Voltage Regulator replacement
Old June 5th 06, 02:10 AM posted to rec.aviation.owning
Default Voltage Regulator replacement
kontiki wrote:
Has anyone replaced their Delco Remy voltage regulator (the old
mechanical type for a 50 amp generator) with a new solid state
type by Zeftronics? CHief aircraft sells them, just wondering
what anyone's experience was.
Mine is old, acting up and charging too high. In the old days I
guess you could clean the contacts and so forth but I'd rather just
replace it.
I would keep what you currently have installed and have an A&P reset
the voltage back to where it belongs. Resetting the voltages is a
simple task with a voltmeter. The old style last forever and changing
to a new style will require some FAA paperwork. The A&P will be worth
the cost.
Stache
Low voltage warning level markp Home Built 1 December 27th 05 05:11 AM
Low battery voltage level markp Instrument Flight Rules 8 December 22nd 05 10:16 AM
Mooney Low Voltage [email protected] Owning 22 August 1st 05 01:01 PM
High Voltage Jim Rosinski Piloting 7 October 16th 04 10:48 PM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 03:24 AM
