Michael wrote:
snip What bothers me is the loss of the ADF from the training environment. The ADF forced the student to understand the difference between heading, bearing, track, and course. Is it not possible to teach these same concepts using the GPS? Those concepts are all relative to the GPS, too, no? -- Peter |
"Peter R." wrote: Michael wrote: snip What bothers me is the loss of the ADF from the training environment. The ADF forced the student to understand the difference between heading, bearing, track, and course. Is it not possible to teach these same concepts using the GPS? Those concepts are all relative to the GPS, too, no? In theory, yes. In practice, "follow the purple line" works pretty well, even if you don't really understand what you're doing. |
On Wed, 07 Jun 2006 20:09:09 -0400, Roy Smith wrote:
In article , "Peter R." wrote: Michael wrote: snip What bothers me is the loss of the ADF from the training environment. The ADF forced the student to understand the difference between heading, bearing, track, and course. Is it not possible to teach these same concepts using the GPS? Those concepts are all relative to the GPS, too, no? In theory, yes. In practice, "follow the purple line" works pretty well, even if you don't really understand what you're doing. I don't think GPS even comes close to simulating an NDB approach. GPS gives you a line to follow. Then NDB points to the station so with a cross wind and no practice you can end up arriving at 90 degrees to your original heading. You do the cross wind correction without really knowing what's going on in the GPS. Just follow the line by pointing the nose where ever it needs to go. With the NDB *you* have to figure out where it needs to go, and be able to make corrections. No more of this descending in the NDB hold on partial panel with a strong cross wind. Now that's an exercise with timed turns to a heading, timed descents to an altitude, or combining the two to make a timed 180 degree turn to a specific heading and altitude and you are expected to reach the heading and altitude at the same time. GPS just takes all the fun out of those exercises:-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote: No more of this descending in the NDB hold on partial panel with a strong cross wind. Now that's an exercise with timed turns to a heading, timed descents to an altitude, or combining the two to make a timed 180 degree turn to a specific heading and altitude and you are expected to reach the heading and altitude at the same time. GPS just takes all the fun out of those exercises:-)) Finally, a good reason to get a GPS. -- Bob Noel Looking for a sig the lawyers will hate |
On Thu, 08 Jun 2006 07:47:23 -0400, Bob Noel
wrote: In article , Roger wrote: No more of this descending in the NDB hold on partial panel with a strong cross wind. Now that's an exercise with timed turns to a heading, timed descents to an altitude, or combining the two to make a timed 180 degree turn to a specific heading and altitude and you are expected to reach the heading and altitude at the same time. GPS just takes all the fun out of those exercises:-)) Finally, a good reason to get a GPS. All I can say, particularly after having spent about two hours on the above and similar exercises... AMEN! Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Peter R. wrote:
What bothers me is the loss of the ADF from the training environment. The ADF forced the student to understand the difference between heading, bearing, track, and course. Is it not possible to teach these same concepts using the GPS? Those concepts are all relative to the GPS, too, no? Those concepts are relative to ANY method of navigation. It's just that with some forms of navigation, you can get by with not really understanding the difference most - but not all - of the time. So yes, it's possible - but not terribly likely to happen, in the same way that it's possible to teach a student to consistently fly and land at the correct airspeed and to touch down at a consistent pitch attitude and with the longitudinal axis aligned with the runway in a C-172, but usually it doesn't happen. The proof is that most pilots trained in a C-172 can't just sit down in a C-170 and fly it - but some can. On the other hand, a C-170 pilot can always get in a C-172 and fly it. That's because his skill set is more general - it always works. But if you want an airplane for practical purposes - getting from point A to point B reliably - the C-172 is clearly the better airplane. So why won't most students learn the right way in the C-172 (or with a GPS rather than an ADF?) It's just too easy to do it to PTS standards the wrong way. Why is it wrong? Because while it works most of the time, there are situations where it will bite you. In the training environment, there is a tradeoff between how good a pilot and how good a teacher an instructor must be. In an airplane with 2 nav-coms, an ADF, and a standard six-pack (and nothing else) you better be a good IFR pilot if you're going to teach in IMC (there is a special place reserved in hell for CFII's who won't teach in IMC) or you're likely to lose SA, and maybe the airplane too. But if the student manages to learn (even if he has to teach himself) he will learn (some of) the right things. With a setup like that, if he can do the (ILS, VOR, and NDB) approaches and consistenly find himself on the map or approach plate, he has learned the difference between heading, bearing, course, track, and radial - even if he can't really explain it - and has developed situational awareness. This will be the case even if his instructor can't teach. Of course he may never learn at all, but then he won't get the rating and won't be dangerous. Now let's say you have two 430's, a PFD, and backup AI, ASI, and altimeter. Instructing in IMC becomes a breeze - almost any CFII can do it. What's more, the flying is much easier. Just follow the line. There's a problem with this, though. Just following the line won't ALWAYS work. There are still situations where you need real SA. But they're hard to simulate, harder to teach, and still harder to test. It takes a really good teacher to get the student to understand why the difference between heading, bearing, course, track, and radial is important, and get the student to learn the differences, internalize them, and develop true situational awareness of which positional awareness is only a subset. The better equipment calls for a more skilled teacher, who need not be a particularly skilled pilot. Michael |
Instruement checkride...for real this time (long) | Jack Allison | Piloting | 28 | February 28th 06 03:26 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
