Roy Smith wrote:
In article .com, wrote: Now let me ask a question. What if ATC clears you direct to the VOR and then clears you for the "straight-in" approach? Isn't the controller's instruction in conflict with the AIM? Who wins, hypothetically speaking (say you can't contact him for clarification)? I had almost exactly this same situation happen the other day with NY Approach. We were coming into White Plains (HPN) from the north, IFR. Controller gave us something like, "direct FARAN, cleared ILS-16". FARAN's not an IAF, the route from FARAN inbound is not marked NoPT, we hasn't giving us vectors. By strict interpretation of the rules, he gave us a bum clearance. On the other hand, not only did I know that he wanted us to fly the approach straight-in, but there was no practical reason why anything else would make any sense, so we did it. The bottom line is that the AIM just hasn't caught up with real life. Not exactly. The following was added to the AIM recently. Note that it is limited to RNAV IAPs. There were lenghty discussions within FAA and with industry. It was at first proposed to permit the practice for all instrument approach procedures with an intermediate fix, and limit it to GPS or advanced RNAV aircraft. FAA's ATC management nixed the idea for conventional, ground-based IAPs. So, it isn't really the AIM not staying up with the "real world," it's the real world inventing its own rules. 5-4-7 i. ATC may clear aircraft that have filed an Advanced RNAV equipment suffix to the intermediate fix when clearing aircraft for an instrument approach procedure. ATC will take the following actions when clearing Advanced RNAV aircraft to the intermediate fix: 1. Provide radar monitoring to the intermediate fix. 2. Advise the pilot to expect clearance direct to the intermediate fix at least 5 miles from the fix. NOTE- This is to allow the pilot to program the RNAV equipment to allow the aircraft to fly to the intermediate fix when cleared by ATC. 3. Assign an altitude to maintain until the intermediate fix. 4. Insure the aircraft is on a course that will intercept the intermediate segment at an angle not greater than 90 degrees and is at an altitude that will permit normal descent from the intermediate fix to the final approach fix. |
![]() Sam Spade wrote: 5-4-7 i. ATC may clear aircraft that have filed an Advanced RNAV equipment suffix to the intermediate fix when clearing aircraft for an instrument approach procedure. Wouldn't a cleaner and more permanent change be to mark those intermediate fixes as IAF or IF/IAF on the GPS/RNAV approach plates? Or is there a reason that isn't practical? I guess that means the initial segment would have a length of zero. (perhaps that's not allowed in the TERPS?) |
equipment suffix to the intermediate fix when clearing aircraft for an instrument approach procedure. How does this jibe with the letter of interp requiring an a/c to use an IAF or be vectored to final. Will this language be added to the ..65 so it can be said to be approved by the Administrator? |
Greg Esres wrote:
ATC may clear aircraft that have filed an Advanced RNAV equipment suffix to the intermediate fix when clearing aircraft for an instrument approach procedure. How does this jibe with the letter of interp requiring an a/c to use an IAF or be vectored to final. Will this language be added to the .65 so it can be said to be approved by the Administrator? It was added to 7110.65R this past February. Here is the new portion of 7110.65R, 4-8-1: "Area Navigation (RNAV) Standard Instrument Approach Procedures may begin at an Intermediate Approach Fix for aircraft that have filed an Advanced RNAV equipment suffix when the conditions of subpara b4 are met." And, here is the background material for the change in the back of 7110.65R: BACKGROUND: Currently, paragraph 4−8−1 provides two methods for clearing aircraft for a Standard Instrument Approach: 1) clear the aircraft to the Initial Approach Fix (IAF) (or Intermediate Fix (IF) when no IAF is depicted), or 2) vector the aircraft to the final approach course. These procedures create undue delay to pilots and air traffic control under certain conditions. When an aircraft utilizing Area Navigation (RNAV) is aligned with the final approach course and at an altitude not requiring abnormal descent to the final approach fix, air traffic must either clear the aircraft to an IAF or vector the aircraft to the final approach course. RNAV aircraft are capable of flying direct to a fix or waypoint with more precision than a radar vector. A direct−to clearance eliminates variables of aircraft drift when changing altitudes and/or airspace when a strong wind shear is present. A radar vector to a typical RNAV approach would place the aircraft within 2 miles of the IF. This requires the controller to monitor the aircraft in variable wind conditions to ensure it does not intercept the final approach course prior to the IF. The final approach course does not extend beyond the IF as a radial on a conventional approach. There are several supporting examples permitting RNAV aircraft to be cleared direct to an IF to execute an instrument approach procedure. FAA Order 8260.3B, United States Standard for Terminal Instrument Procedures (TERPS), paragraph 230, provides for an initial approach to be made along an arc, radial, course, heading, radar vector, or combination thereof when the IF is part of the en route structure. In this case, the approach commences at the IF and a direct−to clearance provides a course for the aircraft to fly. Aircraft may be cleared to the IAF/IF for RNAV approaches. When a Terminal Arrival Area (TAA) is depicted, most TAAs specify NoPT (No Procedure Turn) for the straight−in segment. This permits aircraft to fly the same segment of the instrument procedure as any RNAV approach from the IF. 14 CFR Section 91.175(i) contains the following statement: “When operating on an unpublished route or while being radar vectored, the pilot, when an approach clearance is received, shall, in addition to complying with Sec. 91.177, maintain the last altitude assigned to that pilot until the aircraft is established on a segment of a published route or instrument approach procedure unless a different altitude is assigned by ATC.” Aircraft are on an unpublished route when cleared direct−to a fix or waypoint and the intermediate segment defines the segment the aircraft must be established on for the approach. Issuing aircraft a direct−to clearance to the IF will enhance the movement of aircraft in the terminal environment. Requiring the controller to advise the pilot in advance of the clearance, limiting the turn angle to intercept the intermediate segment, accounting for descent along the approach and providing radar monitoring, the procedure will ensure the pilot is able to safely maneuver the aircraft for the approach. 3 |
Ah, thank you. Mine is outdated. |
Change in AIM wording concerning procedure turn | Kris Kortokrax | Instrument Flight Rules | 208 | October 14th 05 12:58 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Unusual Procedure at DFW | Toks Desalu | Piloting | 9 | December 17th 03 05:27 PM |
Instrument Approaches and procedure turns.... | Cecil E. Chapman | Instrument Flight Rules | 58 | September 18th 03 10:40 PM |
