"Paul J. Adam" wrote in
: In message , Fred J. McCall writes "Paul J. Adam" wrote: :I'd like to keep the options open. Come in from above (where the sensors :can't see you) and see if the downwash takes it out: if not, then donate :some half-inch Raufoss at 1,100 rounds a minute. So would I. The difference is that I want to use some 20mm shells at 6,000 RPM. And I'd like to give the gunner a larger target and more time to fire - plus not everyone, not even the USN, has a fast jet in attendance on every unit at all times, but many of those units have helicopters. [Paul might want to look up the firing rate for that GAU-16 on the SH-60 (slower - only 750 RPM), the ammo supply (100 round can), and the intended purpose of said weapon ("anti-surface warfare and anti-light armor weapon"). Fred might want to look up the stats for the M3M - 1,100rpm and a 600-round feed - before making bold, sweeping statements. Not every naval helicopter is a SH-60 and not every doorgun is a GAU-16. This MIGHT give him some clue about why our opinions about how to do this differ - but, knowing Paul, it probably won't.] Just confirms the narrowness of Fred's mind - if he doesn't think it's possible then it can't be done, regardless of whether it's actually happening or not. Some helos also have pintle-mounted manually aimed 7.62 miniguns(gatlings) with a high rate of fire,and they would also be effective in downing a low&slow UAV. -- Jim Yanik jyanik at kua.net |
![]() Jim Yanik wrote: [SNIP] Some helos also have pintle-mounted manually aimed 7.62 miniguns(gatlings) with a high rate of fire,and they would also be effective in downing a low&slow UAV. -- Jim Yanik jyanik at kua.net Yep, check this out: http://www.strategypage.com/gallery/...s_20052123.asp Click the link below the photo to play the video. |
Jim Yanik wrote:
:"Paul J. Adam" wrote in : : : In message , Fred J. McCall writes :"Paul J. Adam" wrote: ::I'd like to keep the options open. Come in from above (where the sensors ::can't see you) and see if the downwash takes it out: if not, then donate ::some half-inch Raufoss at 1,100 rounds a minute. : :So would I. The difference is that I want to use some 20mm shells at :6,000 RPM. : : And I'd like to give the gunner a larger target and more time to fire - : plus not everyone, not even the USN, has a fast jet in attendance on : every unit at all times, but many of those units have helicopters. : :[Paul might want to look up the firing rate for that GAU-16 on the :SH-60 (slower - only 750 RPM), the ammo supply (100 round can), and :the intended purpose of said weapon ("anti-surface warfare and :anti-light armor weapon"). : : Fred might want to look up the stats for the M3M - 1,100rpm and a : 600-round feed - before making bold, sweeping statements. Not every : naval helicopter is a SH-60 and not every doorgun is a GAU-16. : :This MIGHT give him some clue about why :our opinions about how to do this differ - but, knowing Paul, it :probably won't.] : : Just confirms the narrowness of Fred's mind - if he doesn't think it's : possible then it can't be done, regardless of whether it's actually : happening or not. : :Some helos also have pintle-mounted manually aimed 7.62 miniguns(gatlings) :with a high rate of fire,and they would also be effective in downing a :low&slow UAV. That's one of the other things that an SH-60 might get instead of the GAU-16. Note that it, too, is intended for attacking GROUND targets. There is no weapon of which I am aware that is cleared for the SH-60 that is intended for use against air targets. Most SH-60s don't have ANY gun fitted. I'll again note that context matters, and the context of the discussion was the Iranian claim that a US carrier 'scrambled to helicopters and 4 fighters' to intercept their UAV. It's a preposterous statement. -- You have never lived until you have almost died. Life has a special meaning that the protected will never know. |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 08:14 PM |
Air defense (naval and air force) | Mike | Military Aviation | 0 | September 18th 04 04:42 PM |
Naval air defense | Mike | Naval Aviation | 0 | September 18th 04 04:42 PM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
