Did work ultimately - by defining a "serial" connection from the IPAQ BT
manager. Still a conflict with Activesync .. "chris" a écrit dans le message de news: ... Jean wrote: Hello, Did any one succeeded to feed Winpilot (or Seeyou Mobile) with the NMEA output of Seeyou - Via Bluetooth ? - Via USB craddle ? Thanks Jean I've had luck in running Winpilot with a NEMA output from both SeeYou and Condor simulator. The main criteria is to have it output to a serial port and to have the com port number assigned correctly on the output. I do not think these programs are setup to accept input via the bluetooth or usb [but i may be wrong], I would expect you to have good luck with the old syle serial port. Chris |
![]() Jean wrote: Did work ultimately - by defining a "serial" connection from the IPAQ BT manager. Still a conflict with Activesync .. Yes, you have to turn off Acivesync. You can configure activesyn to not make connections by port type [serial, usb etc]. This allows the port to be used by SeeYou for output. Chris |
Attention Cambridge GPS-NAV, OLC and SeeYou users--v3.5 is now current | Doug Haluza | Soaring | 2 | May 30th 06 03:06 AM |
Using mobile SeeYou | Robert Hart | Soaring | 3 | May 10th 06 09:42 PM |
SeeYou Training | Paul Remde | Soaring | 0 | April 13th 06 04:46 PM |
SeeYou Training DVD Now Shipping | Paul Remde | Soaring | 0 | January 25th 06 09:33 PM |
SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 12:25 AM |
