![]() On 16-Jun-2006, "Dan Luke" wrote: Getting it done is no big deal. I have it done to my airplane every other annual. My airplane has been parked two miles from Mobile Bay for six years and shows no signs of airframe corrosion. Good news for a change! For some reason I had it in my mind that the process was fairly involved and thus expensive. Our Arrow has nearly always been hangared, and corrosion has not, to date, been an issue. But now our mech is seeing some very minor powdering and recommends the treatment. We'll probably get it done in the next couple of weeks. I previously co-owned a C-172 that spent its entire life (18 years when we sold it) outdoors, never had any anti-corrosion treatment and never had any serious corrosion issues. This is in Seattle, so the plane got rained on regularly. Apparently salt is a much bigger issue than wet. The plane was parked at BFI, less than a mile from Puget Sound (sal****er). But there is very little salt in the air and on the ground here. Humidity in summer is generally low, and no need for salt or other chemicals for clearing ice from roads in winter. -Elliott Drucker |
Just curious if anyone has ever suspected ACF-50 or
other corrosion treatment as being bad for some plastic / bakelite type parts? The reason I ask is that my C172 had been treated with ACF-50 in years past via the previous owner. I had a flap failure one day and discovered the cause was the microswitches in the right wing that sense flap full-up / full-down position. Both switch cases had broken down to the point that just touching them caused them to crumble into pieces. I'd never seen anything like that before, and I've handled a lot of old microswitches. The only possible explaination I could offer was that the ACF-50 might have damaged the hard plastic case on the microswitches. Of course maybe it was some other lubricant or cleaner that had been sprayed into that area inside the wing. Anybody else ever see anything like this? Ronnie "Dan Luke" wrote in message ... wrote: Based on his inspection of our Arrow's airframe during its current annual, our mech is recommending a Corrosion X treatment. Anybody have one done at one the authorized Corrosion X Treatment Centers? Feedback, good or bad? Cost? How long did it take? I'll go ahead and call the nearest center (which is not exactly convenient) but thought I'd ask for opinions and advice from the group first. Getting it done is no big deal. I have it done to my airplane every other annual. My airplane has been parked two miles from Mobile Bay for six years and shows no signs of airframe corrosion. -- Dan C172RG at BFM |
![]() "Ronnie" wrote: Just curious if anyone has ever suspected ACF-50 or other corrosion treatment as being bad for some plastic / bakelite type parts? Nope. My only gripe about Corrosion X is that it leaves oily streaks on the finish (they wash off) for months after each application. Necessary evil, I suppose. -- Dan C172RG at BFM |
On Fri, 16 Jun 2006 17:55:06 -0500, "Dan Luke"
wrote: "Ronnie" wrote: Just curious if anyone has ever suspected ACF-50 or other corrosion treatment as being bad for some plastic / bakelite type parts? Nope. My only gripe about Corrosion X is that it leaves oily streaks on the finish (they wash off) for months after each application. Necessary evil, I suppose. You "wash" your airplane? Next you'll be giving your cat a bath. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote: You "wash" your airplane? Next you'll be giving your cat a bath. Heh. My airplane is parked under cover but not in a hangar. At BFM, jet engines and APUs are running almost constantly at Mobile Aerospace Engineering. Jet-A soot, dust and salt spray stick to the plane overnight when it gets wet from condensation. I can wash it on Sunday and it will be filthy again by Friday, just by sitting there. Usually, I just give it a quick squirt bath with the hose. About every other month it gets a real wash. -- Dan C172RG at BFM |
No reason to hire anyone to do that other than to save yourself the trouble.
I use it for everything I need to protect from corrosion here in the caribbean, even my car, scooter, etc. 100% results. It works exactly as advertised and then some. All you need to do is open up those inspection panels and access points, maybe remove the interior and the paneling to get to the inside of the back of the aircraft, and apply. wrote in message news:wUokg.17361$Bj6.12126@trnddc08... Based on his inspection of our Arrow's airframe during its current annual, our mech is recommending a Corrosion X treatment. Anybody have one done at one the authorized Corrosion X Treatment Centers? Feedback, good or bad? Cost? How long did it take? I'll go ahead and call the nearest center (which is not exactly convenient) but thought I'd ask for opinions and advice from the group first. -Elliott Drucker -- Posted via a free Usenet account from http://www.teranews.com |
Pilatus B4 and corrosion | Mika Koski | Soaring | 1 | April 26th 06 09:50 PM |
Corrosion Evaluation Help | Dick | Home Built | 3 | July 15th 05 02:51 AM |
Surface Corrosion? | Joaquin Murrieta | Home Built | 2 | May 3rd 05 01:19 AM |
Corrosion Proofing | Clay | Owning | 7 | April 22nd 05 12:03 AM |
How much corrosion is too much? | Carl Orton | Owning | 5 | February 2nd 04 01:31 AM |
