Arrow annual woes
Old June 15th 06, 06:11 PM posted to rec.aviation.owning
Default Arrow annual woes
I had to replace the hydraulic power unit in my 1972 Seneca in 1991. It had
4,000 hrs at the time. Cost was ~ $900 U.S.
news:ex1kg.13606$OL2.9653@trnddc06...
Our 1979 Arrow IV is in the shop for its annual inspection. As usual, the
inspection itself went smoothly, but it uncovered some maintenance items
that will run into several AMUs. Here are the top three uglies:
1) The inspection part of Piper Service Bulletin 1161 resulted in
identification of cracks in both affected wing ribs. That's the bad news.
The good news is that the cracks are in locations that will allow the use
of
the Piper repair kits, which Piper stocks. Jack Allison has posted on
this
NG his horror story of replacing the ribs when the cracks precluded use of
the repair kits, so in a way we feel lucky. Cost estimate for the SB
compliance with the repair kits is about 1.3 AMU, including parts and the
initial inspection.
2) The hydraulic power pack has to be replaced or overhauled. We can't
feel
too bad about this one because it's the original (1979) unit. 27 years is
a
more than reasonable service life. A rebuilt replacement goes for 0.8
AMU,
which is about the cost of overhauling ours. We will do a swap in order
to
avoid downtime for an overhaul.
3) The biggie! The support structure under the wing walk is cracked in
several places and needs to be replaced. This is apparent from a slight
"oilcanning" of the wing skin in the wing walk area when we step on it.
Repair will necessitate removing the right wing, a bunch of drilling to
remove the old structure, replacing it with a new assembly (cost unknown)
and replacing the wing. our mech estimates (roughly) the job will take
about 24 hrs of labor and cost, with parts, around 2 AMUs. It's not
really
a safety issue as the structure only supports and reinforces the wing walk
-- it is not part of the primary wing structure. But left unrepaired the
outer skin could crack, resulting in a much bigger repair job. Our shop
has
never done this job before but one of the assistant A&Ps has, and the
estimate is largely based upon his knowledge. Have any of you other
PA-28/PA-32 owners had this problem?
The rest of the identified maintenance items are the usual collection of
individually minor items -- a seal here, a gasket there -- but of course
collectively they typically add up to about 1 AMU.
Glad this is going to be split 3 ways!
-Elliott Drucker
Old June 15th 06, 08:06 PM posted to rec.aviation.owning
There is always a Van's RV...
denny
Wait till SBs become mandatory by regulation .. which is in the works.
It's going to cost $1000 plus per hour to operate these old planes. And
the value of them is going straight in the toilet.
Old June 15th 06, 09:41 PM posted to rec.aviation.owning
On Thu, 15 Jun 2006 13:43:01 -0500, Otis Winslow
snip
snip
this is just plain incorrect.
just read today that AOPA (or some other alphabet) is climbing onto
the soapbox to fight this non-issue.
one more time-the recent ruling states that if you are overhauling
an engine in accordance with an approved overhaul manual that
explicitly states that service bulletins are mandatory, you must
comply with the service bulletins.
nothing new, just the first ruling to that effect.
there is a world of difference between this ruling and the blanket
statement that all manufacturer SB's will "become mandatory" by
regulation.
TC
Old June 15th 06, 10:09 PM posted to rec.aviation.owning
I think you're dead on TC, and many people have missed this when reading the
ruling. In that particular case it was the overhaul manual that made the
SB's mandatory. There was literally no way to comply with the accepted
overhaul manual without complying with the SB's. The SB's became PART of
the overhaul manual. In all practical purposes "updates" to the manual.
(waking up each morning to the sounds of PT-6's and R-1340's... summer is
officially here)
Old June 16th 06, 12:53 AM posted to rec.aviation.owning
Actually, You're Both incorrect... The only way a manufacturers SB
becomes MANDATORY for a part 91operator is thru an AD note or if it is
referenced in the TCDS. Just because Lycoming puts that statement in
the manual does not make it mandatory....
Joe
officially here)
Old June 16th 06, 04:08 PM posted to rec.aviation.owning
Then I would argue that the term "overhaul" could not be used to describe or
certify the work done on the engine, no matter if part 91 or part 135. The
mechanic certified that the engine had been overhauled according to the
approved overhaul manual. "Overhaul" requires specific compliance with the
approved overhaul manual, if that manual states that in addition to the
current manual, all SBs be complied with, any other action would negate the
official definition of "overhaul". This is not saying that the engine could
have been legally repaired, rebuilt, fixed, or use any other word you want,
but it was not overhauled as the mechanic had certified.
"joe" wrote in message
Joe
of
is
officially here)
Old June 16th 06, 01:47 AM posted to rec.aviation.owning
Some SBs become mandatory because of a subsequently issued AD, but by
themselves they are, from a legal standpoint, voluntary. That said, my
feeling is that SBs generally address serious issues that soul be dealt with
by careful pilots/owners.
In the 10 years I have co-owned our Arrow IV, the various Piper- and
Lycoming-issued SBs affecting our plane have had quite modest cost
implications. Unfortunately, the SB dealing with cracked wing ribs caught
us -- not because of the cost of the inspection, which took about 2 hours of
A&P labor (if done at the time of an annual), but because it revealed some
cracks. The cracks make the airplane un-airworthy, SB or no SB. So in
effect, the big cost is not in complying with the SB, but rather in
repairing the damage that performing the SB uncovered.
Yes, older airplanes generally have more maintenance issues. Things wear
out. But properly maintained, their values generally, on average, have more
than kept pace with inflation. Consider, for example, Bonanzas from the
'70s and '80s. They require lots of expensive maintenance but their values
keep climbing, or at least hold firm, year after year.
-Elliott Drucker
Old June 17th 06, 01:06 AM posted to rec.aviation.owning
"Some SBs become mandatory because of a subsequently issued AD, "...
Tell me about it. Years ago, there was a service bulletin on the Seneca for
the landing gear trunions. Some operators were reporting cracks. The S.B.
beacame an A.D. I had just over 2000 hours on the trunions, and they had to
be replaced. (They had already been magnafluxed several times, with no
cracks found).
$5000 spent fixing that one.
news:tcnkg.9854$db5.4007@trnddc03...
with
of
more
values
-Elliott Drucker
Old June 16th 06, 05:44 AM posted to rec.aviation.owning
The good news is that the cracks are in locations that will allow the use of
the Piper repair kits, which Piper stocks. Jack Allison has posted on this
the repair kits,
Misery does love company. Maybe when it's all said and done, our final
costs will be pretty close. I hope yours is less though. Glad you
could go the SB route vs. rib replacement. 1.3 AMUs is much better than
just north of 5 AMUs.
Sure can't complain about that kind of service life on the hydraulic
power pack...and for less than an AMU. That's just $29.63/year. Such a
deal. :-)
3) The biggie!
Ouch! I hate it when there's a biggie found at annual time (and I've
only been through one).
As JayH said, check into CPA. I've read a few things about the repairs
but don't recall costs involved.
Yes! That divide by three things sure does help make it easier to
swallow, eh?
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Annual and rib replacement complete Jack Allison Owning 13 May 10th 06 04:00 AM
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 12:29 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
