Defense against UAV's
Old June 1st 06, 05:43 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Default Defense against UAV's
Ken Chaddock wrote:
Block 1B CIWS has an infrared and optical tracker that would do nicely
against any UAV within it's range...the question is finding the UAV in
the first place. An Infrared search system with the ability to designate
to a B1B Phalanx would work quite well I think...
But a prop-driven UAV with a small engine and some attention to exhaust
masking would not be an easy IR target.
If all you want to do is locate and identify a ship, and beam an
illuminating laser at it to guide the incoming ordnance, then the UAV
can be very small and very hard to detect.
Tony Williams
Military gun and ammunition website: http://www.quarry.nildram.co.uk
Old June 2nd 06, 02:34 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Tony Williams
Have you ever seen the radar return from a prop ? Looks like a bloody
747...a prop-job wouldn't be a particular problem and contrary to
popular misconception, most modern IR trackers don't rely on a hugh heat
gradient but rather on the difference in emissivity between the target
and the background, IOW it's tracking the delta, not the absolute IR
output of the target...
....Ken
Old June 2nd 06, 06:14 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
In article %AMfg.1638$I61.24@clgrps13,
says...
Tony Williams
So what IS the radar return from a wooden or fiberglass propellor like?
The UAVs that I've seen and the powered paragliders don't have metal
propellors. I suspect the reason is economics, rather than stealth,
though.
Mark Borgerson
Old June 3rd 06, 03:11 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
says...
Tony Williams
Not as strong as from metal but still there and the main feature of the
return is the doppler...which is unique and quite distinctive since it
varies from hub (near zero doppler) to quite high since the prop tip is
almost certainly supersonic. Remember Mark, you do get a radar return
from wood and fiberglass
Fundamentals of Stealth Design
The following article was written by Alan Brown, who retired as Director
of Engineering at Lockheed Corporate Headquarters in 1991. He is
generally regarded as one of the 'founding fathers' of stealth, or low
observable technology. He served for several years as director of low
observables technology at Lockheed Aeronautical Systems Co. in Marietta,
Ga. From 1978 to 1982, he was the program manager and chief engineer for
the F-117 stealth fighter and had been active in stealth programs since
1975. This article first appeared in 1992. Design for low observability,
and specifically for low radar cross section (RCS), began almost as soon
as radar was invented. The predominantly wooden deHavilland Mosquito was
one of the first aircraft to be designed with this capability in mind.
Against World War II radar systems, that approach was fairly successful,
but it would not be appropriate today. First, wood and, by extension,
composite materials, are not transparent to radar, although they may be
less reflective than metal; and second, the degree to which they are
transparent merely amplifies the components that are normally hidden by
the outer skin. These include engines, fuel, avionics packages,
electrical and hydraulic circuits, and people.
though.
I'm absolutely positive...
....Ken
Old June 3rd 06, 01:12 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
snip
though.
...Ken
I think weight vs. strength is a factor, too.
John Mullen
Old June 4th 06, 12:42 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
In article Ad6gg.5190$771.1108@edtnps89,
in mind. Against World War II radar systems, that approach was
fairly successful, but it would not be appropriate today.
I think stealth came way down the list when the Mosquito was
designed, especially as radar was so secret those days. Design of
the Mosquito started in 1938 when German Radar was unknown. It
was more likely wood was adopted because De Haviland had far more
experience with that material than metal. IIRC the DH4 had a
monocoque fuselage.
My grandfather was the engineer in the RAE's timber mechanics
laboratory in Bucks in the 30s and early 40s. AIUI, the idea of low
observability just wasn't a factor considered when he did the tests on
de Havilland's plywood aircraft construction to prove the concept for
combat aircraft. What was important was durability and structural
integrity after aerobatic stress or battle damage. If you look up the
research in the archives you'll find much of it associated with C.J.
Chaplin, M.Sc.
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
Old June 4th 06, 07:42 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
monocoque fuselage.
Ken Young
Plus there was a surfeit of woodworkers, joiners and cabinet makers unable
to practise their normal trade due to the war economy. The complement of
metal-bashers were committed to aircraft and vehicle manufacture, and the
'new' science of laminated materials utilising resins was becoming
available. All these factors culminated in the 'Ministry of Aircraft
Production(?)' authorising the production of the wooden-hulled aircraft and
allocating the necessary engines and hydraulic componentry to DH.
The book 'The New Science of Strong Materials - or Why You Don't Fall
Through the Floor' is recommended for the background to the development of
the Mosquito airframe.
Brian
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Air defense (naval and air force) Mike Military Aviation 0 September 18th 04 04:42 PM
Naval air defense Mike Naval Aviation 0 September 18th 04 04:42 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
