pgbnh wrote: Can one fail an IPC? That depends on the definition of "fail" :-) Certainly, one can fail to complete it, in which case the instructor simply doesn't give you the IPC endorsement in your logbook. But, there won't be any "Failed IPC" logged, nor will there be a failure notification sent to the FAA like when you fail a checkride. Here's an interesting twist: you've got 3 approaches logged in the last 6 months, and decide rather than just going up and flying 3 more with a safety pilot to get legal again, you're going to take an IPC. You don't fly to the PTS standards, so your IPC instructor does not sign you off for the IPC. However, you have just flown three more approaches, bringing your total for the last 6 months up to 6 (and presumably all the other silly stuff like doing a hold). Presto, in the course of "failing" an IPC, you have just become legally current again. Deciding if this makes sense is left as an excercise for the reader. |
That's a pretty productive way of failing to complete an IPC. You
pretty much know if you're not making the grade as the IPC progresses and hopefully that right there should be an indicator that perhaps some rest and reflection and another flight are in order. An instructor that signs you off for an IPC when you have flown sub-optimally is not doing you, or those you share the skies with any favors. Robert Roy Smith wrote: In article , pgbnh wrote: Can one fail an IPC? That depends on the definition of "fail" :-) Certainly, one can fail to complete it, in which case the instructor simply doesn't give you the IPC endorsement in your logbook. But, there won't be any "Failed IPC" logged, nor will there be a failure notification sent to the FAA like when you fail a checkride. Here's an interesting twist: you've got 3 approaches logged in the last 6 months, and decide rather than just going up and flying 3 more with a safety pilot to get legal again, you're going to take an IPC. You don't fly to the PTS standards, so your IPC instructor does not sign you off for the IPC. However, you have just flown three more approaches, bringing your total for the last 6 months up to 6 (and presumably all the other silly stuff like doing a hold). Presto, in the course of "failing" an IPC, you have just become legally current again. Deciding if this makes sense is left as an excercise for the reader. |
Pilot survival instinct and training should have all
instrument pilots demanding that they be really current, after all they are most likely to kill themselves and their families. Its kind of like brain surgery, a good doctor and clean operating room costs a lot more than the witch doctor in an alley, your choice. "Roy Smith" wrote in message ... | In article , | pgbnh wrote: | Can one fail an IPC? | | That depends on the definition of "fail" :-) | | Certainly, one can fail to complete it, in which case the instructor | simply doesn't give you the IPC endorsement in your logbook. But, | there won't be any "Failed IPC" logged, nor will there be a failure | notification sent to the FAA like when you fail a checkride. | | Here's an interesting twist: you've got 3 approaches logged in the | last 6 months, and decide rather than just going up and flying 3 more | with a safety pilot to get legal again, you're going to take an IPC. | You don't fly to the PTS standards, so your IPC instructor does not | sign you off for the IPC. However, you have just flown three more | approaches, bringing your total for the last 6 months up to 6 (and | presumably all the other silly stuff like doing a hold). Presto, in | the course of "failing" an IPC, you have just become legally current | again. Deciding if this makes sense is left as an excercise for the | reader. |
