Hi,
There have been a few issues with 302 flight log security failures this year. Some of the failures can be avoided by making sure your 302 is running the latest firmware (2.63) and by using the latest version of the Cambridge 300 Utility (2.57) to download your flight logs to a PDA or PC. Unfortunately, Cambridge has been unable to update the web page on which they have their utilities. I have therefore made them available on my web site he http://www.cumulus-soaring.com/cai_downloads.htm The 302 firmware file (version 2.63) has not changed in several years, but the 300 Utility was updated only a few months ago to version 2.57 for PDAs and version 2.56 for PCs. The firmware version in the 302 is displayed at power-up on the LCD display on the 302. If you find that the 300 Utility shows that your flight log does not pass the validity checks after download - please try again several times. That will most likely solve the problem. If it does not solve the problem then contact Gary Kammerer at Cambridge at ![]() possible to get a valid flight log out of the 302 - assuming that the 302 shows that it is properly sealed. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul
Any plans to upgrade the firmware on the 302 or is it going ok and they only will if there is a problem / bug? I am using it in tandem with a 303 screen and a PDA running SeeYou Mobile and its going fine. I guess most users would do something similar using CU mobile. Strepla Pocket or Winpilot. Seeyou does regular updates fixing bugs and adding features etc but Cambridge seems to be content as it is. Of course I have no idea how upgradeable the 302/303 is and if SeeYou want to supply the trick bits then I guess Cambridge have to do nothing. |
Hi Paul,
That is a tough question to answer. If you have any issues with the 302 firmware then let us know so we can try to get them addressed. Paul Remde "Paul Buchanan" wrote in message ... Paul Any plans to upgrade the firmware on the 302 or is it going ok and they only will if there is a problem / bug? I am using it in tandem with a 303 screen and a PDA running SeeYou Mobile and its going fine. I guess most users would do something similar using CU mobile. Strepla Pocket or Winpilot. Seeyou does regular updates fixing bugs and adding features etc but Cambridge seems to be content as it is. Of course I have no idea how upgradeable the 302/303 is and if SeeYou want to supply the trick bits then I guess Cambridge have to do nothing. |
Paul Remde wrote:
Unfortunately, Cambridge has been unable to update the web page on which they have their utilities. Errr, would you care to explain that one? Tony V |
Hi Tony,
I'm not certain of the details. Paul Remde "Tony Verhulst" wrote in message ... Paul Remde wrote: Unfortunately, Cambridge has been unable to update the web page on which they have their utilities. Errr, would you care to explain that one? Tony V |
Paul,
My Ipaq has the utility file version 2.5.6.0 running, so I downloaded the 'new' file. The 'new' file, named '300 Utility iPAQ 257.exe' opens up showing it is version '2.5.6.1' Is version 2.5.6.1 supposedly the same as version 2.5.7? What's up? Thanks, Ray Lovinggood Carrboro, North Carolina At 21:18 07 June 2006, Paul Remde wrote: Hi, There have been a few issues with 302 flight log security failures this year. Some of the failures can be avoided by making sure your 302 is running the latest firmware (2.63) and by using the latest version of the Cambridge 300 Utility (2.57) to download your flight logs to a PDA or PC. Unfortunately, Cambridge has been unable to update the web page on which they have their utilities. I have therefore made them available on my web site he http://www.cumulus-soaring.com/cai_downloads.htm The 302 firmware file (version 2.63) has not changed in several years, but the 300 Utility was updated only a few months ago to version 2.57 for PDAs and version 2.56 for PCs. The firmware version in the 302 is displayed at power-up on the LCD display on the 302. If you find that the 300 Utility shows that your flight log does not pass the validity checks after download - please try again several times. That will most likely solve the problem. If it does not solve the problem then contact Gary Kammerer at Cambridge at ![]() It is almost always possible to get a valid flight log out of the 302 - assuming that the 302 shows that it is properly sealed. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Ray Lovinggood wrote:
Paul, My Ipaq has the utility file version 2.5.6.0 running, so I downloaded the 'new' file. The 'new' file, named '300 Utility iPAQ 257.exe' opens up showing it is version '2.5.6.1' Is version 2.5.6.1 supposedly the same as version 2.5.7? From Paul's website: Note: This is version 2.57 but the home screen in the software incorrectly shows that it is version 2.5.6.1. So, I think you now have 2.57. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Hi Roy,
I mention that minor bug in version 2.5.7 on my web site next to the link to the file you downloaded. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Ray Lovinggood" wrote in message ... Paul, My Ipaq has the utility file version 2.5.6.0 running, so I downloaded the 'new' file. The 'new' file, named '300 Utility iPAQ 257.exe' opens up showing it is version '2.5.6.1' Is version 2.5.6.1 supposedly the same as version 2.5.7? What's up? Thanks, Ray Lovinggood Carrboro, North Carolina At 21:18 07 June 2006, Paul Remde wrote: Hi, There have been a few issues with 302 flight log security failures this year. Some of the failures can be avoided by making sure your 302 is running the latest firmware (2.63) and by using the latest version of the Cambridge 300 Utility (2.57) to download your flight logs to a PDA or PC. Unfortunately, Cambridge has been unable to update the web page on which they have their utilities. I have therefore made them available on my web site he http://www.cumulus-soaring.com/cai_downloads.htm The 302 firmware file (version 2.63) has not changed in several years, but the 300 Utility was updated only a few months ago to version 2.57 for PDAs and version 2.56 for PCs. The firmware version in the 302 is displayed at power-up on the LCD display on the 302. If you find that the 300 Utility shows that your flight log does not pass the validity checks after download - please try again several times. That will most likely solve the problem. If it does not solve the problem then contact Gary Kammerer at Cambridge at ![]() It is almost always possible to get a valid flight log out of the 302 - assuming that the 302 shows that it is properly sealed. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul and Eric:
Duh. Make note to self: R.T.F.S. Thanks, Ray Lovinggood Carrboro, North Carolina, USA At 00:24 08 June 2006, Eric Greenwell wrote: Ray Lovinggood wrote: Paul, My Ipaq has the utility file version 2.5.6.0 running, so I downloaded the 'new' file. The 'new' file, named '300 Utility iPAQ 257.exe' opens up showing it is version '2.5.6.1' Is version 2.5.6.1 supposedly the same as version 2.5.7? From Paul's website: Note: This is version 2.57 but the home screen in the software incorrectly shows that it is version 2.5.6.1. So, I think you now have 2.57. -- Change 'netto' to 'net' to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download 'A Guide to Self-launching Sailplane Operation' |
Another Cambridge 302 logger bug | [email protected] | Soaring | 8 | July 19th 05 04:05 PM |
Commercial - Updated Cambridge 302A | Paul Remde | Soaring | 2 | December 16th 04 07:35 PM |
Cambridge Instruments | Ian McPhee | Soaring | 2 | June 18th 04 10:14 AM |
Cambridge Aero Explorer Fix | Guy Byars | Soaring | 8 | May 19th 04 03:04 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
