermal Assistant is that it can be used with any GPS. Of course, it will work best with a Cambridge 302, LX7007, LX1600, Borgelt B50 or B500 that is sending it vario data, but it seems to work quite well with my Cambridge 302A GPS flight recorder. Paul, I assume in your case that SeeYou Mobile is calculating its own rate-of-climb from changes in GPS altitude, including the effects of any changes in airspeed (i.e., dives, zooms) as well as changes in lift strength. As I understand it, the later variometer/flight computer systems you mention add total energy climb rate to the GPS data stream which is used by WinPilot, for example, to show where the best lift is. If so, the latter approach should be more useful in optimizing climb rate but the former approach has the advantage of not forcing me to buy an expensive new vario/flight computer to replace my faithful LNAV. Do you know if SeeYou Mobile also uses vario data when available and defaults to GPS-derived climb data only when necessary? Chip Bearden ASW 24 "JB" |
Hi,
SeeYou Mobile's Thermal Assistant will use the best vario data it can get. If it can't get vario data it will use GPS altitude changes. Vario data is much faster and more accurate of course. But it seems to work OK with GPS only. I don't know whether it is using pressure altitude or GPS altitude from my Cambridge 302A. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com wrote in message ups.com... I sell and support SeeYou Mobile. It also has what they call a "Thermal Assistant" that is very much like the one found in WinPilot. It seems to work well, but I have done only a little testing so far. The interesting feature of the SeeYou Mobile Thermal Assistant is that it can be used with any GPS. Of course, it will work best with a Cambridge 302, LX7007, LX1600, Borgelt B50 or B500 that is sending it vario data, but it seems to work quite well with my Cambridge 302A GPS flight recorder. Paul, I assume in your case that SeeYou Mobile is calculating its own rate-of-climb from changes in GPS altitude, including the effects of any changes in airspeed (i.e., dives, zooms) as well as changes in lift strength. As I understand it, the later variometer/flight computer systems you mention add total energy climb rate to the GPS data stream which is used by WinPilot, for example, to show where the best lift is. If so, the latter approach should be more useful in optimizing climb rate but the former approach has the advantage of not forcing me to buy an expensive new vario/flight computer to replace my faithful LNAV. Do you know if SeeYou Mobile also uses vario data when available and defaults to GPS-derived climb data only when necessary? Chip Bearden ASW 24 "JB" |
Thermal History Software? | Gary Emerson | Soaring | 4 | April 19th 06 02:26 AM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Free Flight Planning Software | Dean Wilkinson | Piloting | 20 | September 25th 04 03:38 AM |
Free Flight Planning Software | Dean Wilkinson | Products | 0 | September 18th 04 10:44 PM |
Next: Aviation Map software | Toks Desalu | Piloting | 5 | May 24th 04 07:55 PM |
