There is no way to park a drive that has heads riding on the surface.
That's been the way nearly all disk drives work since the mid-1980s. I believe the technology was invented by IBM in their San Jose disk facility. Peter Duniho wrote: "Stubby" wrote in message . .. My understanding is that modern disks have the heads riding in contact with the surface. Your understanding is incorrect. Why is there no defined "Landing Zone" on the current crop of drives? Non-sequitur. First, why would you think that "there is no defined 'Landing Zone' on the current crop of drives"? Second, in what way does the presence or lack thereof of a "Landing Zone" have to do with whether the heads contact the surface during normal operation? The landing zone is a place where the heads can rest when they are not being used to read or write data from or to the disk platters, and of course to "park" the heads when the drive is shut down. It has nothing to do with how the heads are supported when actually accessing the data on the platters. Pete |
. .. There is no way to park a drive that has heads riding on the surface. Modern drives don't have heads riding on the surface. They all "fly" above the surface, on a very thin cushion of air. That's the reason that high-altitude operation is a problem. Are you saying that you have a reference that says there is no defined landing zone on the current crop of drives, and thus you infer that because of that, the head are in contact with the platters? I'm really having a hard time trying to figure out what your point is. You don't appear to understand how modern drives work, but at the same time all of your posts are so brief, and so seemingly irrelevant to the topic at hand, it''s difficult to understand what it is you are actually trying to say. Pete |
On 2006-06-05, Stubby wrote:
There is no way to park a drive that has heads riding on the surface. That's been the way nearly all disk drives work since the mid-1980s. I believe the technology was invented by IBM in their San Jose disk facility. Modern drives are voice-coil actuated and do not need to be "parked" or "landed". When the power to the voice coil goes away, the head retracts *completely off the disk surface* into small plastic storage grooves just off the outer edge of the disk. There may be slight design differences - but if you take the lid off a hard drive that's what you'll see (obviously, don't take the lid off a hard drive you want to keep using). -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
I'm a bit of an armchair astronomer so I follow the various astronomy
groups... Astronomers who work at the high altitude observatories around the world use laptops all the time for data logging, capturing pictures off the telescope camera, controlling the telescope, etc... These observatories are above 10,000 feet... The astronomers have no hard drive problems I am aware of... The OP is repeating old wives tales without any real knowledge... denny |
On 6 Jun 2006 04:09:55 -0700, "Denny" wrote:
I'm a bit of an armchair astronomer so I follow the various astronomy groups... Astronomers who work at the high altitude observatories around the world use laptops all the time for data logging, capturing pictures off the telescope camera, controlling the telescope, etc... These observatories are above 10,000 feet... The astronomers have no hard drive problems I am aware of... The OP is repeating old wives tales without any real knowledge... HDD crash due to density altitude is a real problem, as the heads float above the platter on a cushion of air. Higher DA = less dense air = easier to contact the platter. Having said that, I have a 40G drive on my tablet PC. I regularly fly at 11.5k in an unpressurized, and have had zero problems. |
![]() I fly my turbo mooney routinely in the mid-teens and I wasn't even looking at tablets because of this issue - thanks for pointing it out! -- wingslevel Posted at www.flight.org |
On Wed, 7 Jun 2006 12:41:46 +1000, wingslevel
wingslevel.290goz@flight_org wrote: I fly my turbo mooney routinely in the mid-teens and I wasn't even looking at tablets because of this issue - thanks for pointing it out! Welcome. It certainly is not a guarantee, but I did want to point that at least one of us has been using HDDs at reasonable altitudes for a few years successfully. |
I think what we need is a turbo-normalized hard drive.
Yeah, that's the ticket. |
"Denny" wrote in message
oups.com... [...] These observatories are above 10,000 feet... The astronomers have no hard drive problems I am aware of... The OP is repeating old wives tales without any real knowledge... Drive manufacturers often specifically state a maximum elevation for use of their drives, because the issue *is* real. It is true that, with a design maximum elevation of 10K, and a failure mode that is not immediate, one can use a hard drive above 10K for some period of time without it crashing (for example, at 10,001 feet you're unlikely to ever have a problem). But that doesn't mean there's no issue. It just means the issue isn't generally catastrophic. And why would you be aware of their hard drive problems anyway? It's not like the drive is necessarily going to fail *while* above 10K feet. It can easily be damaged at altitude, and then not actually show signs of failure until the computer is back at a normal altitude. Do these astronomers report all of their technical problems, including hardware failures, to you? Pete |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
URGENT HELP !!!...FS2004/Radeon 9700 Probs...... | Derek | Simulators | 21 | May 27th 04 10:39 PM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
