![]() "Michael" wrote in message m... "Chip Jones" wrote My question concerns the course reversal at MINES. If you were flying this approach from due east of MINES, "cleared approach", what do you do at MINES to get on the approach course? Thanks everyone. When I learned this IAP back in the day, it had a DME arc off of HCH Vor to get to the IAF, and then you turned down the approach course. When they slipped GPS into the system, they changed the IAP and eliminated the arc. Of course, no one told the controllers about the change- as usual they just published it. I never thought about the difference. Looks like I need some refresher training... Chip, not to be argumentative, but IMO the change to the procedure makes absolutely no difference here. Obviously it made a difference to me. :-) What the pilot did was absolutely correct. Had the DME arc been charted as before, his actions would still have been correct provided the hold-in-lieu was still charted. Removal of the DME arc is not a function of adding the GPS overlay; there are VOR/DME approaches with GPS overlays out there that include a DME arc as an option. UTS VOR/DME or GPS-A (http://www.naco.faa.gov/d-tpp/0408/05813VDGA.PDF) is one example, though it's NoPT all the way around. I have no doubt that the pilot made no mistake. The key here is this - if you're vectoring the guy to the FAC, no procedure turn. If you've cleared him direct to the IAF, he does the PT. It's just that simple. No kidding... I guess my question is this - why was this a problem? The pilot asked for the full procedure, and your traineed cleared him for it. The phraseology was not quite perfect, but well within the range of variation, at least based on my experience. What am I missing? No one said this was a problem. I posted this to gain personal insight, and nothing more. I don't think you're missing a thing. Chip, ZTL |
As a procedures sort of guy I think it was stupid to remove the DME ARC,
especially since it is a VOR/DME IAP. If the system worked the way it should, AVN-100 would not have removed the ARC because GPS overlay was added; rather, they would have removed it because your airspace staff for that area asked for it to be removed. Or, in the alternative the DME ARC might have failed a periodic flight inspection, which is more common these days as the VORs get old. Chip Jones wrote: "Michael" wrote in message m... "Chip Jones" wrote My question concerns the course reversal at MINES. If you were flying this approach from due east of MINES, "cleared approach", what do you do at MINES to get on the approach course? Thanks everyone. When I learned this IAP back in the day, it had a DME arc off of HCH Vor to get to the IAF, and then you turned down the approach course. When they slipped GPS into the system, they changed the IAP and eliminated the arc. Of course, no one told the controllers about the change- as usual they just published it. I never thought about the difference. Looks like I need some refresher training... Chip, not to be argumentative, but IMO the change to the procedure makes absolutely no difference here. Obviously it made a difference to me. :-) What the pilot did was absolutely correct. Had the DME arc been charted as before, his actions would still have been correct provided the hold-in-lieu was still charted. Removal of the DME arc is not a function of adding the GPS overlay; there are VOR/DME approaches with GPS overlays out there that include a DME arc as an option. UTS VOR/DME or GPS-A (http://www.naco.faa.gov/d-tpp/0408/05813VDGA.PDF) is one example, though it's NoPT all the way around. I have no doubt that the pilot made no mistake. The key here is this - if you're vectoring the guy to the FAC, no procedure turn. If you've cleared him direct to the IAF, he does the PT. It's just that simple. No kidding... I guess my question is this - why was this a problem? The pilot asked for the full procedure, and your traineed cleared him for it. The phraseology was not quite perfect, but well within the range of variation, at least based on my experience. What am I missing? No one said this was a problem. I posted this to gain personal insight, and nothing more. I don't think you're missing a thing. Chip, ZTL |
FAAO 8260.19 requires any arcs in a radar environment to be removed
