CFII oral exam guide questions?
Old June 13th 06, 07:25 PM posted to rec.aviation.ifr,rec.aviation.student
Default CFII oral exam guide questions?
On 06/13/06 11:15, Jim Macklin wrote:
You can explain how a VOR/DME works with a simple visual
model.
There is a large lake with an island in the middle. There
is a lighthouse with a rotating beacon that makes one
revolution a minute. It has a white beacon and a green
beacon, when the white beacon is passing North, a big strobe
light on top flashes and a very loud horn sounds.
You see the strobe light flash and 6 seconds later see the
green beacon sweep by. Where are you? 216 degrees from the
beacon. Ten seconds after the strobe, you hear the horn,
how far away? 2 miles.
So are both the white and green beacons rotating?
Don't you just need an omnidirectional strobe (with horn for
distance measurements) and a single rotating beacon?
VOR is the same, just faster.
Steer your boat so the bow always points to the light and
you've got an ADF homer.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old June 13th 06, 08:08 PM posted to rec.aviation.ifr,rec.aviation.student
Just like the rotating beacon at the airport, the two lights
are 180 apart and rotate on the common shaft.
Yes, you could have just one light rotating, but two
identifiable beacons makes the system more useable and
faster.
English lesson... "white beacon passing North...green beacon
sweeps by" Seems that both are moving.
"Mark Hansen" wrote in message
| model.
There
strobe
horn,
for
and
| Sacramento, CA
Old June 13th 06, 08:28 PM posted to rec.aviation.ifr,rec.aviation.student
faster.
Thanks, but I don't really need the English lesson.
Your description made it sound like there were two rotating
beacons, and I couldn't see why that was necessary to make
the point. I asked the question so you could clarify.
Having one rotating beacon seems to illustrate the functionality.
If the point is to make the system easy for a student pilot to
understand, why not keep it simple?
The "useable[sic] and faster" issue isn't really necessary for
the student to understand how the system works, IMHO :-)
I do like the analogy, though.
Thanks,
| model.
There
strobe
horn,
for
and
| Sacramento, CA
Sacramento, CA
Old June 14th 06, 02:22 AM posted to rec.aviation.ifr,rec.aviation.student
I've used this analogy many times to explain VOR operation to students.. but
using one rotating beacon and the flash.. I like the idea of adding the horn
for the distance.
BT
Just like the rotating beacon at the airport, the two lights are 180
Yes, you could have just one light rotating, but two identifiable beacons
makes the system more useable and faster.
English lesson... "white beacon passing North...green beacon sweeps by"
Thanks,
| model.
| Sacramento, CA
Sacramento, CA
Oral Exam Prep -- recommendations and recollections Nicholas Kliewer Instrument Flight Rules 0 November 15th 04 05:00 PM
Training for my CFII - Got a couple questions BoDEAN Instrument Flight Rules 11 May 3rd 04 12:42 PM
