Wave window file(s)
Old June 2nd 06, 05:11 PM posted to rec.aviation.soaring
Default Wave window file(s)
I am looking for a files (airspace files) with published wave windows
on the west coast in GN II format. I would like somehow to create a
file which I can use in addition to my nav points. What I would like to
see on my iPAQ is a wave windows with its boundary lines and maybe some
shade of some sort light color within the window....or maybe someone
has a program which would create those files? I also have See You but I
don't know if creation of such a window is possible in that program.
Any thoughts out there or maybe some help is available?
Thanks,
Jacek Kobiesa
Washington State
Old June 2nd 06, 06:56 PM posted to rec.aviation.soaring
I'm sending you the GN II (Newport-Peace) format files for the wave
windows in Washington and Oregon. It also includes the Mt. St Helens
TFR, the Umatilla Depot "Request.. " area, the Alvord Desert wave window
(only available during the July encampment), and a "warning" area for
the Davenport skydiver operation.
You should be able to use the file as-is in GN II and SeeYou. Let me
know if you have problems.
or maybe someone
These are just text files and easy to create, and the format should be
explained in your GN II instructions (it was in mine when I used the
program).
You can't create airspace files in SeeYou, but you can use airspace
files created for GN II or WinPilot in SeeYou.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old June 2nd 06, 08:02 PM posted to rec.aviation.soaring
If there are any computer savy folks out there, I'd think there would be
a market for a computer program that would allow airspace files to be
created graphically (lines, circles, connect the dots) and then have
altitudes assigned to them rather than having to create the files via
text. I know there is software that will pull up the MOAs, restricted
areas and generate those files automatically, but is there something for
a pilot who wants to draw a box around a local skydive operation, etc.
that he/she wants to highlight on their heads down display.
Thanks,
Jacek Kobiesa
Washington State
Old June 2nd 06, 11:30 PM posted to rec.aviation.soaring
Hi Jacek,
I may have already sent this to you, but below is the file I created for
Minden, NV. It is extremely simple.
Tip: Note that the first and last point of each area are just slightly
different. That causes GN II to draw the lines, but not fill the area with
grey.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
# Minden Wave Window - Minden-West
INCLUDE=YES
TYPE=OTHER
TITLE=Minden-West Wave Window
BASE=FL180
TOPS=FL400
POINT=N390400 W1195700
POINT=N384200 W1195700
POINT=N384200 W1193800
POINT=N390400 W1194100
POINT=N390400 W1195701
# Minden Wave Window - Minden-Central
INCLUDE=YES
TYPE=OTHER
TITLE=Minden-Central Wave Window
BASE=FL180
TOPS=FL400
POINT=N390400 W1192800
POINT=N384200 W1192600
POINT=N384200 W1193801
# Minden Wave Window - Minden-East
INCLUDE=YES
TYPE=OTHER
TITLE=Minden-East Wave Window
BASE=FL180
TOPS=FL400
POINT=N390400 W1192900
POINT=N390400 W1191000
POINT=N384200 W1190800
POINT=N384200 W1192601
END
Thanks,
Jacek Kobiesa
Washington State
Old June 2nd 06, 11:33 PM posted to rec.aviation.soaring
Hi,
I believe that StrePla allows you to edit airspace data.
It can also import DAFIF data and export airspace files in several formats.
I used it yesterday to create an SUA file for GNII for the Parowan, UT area.
Good Soaring,
Paul Remde
"Gary Emerson" wrote in message
. net...
If there are any computer savy folks out there, I'd think there would be a
areas and generate those files automatically, but is there something for a
pilot who wants to draw a box around a local skydive operation, etc. that
Thanks,
Jacek Kobiesa
Washington State
Old June 3rd 06, 02:55 AM posted to rec.aviation.soaring
Paul Remde wrote:
Hi,
Paul,
if you are looking at a background map, is there a function where you
can say "I want a circle here" stretch to form a diameter and then
assign altitudes to the airspace?
Gary
Old June 3rd 06, 04:24 AM posted to rec.aviation.soaring
Hi Gary,
I don't think so. I'll look into it. I'm off to go flying for Sat. through
Monday so it will have to wait!
Good Soaring,
Paul Remde
om...
Paul Remde wrote:
Hi,
Paul,
if you are looking at a background map, is there a function where you can
say "I want a circle here" stretch to form a diameter and then assign
Gary
Old June 3rd 06, 06:35 AM posted to rec.aviation.soaring
Gary Emerson wrote:
Paul Remde wrote:
Hi,
Paul,
The Newport-Peace format is easy to use for things like circles and
polygons, and allows altitudes to be assigned. Just a text editor will
allow you to make simple airspace in a few minutes. It's not something
you need to do much of, or very often.
Operation"
Old June 3rd 06, 04:56 PM posted to rec.aviation.soaring
For the benefit of anyone wanting to create airspace files, the
definition of the format can be found at:
http://www.spsys.demon.co.uk/software/USER.AIR
And if you need more examples, actual airspace files are available at
http://soaring.aerobatics.ws/SUA/NA.html
Operation"
Early season Sierra Wave flight [email protected] Soaring 1 September 28th 05 04:50 AM
Side window install Jim Burns Owning 3 August 11th 05 03:59 PM
Sierra wave record breaking flights IGC files [email protected] Soaring 4 April 8th 05 03:15 AM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
FS - Collection of Aircraft Information Files Matt Aviation Marketplace 0 July 21st 03 12:03 AM