unless they are operationally required. It appears that someone deemed that they were not needed back in 1992, when they were removed from the procedure. GPS was overlayed later, so had nothing to do with removal of the arcs. The arcs probably had the annotation "NoPT" on them, since a course reversal would not have been required from the arcs based on the TERPS criteria in effect back in 1992. An interesting point that might help ATC understand the PT/NoPT question is that anytime a route is published that allows elimination of the course reversal, then the procedure specialist must indicate that by publishing "NoPT" on that route segment. Otherwise, the PT is expected. Since ATC was substituting radar flight following (not vectors) combined with center's MIA to protect the GPS equipped aircraft on his flight to MINES, then it would be up to ATC to indicate that the course reversal was not necessary by stating that to the pilot. In the case of the UH-60, though, once he asked for the "full approach" it would have alerted me that he wanted a little more than a quick straight-in, and I would have queried him further to confirm exactly what he wanted, (hold-in lieu, clearance to Hinch Mountain for the feeder, or what?). We used to routinely vector military aircraft to intercept the final, but whenever one requested the full procedure, that was our clue to clear them via non-radar routes to the IAF, even if it was 20 miles further out. JPH wrote: As a procedures sort of guy I think it was stupid to remove the DME ARC, especially since it is a VOR/DME IAP. If the system worked the way it should, AVN-100 would not have removed the ARC because GPS overlay was added; rather, they would have removed it because your airspace staff for that area asked for it to be removed. Or, in the alternative the DME ARC might have failed a periodic flight inspection, which is more common these days as the VORs get old. |
On Wed, 25 Aug 2004 22:36:41 -0500, J Haggerty
wrote: then it would be up to ATC to indicate that the course reversal was not necessary by stating that to the pilot. By what authority can ATC do this, on this particular approach? Chip has already indicated that ATC could not issue vectors to final for this approach; and I am not aware of any authority given ATC to modify published SIAP's by eliminating required course reversals, absent VTF or timed approaches. --ron |
I didn't find any written authority that directly authorizes this. It
would be more a compilation of bits and pieces from several regulations. Unfortunately, there's not much out there in the books that relates directly to GPS overlay procedures. Example; FAAH 7110.65 Para 4-8-1 b. "For aircraft operating on unpublished routes, issue the approach clearance only after the aircraft is: 3. Established on a heading or **course** that will intercept the initial segment at the initial approach fix, or intermediate segment at the intermediate fix when no initial approach fix is published, for a GPS or RNAV instrument approach procedure at an angle not greater than 90 degrees. Angles greater than 90 degrees may be used when a hold in lieu of procedure turn pattern is depicted at the fix for the instrument approach procedure. (See FIG 4-8-2.)" EXAMPLE- Aircraft 1 can be cleared direct to CENTR. The intercept angle at that IAF is 90 degrees or less. The minimum altitude for IFR operations (14 CFR Section 91.177) along the flight path to the IAF is 3,000 feet. "Cleared direct CENTR, maintain at or above three thousand until CENTR, cleared R-NAV Runway One Eight approach." In this example, they are talking about RNAV procedures, but the UH-60 was navigating to the IAF using the GPS. If he didn't have GPS, he would not have been on an unpublished non-radar route to the IAF and this paragraph would not apply. On the procedure in question, the only purpose of the "hold in lieu of PT" is to allow an aircraft on the feeder from HCH to complete a course reversal so that he can align himself with the final approach course. It is not used to get a lower altitude and consequent descent gradient as it might be on some course reversal procedures. The UH-60 was already aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. JPH Ron Rosenfeld wrote: On Wed, 25 Aug 2004 22:36:41 -0500, J Haggerty wrote: then it would be up to ATC to indicate that the course reversal was not necessary by stating that to the pilot. By what authority can ATC do this, on this particular approach? Chip has already indicated that ATC could not issue vectors to final for this approach; and I am not aware of any authority given ATC to modify published SIAP's by eliminating required course reversals, absent VTF or timed approaches. |
On Thu, 26 Aug 2004 18:10:00 -0500, J Haggerty
wrote: I didn't find any written authority that directly authorizes this. It would be more a compilation of bits and pieces from several regulations. Unfortunately, there's not much out there in the books that relates directly to GPS overlay procedures. Then I don't understand you making up new rules. Example; FAAH 7110.65 Para 4-8-1 b. "For aircraft operating on unpublished routes, issue the approach clearance only after the aircraft is: 3. Established on a heading or **course** that will intercept the initial segment at the initial approach fix, or intermediate segment at the intermediate fix when no initial approach fix is published, for a GPS or RNAV instrument approach procedure at an angle not greater than 90 degrees. Angles greater than 90 degrees may be used when a hold in lieu of procedure turn pattern is depicted at