If another airplane is flying an approach into the airport, you cannot depart IFR. In those cases ATC may assign a VFR departure. You see an avoid the other airplane until you reach your cruising altitude. Oh, my. It's not up to me to decide whether I can depart IFR because "another airplane is flying an approach into the airport". I either get a clearance, or I don't. AFAIK ATC can't "assign a VFR departure". Please show me where it says they can do that. *I* can decide to depart VFR rather than wait for a clearance. That is not an IFR operation. In that case I am VFR, until I obtain a clearance, whether that's at my cruising altitude or some other altitude. *I* can request a VFR climb while on an instrument clearance. "VFR climb" is defined terminology. "VFR departure" is not. Others say a VFR climb can be requested right from the airport surface, with the issuance of an instrument clearance for departure. I've never seen/heard this done, but I don't see any regulatory reason why it should not be possible, and I defer to those who say they have done it. Dave |
Dave Butler wrote: AFAIK ATC can't "assign a VFR departure". Please show me where it says they can do that. Right, the pilot has to ask for it. Others say a VFR climb can be requested right from the airport surface, with the issuance of an instrument clearance for departure. I've never seen/heard this done, but I don't see any regulatory reason why it should not be possible, and I defer to those who say they have done it. A VFR climb comes in handy in the mountains. Busy places like Salt Lake see a lot of VFR climbs by the airlines so they don't have to get vectored to hell and gone for their climb. |
Newps wrote:
Others say a VFR climb can be requested right from the airport surface, with the issuance of an instrument clearance for departure. I've never seen/heard this done, but I don't see any regulatory reason why it should not be possible, and I defer to those who say they have done it. A VFR climb comes in handy in the mountains. Busy places like Salt Lake see a lot of VFR climbs by the airlines so they don't have to get vectored to hell and gone for their climb. I heard this at FLG just this past Saturday. A dash 8 was departing, and they got "VFR climb approved" or some such wording, direct from clearance delivery. Mike |
Dave Butler wrote:
If another airplane is flying an approach into the airport, you cannot depart IFR. In those cases ATC may assign a VFR departure. You see an avoid the other airplane until you reach your cruising altitude. Oh, my It's not up to me to decide whether I can depart IFR because "another airplane is flying an approach into the airport". I either get a clearance, or I don't. You already have an IFR CLEARANCE, you just do not have an IFR RELEASE. They are not the same thing. Hence you can request a VFR DEPARTURE with an IFR CLEARANCE. This is a spacing issue. The controller is obigated to hold you on the ground or at a fix until they have assurance that other IFR traffic in the vicinity (usually around an uncontrolled airport) is clear or the requisite spacing is attained. |
john smith wrote:
Dave Butler wrote: If another airplane is flying an approach into the airport, you cannot depart IFR. In those cases ATC may assign a VFR departure. You see an avoid the other airplane until you reach your cruising altitude. Oh, my It's not up to me to decide whether I can depart IFR because "another airplane is flying an approach into the airport". I either get a clearance, or I don't. You already have an IFR CLEARANCE, you just do not have an IFR RELEASE. They are not the same thing. Hence you can request a VFR DEPARTURE with an IFR CLEARANCE. This is a spacing issue. The controller is obigated to hold you on the ground or at a fix until they have assurance that other IFR traffic in the vicinity (usually around an uncontrolled airport) is clear or the requisite spacing is attained. OK, this will be my last missive on this subject. I don't think you're getting it, and I guess you don't think I'm getting it. This is not leading anywhere. When you request a VFR DEPARTURE (emphasis yours), you are not requesting an IFR procedure. You're just departing VFR. When the controller grants your request, he/she's not bestowing any priveleges on you that you didn't have already. You can always choose to depart VFR. When you depart VFR you're not IFR. Now, if you request a VFR CLIMB (emphasis mine) that's different. A VFR climb is an IFR procedure. Rebut if you like. I'm finished with this conversation. Good day. |
john smith wrote: You already have an IFR CLEARANCE, you just do not have an IFR RELEASE. They are not the same thing. Hence you can request a VFR DEPARTURE with an IFR CLEARANCE. You are still a little hazy on this. If you depart VFR you are not in the system, period. You get absolutely no separation of any kind whatsoever. You may as well have taken off VFR and requested your clearance enroute. |
Newps wrote:
john smith wrote: You already have an IFR CLEARANCE, you just do not have an IFR RELEASE. They are not the same thing. Hence you can request a VFR DEPARTURE with an IFR CLEARANCE. You are still a little hazy on this. If you depart VFR you are not in the system, period. You get absolutely no separation of any kind whatsoever. You may as well have taken off VFR and requested your clearance enroute. You already have your clearance (Puddle Jumper 12345 is cleared as filed, hold for release.) You just have to get active in the system. That is where the previous posting comes in. You will be told the who, when, where to contact to get activated. Think of it as an amended departure clearance to a point in space (Point X). Once you reach Point X and contact the facility they will again amend your clearance to your destination (from Point X). You do not have to refile, they already have the flight plan on file, they are just sequencing you into the flow with the required separation. Yes, you are VFR on an IFR flight plan that has been filed and a clearance issued, but ATC is not responsible for your separation from other aircraft. If it VFR, it is a tool to expedite your departure. Do you want to wait 15 minutes for that 152 that is practicing the VOR Approach inbound on the hold with a headwind? Or, do you want to depart? |
Here is the test to know that I am really VFR and not IFR with a VFR
Departure... ATC: "Puddle Jumper 12345, squawk VFR." |
While waiting for my release, ATC says "I have an aircaft on approach.
Can't release you until he cancels. Can you depart VFR?" I say fine. I keep the same squawk code, depart under VFR, and then get my release in the air. Why is this such a big deal? Dave Butler wrote in : If another airplane is flying an approach into the airport, you cannot depart IFR. In those cases ATC may assign a VFR departure. You see an avoid the other airplane until you reach your cruising altitude. Oh, my. It's not up to me to decide whether I can depart IFR because "another airplane is flying an approach into the airport". I either get a clearance, or I don't. AFAIK ATC can't "assign a VFR departure". Please show me where it says they can do that. *I* can decide to depart VFR rather than wait for a clearance. That is not an IFR operation. In that case I am VFR, until I obtain a clearance, whether that's at my cruising altitude or some other altitude. *I* can request a VFR climb while on an instrument clearance. "VFR climb" is defined terminology. "VFR departure" is not. Others say a VFR climb can be requested right from the airport surface, with the issuance of an instrument clearance for departure. I've never seen/heard this done, but I don't see any regulatory reason why it should not be possible, and I defer to those who say they have done it. Dave |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 08:16 PM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
| Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 08:47 AM |
| IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 10:03 PM |
