Claude: The free wheel idea is possible, I don't think that I got the sprag
loose every time, but I know I did several times. I have done three Safaris and was able to quite easily take them down to 0.05 ips in no more than 4 starts and mine was one of them. However something has changed. I'm in the process of replacing all the plugs to see if there might be an intermittent plug causing an additional vibration that I felt while checking engine vibrations with the balancer. # 4 plugs both look like that cyl is running quite rich. The engine ips did not repeat well but the ips was down below 0.2. I disconnected the tail rotor shaft at the orange coupling or the exit of the main transmission. I did check the DSS on the bench and it does appear to function properly. Compression check is next after the plugs are replaced. -- Kathryn Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell "claude lescure" wrote in message ... Stu, If I understand, the figures in term of IPS and angle does not repeat each time you decrease to idle and start again.I may be incorrect but each time you are passing though idle the engine crankwheel can take a different place due to freewheel. And the vibrations from engine(same speed than tail rotor) could mix, interfer or be added and amplified with the tail rotor assembly.The different place taken by the engine crankwheel and slip between engine and rotor shaft each time you reduce the throtle could be the answer for non repeatable reading . Have you tried to put a velocimeter on the engine itself to see the level of vibrations at 2700RPM? Where did you disconnect the tail rotor drive? is it on the mainrotor side or on the tail rotor side? First try to check your DSS on a bench.I am almost sure that it is ok as the figures are constant as you go from 2500 to 2700 except IPS slight increasing. You could as well make a try with the second velocemeter. About tracking influence on vibration I can assure that on main rotor track adjustment has mainly effect on vertical vibration but have as well a great effect on lateral vibration. And it should be the same on tail rotor. Last time I balanced my tail rotor I had difficulties to get below 0.2 IPS. I am sure you will succeed. Claude "Gary Knutson" a écrit dans le message de news: Tv6fg.98088$iU2.89247@fed1read01... claude lescure wrote: Stu , I was just thinking: maybe the problem is comming from your balancer. Along those lines, Chadwick-Helmuth makes (or used to make) a calibrator for the purpose of check the balancing equipment. It was a fairly simple device and probably could be duplicated (as the Chadwick version was pricey). After chasing the T/R balance on my 269, it turned out the problem was indeed the CH balancer. It was not an obvous problem. I looked online and noticed that CH had been purchased by Honeywell and I wasn't able to find any further info. Gary |
Real time continuous Prop balancing | abripl | Home Built | 20 | January 15th 06 03:32 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Tracking and Balancing | Frederik Coppens | Rotorcraft | 1 | June 29th 04 02:39 PM |
Prop balancing and assorted observations - long | Dave Hyde | Home Built | 10 | June 27th 04 01:08 AM |
Balancing act | Big John | Home Built | 1 | November 28th 03 04:33 PM |