the fix for the instrument approach procedure. (See FIG 4-8-2.)" EXAMPLE- Aircraft 1 can be cleared direct to CENTR. The intercept angle at that IAF is 90 degrees or less. The minimum altitude for IFR operations (14 CFR Section 91.177) along the flight path to the IAF is 3,000 feet. "Cleared direct CENTR, maintain at or above three thousand until CENTR, cleared R-NAV Runway One Eight approach." In this example, they are talking about RNAV procedures, but the UH-60 was navigating to the IAF using the GPS. If he didn't have GPS, he would not have been on an unpublished non-radar route to the IAF and this paragraph would not apply. On the procedure in question, the only purpose of the "hold in lieu of PT" is to allow an aircraft on the feeder from HCH to complete a course reversal so that he can align himself with the final approach course. It is not used to get a lower altitude and consequent descent gradient as it might be on some course reversal procedures. The UH-60 was already aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. I think what you are proposing is potentially dangerous. The fact of the matter is that there is no published route. There also is no TAA. Are we supposed to believe that ATC is now able to apply all of the appropriate TERPS criteria "on the fly" in off route areas, and also have the authority to legally and safely allow pilots to circumvent the published regulations and SIAP? I think that more than a compilation of bits and pieces from several regulations is required to justify this conclusion. Not all obstacles are on our charts. At my local airport, the controlling obstacle for the GPS and/or NDB 15 approach appears on no aviation charts at all. It may be that a TAA could be established around MINES, and then this discussion would be moot. But with a TAA, we pilots know that the area has been surveyed. It may also be that local pilots who are familiar with the area can safely (although not legally, in my opinion) circumvent the published approach. I just don't think you have shown that ATC has the authority to make that circumvention legal. And I don't buy the "bits and pieces". --ron |
Ron,
If you read the paragraph, you'll note that the requirement is that the aircraft be on a route or vector to an IAF. It's not unusual for an aircraft to be cleared direct to a fix even though there's not a published route. ATC would be required to ensure the aircraft was at a suitable altitude for IFR operations on this route, but the navigation would be provided by the pilot, in this case using GPS. The paragraph I quoted actually gives the authority for ATC to give an approach clearance by clearing him direct to MINES at 5000. If the intercept angle was greater than 90 degrees, then a hold-in-lieu of PT would have to be published, and on this procedure there is one published, but it's not needed in the example because a course reversal is not needed. Note that we're talking about a holding pattern in lieu of a PT, and not an actual PT. An aircraft flying the VOR from the feeder fix would be required to complete the hold-in-lieu for course reversal. Stand-alone RNAV procedures are published either with a TAA or without a TAA. If there was a TAA, then the controller would not have to provide the 5000 altitude restriction if the aircraft was within the TAA area, because he would be on a published portion of the approach and could use Para 4-8-1 b subpara 1 and 2 as directed by 4-8-1 e instead of 4-8 b subpara 3. The situation I'm talking about is using subpara 3. The aircraft was using a route rather than vectors, so the rules regarding vectors do not apply. Ron Rosenfeld wrote: Then I don't understand you making up new rules. I didn't make up para 4-8-1 b. Example; FAAH 7110.65 Para 4-8-1 b. "For aircraft operating on unpublished routes, issue the approach clearance only after the aircraft is: 3. Established on a heading or **course** that will intercept the initial segment at the initial approach fix, or intermediate segment at the intermediate fix when no initial approach fix is published, for a GPS or RNAV instrument approach procedure at an angle not greater than 90 degrees. Angles greater than 90 degrees may be used when a hold in lieu of procedure turn pattern is depicted at the fix for the instrument approach procedure. (See FIG 4-8-2.)" EXAMPLE- Aircraft 1 can be cleared direct to CENTR. The intercept angle at that IAF is 90 degrees or less. The minimum altitude for IFR operations (14 CFR Section 91.177) along the flight path to the IAF is 3,000 feet. "Cleared direct CENTR, maintain at or above three thousand until CENTR, cleared R-NAV Runway One Eight approach." In this example, they are talking about RNAV procedures, but the UH-60 was navigating to the IAF using the GPS. If he didn't have GPS, he would not have been on an unpublished non-radar route to the IAF and this paragraph would not apply. On the procedure in question, the only