Polished Aluminum Spinner..
Old June 11th 06, 02:25 PM posted to rec.aviation.piloting
Default Polished Aluminum Spinner..
Well... it is stripped, sanded, polished..
Now, how do we keep it that way?
What do you guys use? How often?
Dave
Old June 11th 06, 02:39 PM posted to rec.aviation.piloting
Weekly labor.
Paint. Once.
Now I never have to polish the g-d thing again.
Dan
C172RG at BFM
Old June 11th 06, 03:22 PM posted to rec.aviation.piloting
Paint. Once.
How about a clearcoat paint, applied quickly after a polishing and cleaning?
Jim in NC
Old June 11th 06, 03:35 PM posted to rec.aviation.piloting
Find out what alloy was used to make the spinner, different
alloys have different corrosion prevention needs.
If you want the bright aluminum polish, a good clear coat
may keep it bright. But paint doesn't like high polish
surfaces, it needs some tooth to bite into, a good paint job
inside and out, on properly etched and primed metal will do
wonders. You can even paint the spinner with a pattern that
looks better than bright metal.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Morgans" wrote in message
| Paint. Once.
| Jim in NC
Old June 11th 06, 04:26 PM posted to rec.aviation.piloting
Paint. Once.
cleaning?
It doesn't look nearly as nice as bare, polished aluminum. Powder coated
clear is supposed to look better, but I haven't seen it.
Dan
C172RG at BFM
Old June 11th 06, 07:40 PM posted to rec.aviation.piloting
"Dave" wrote in message
The other folks are probably right, painting is the easiest.
That said, I've been very happy with Flitz metal polish. I first found it
in the hardware store, but since then have run into sales booths at
airshows. It does work great.
As far as how often, well...I don't use it nearly often enough. I suppose
weekly would be optimal, but it really comes down to how much you care about
keeping the thing shiny. I have limited time with respect to flying these
days, so frequently the choice is between keeping the plane clean and flying
it. Guess what...the plane doesn't get cleaned very often.
Pete
Old June 11th 06, 08:16 PM posted to rec.aviation.piloting
I use Mothers Mag & Aluminum Polish when the spinners on the 310 start
looking like they need polishing. Then Mothers Carnuba wax on spinners and
the leading edges to make bug removal easier. In between I use AeroShell
Touch & Go to wipe the bugs off.
Mark
N28409
WC5I
Dave
Old June 11th 06, 10:58 PM posted to rec.aviation.piloting
Us, too. We have a polished spinner and prop, and Mothers has turned out to
be the best compromise on price and results.
We probably polish the prop every other week, ditto the spinner. It only
takes a few minutes, and it looks SO much better than paint.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 12th 06, 11:07 AM posted to rec.aviation.piloting
Nuvite. It comes in several grades. We used it on our (half polished,
half painted) Cessna 140 and the polished surfaces looked like a mirror
afterwards.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old June 14th 06, 11:58 PM posted to rec.aviation.piloting
Some of the more experienced pilots might advise otherwise, but...
A trick with RVers in the south is to spray the front surface of their RV
with a very thin coat of PAM so that they can just wipe off the bugs without
chipping the paint.
I don't know if it's an option for a spinner, but you get the idea, and
maybe a similar solution would work. (Wiping it down with an oilcloth
before a summer flight, for example.)
-c
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