purpose of the "hold in lieu of PT" is to allow an aircraft on the feeder from HCH to complete a course reversal so that he can align himself with the final approach course. It is not used to get a lower altitude and consequent descent gradient as it might be on some course reversal procedures. The UH-60 was already aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. I think what you are proposing is potentially dangerous. The fact of the matter is that there is no published route. There also is no TAA. The paragraph is talking about **unpublished** routes. TAA's use a different paragraph of the 7110.65. Are we supposed to believe that ATC is now able to apply all of the appropriate TERPS criteria "on the fly" in off route areas, and also have the authority to legally and safely allow pilots to circumvent the published regulations and SIAP? No, they use the criteria contained in the paragraph shown. I think that more than a compilation of bits and pieces from several regulations is required to justify this conclusion. Not all obstacles are on our charts. At my local airport, the controlling obstacle for the GPS and/or NDB 15 approach appears on no aviation charts at all. True, but TRACONS and CENTERS have to have their charts approved by AVN and they have to ensure the same IFR altitudes as the feeder routes and TAA's. The TAA's and feeder routes don't normally depict obstacles either. It may be that a TAA could be established around MINES, and then this discussion would be moot. But with a TAA, we pilots know that the area has been surveyed. Overlay procedures do not have TAA's. The GPS portion is treated just as the paragraph above explains. --ron JPH |
![]() J Haggerty wrote: aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. Not necessarily. Intercept angle is one of two criterion for publishing "NoPT." The other is descent gradient. |
The route flown by the UH-60 was using Center's IFR altitude at 5000.
Descent gradient was not a problem, as the IAF altitude was also 5000. wrote: aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. Not necessarily. Intercept angle is one of two criterion for publishing "NoPT." The other is descent gradient. |
![]() "J Haggerty" wrote in message news:65uXc.61810$wo.23863@okepread06... I didn't find any written authority that directly authorizes this. It would be more a compilation of bits and pieces from several regulations. Unfortunately, there's not much out there in the books that relates directly to GPS overlay procedures. I agree the books are spotty for GPS overlay procedures. Example; FAAH 7110.65 Para 4-8-1 b. "For aircraft operating on unpublished routes, issue the approach clearance only after the aircraft is: [snipped] On the procedure in question, the only purpose of the "hold in lieu of PT" is to allow an aircraft on the feeder from HCH to complete a course reversal so that he can align himself with the final approach course. It is not used to get a lower altitude and consequent descent gradient as it might be on some course reversal procedures. The UH-60 was already aligned within the parameters of the TERPS criteria (90 degrees). If the route that the UH-60 flew just magically appeared as a published route on this procedure, it would be required to be published as NoPT. Good points. However, FAAO 7110.65, paragraph 5-9-1 is the controlling paragraph relating to radar vectors to FAC for Center controllers. 5-9-1d says: "d. EN ROUTE. The following provisions are required before an aircraft may be vectored to the final approach course: 1. The approach gate and a line (solid or broken), depicting the final approach course starting at or passing through the approach gate and extending away from the airport, be displayed on the radar scope; for a precision approach, the line length shall extend at least the maximum range of the localizer; for a nonprecision approach, the line length shall extend at least 10NM outside the approach gate; and 2. The maximum range selected on the radar display is 150 NM; or 3. An adjacent radar display is set at 125 NM or less, configured for the approach in use, and is utilized for the vector to the final approach course. 4. If unable to comply with subparas 1, 2, or 3 above, issue the clearance in accordance with para 4-8-1 Approach Clearance." In the case of every non-precision approach in my airspace, including RKW, the FAC is not displayed on the radar scope. We fail the test at provision #1. The weenie language that applies to this particular approach into RKW clearly forbids the controller from vectoring to FAC. Even if the pilot can fly this approach without the course reversal, it looks like Center ATC can't clear him to do so. Too bad those DME arc's disappeared... Thanks for the input, I've learned a lot. Chip, ZTL |
where to ask question about approach? | J Haggerty | Instrument Flight Rules | 1 | August 17th 04 06:30 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
